Mine arrived. I found a tube light that is actually longer, 138 mm vs 136.5 mm, than the FC12. It's an Eagle Eye X5 on the left:
Also found tailcaps that fit and work, but not the other way around:
This one may be my favorite:
Even an old SWM C20C cap fits:
I do like the beam. As others said because of the deep reflector, the hot spot is well defined, the flood area is small but bright. Also I noticed the lower levels don't have the green effect I see on my custom FET+1 drivers with the SFT-40. For the FET+1's, on the lower channel 7135, there's a noticeable green. Not sure why but must have something to so do with PWM'ing at low amps (0.35 amps). The stock driver on the FC12 doesn't have that effect.
It's funny because the reflector looks designed for a 3535 XP footprint LED. It looks like the reflector is actually sitting on the corners of the LED because the hole is too small, but it works well, appears to be well centered.
Overall now, I'm glad I ordered this light.
I did measure ~6.3 amps on a 30Q and ~7.3 amps on a 25S cell, so it does vary based on resistance of the cell. Not sure, but at least on max/turbo, it may be in full FET mode. Just a spot check on the 30Q had about 1800 lumens at start which probably makes sense from the amp readings. It's a small light so heats up quick at these levels.
Mine didn't come with a manual - hope I can get one to download.
Wurkkos disregard any and all ideas about a side switch working as an on/off switch. Because if you do that, the light loses the ability to be jacket-pocket carried without accidental activation. Or else have a separate model with the side switch as activation switch.
There few and many reasons for a manufacturer to do whatever deem fits best.
End of the day, I will never buy any Wurkkos Flashlight because when newly launch, they tends to overpriced. After 1/2 months, they price will drop drastically.
I don’t see how that’s a disqualifier. Sounds like a reason TO buy Wurkkos. They get their profit from people unwilling to wait, and you pay less later on.
It’s a manufacturer, not a friend or neighbor, and with the pace that new flashlight models are released prices will always go down.
