I made a short 2.5 minute video including a beamshot comparison of the sst20 4000k version of this light vs the aaa sofirn C01s (sst20) lumintop tool aa (4500k) Emisar D4 (sst 20 4000k) and the emisar D4V2 (XPL-Hi 5000k)
Jonathan! And whomever else… slice those ssts you’ll get lower duv and the little guy won’t hurt much losing a little output, it’s a little over powered anyway?? Not complaining, just noting. (I’ve heard slicing sst20 lowers output? Mine might’ve but not by alot). I can only imagine how hot a ti gets…
Anyway, i have no regrets doing it. Slice high to avoid the wires, it’ll still get a duv shift down in a very pleasing manner. And tighten up beam (slightly/ relatively). It went from a novelty light for me to carrying often because i can use at lower levels and still like the tint.
And thanks y’all, I’ve had good lurk reading in this thread, that resulted with another flashlight. Funny how that happens…
maukka agrees w you,
glad youre enjoying using the light
technically tint is still above bbl after shaving sst-20
but, I dont mind the stock tint of my 4000k SST-20 FWAA
Ive become more open minded recently… lol
I like how it renders colors
other results of shaving
fwiw, I “tightened up the beam” (but failed to document the change), by polishing the outside of the Tir on a yellow jewelers rouge cloth… now there is a hint of a hotspot, and its a “bit” (undocumented), throwyer…
Ive been carrying it a lot… its my new hot item
actually, I dont use Turbo, I set ceiling to 400 lumens, and 40C thermal limit…
the copper handles the heat great, I can actually hold Turbo in my hand for 10 seconds, but thats not why I like the light… it has great hand feel, and Im enjoying using it with 12 steps… dont care for the ramping… that double flash bugs the crap out of me
I think I understand what the flashes are when ramping… correct me if I am wrong, ramping from lowest brightness, it’s the 7135, first flash ramping up is FET, then the last flash at the highest level indicates direct drive…
my question is, were the flashes an intentional design choice? Or unavoidable?
I don’t particularly like the flashes, but I like to know where the PWM begins to avoid it when using as a room lamp for long periods, though I wonder what the feel of the smooth ramping would be without the flashes.
Only other comment I have (and it’s the wrong thread for it, but I just don’t have the energy to post much anymore, and I have only occasionally lurked every few weeks), is that had I seen the Anduril2 change in development to have TWO ways to get to that confounded 5C momentary mode, I would have requested against it… I liked manual memory, and now it is buried behind 10H from on rather than just 5C from on. I don’t like that, but I am getting used to auto memory I guess.
I haven’t posted in some time… got a job is all. Exhausting. I don’t remember it being so tiring to work FT, say, even 6 years ago. I just read that new report about metabolism dropping quickly as one ages… must be that. Anyway, missed you all, and will continue missing you
I looked into that can of worms and decided to just switch to stepped mode… it does not have the FET flashes
congrats on the new job
yes the midramp flashes mean FET, top flashes just mean top
but ramping is so fast that if I try to get the highest output before the double flash for FET, I end up somewhere between 75 and 150 lumens on my meter…
I get 130 lumens on step 11 of 12 with a 200 lumen ceiling… iow, only the 12th level is above FET…
I have the advantage of being able to measure lumens…
bottom line is the FWAA FET boundary seems to be around 150 lumens, but there is no way I can hit that with smooth ramping… I either overshoot or undershoot
so… to me, the double blink is just an exercise in frustration
plus its inconsistent… as there is no double blink in stepped mode… I cant hit 150 in stepped either, but I can come closer, consistently, using a step I know is below 150 lumens
I just use stepped to avoid the double flash, most of my use is below FET level anyway
Congrats on the job! What’s your domain and role? Sleep. Gotta get more sleep. That’s just the way it is as we age. If we starve ourselves of sleep, we lose energy AND we encourage health problems. Buy yourself a new mattress and pillows. Don’t skimp. You sleep every single day on that stuff, so it should be the best you can afford!
I avoid stepless ramping when I can. I am chuffed that Anduril can let us define as many steps as we want. With this, I can hit the brightness I need with ease. When it’s stepless, I can’t decide where to stop! A bit OCD, I guess. :laughing:
Fireflies lights that i have do not have the flashes during ramping… something i noticed but can’t say for sure (i have several, but have not checked to make sure) although i don’t mind either way.
Sometimes it’s nice to know where you’re at and sometimes it’s nice to be smooth jazzy.
Kind of wish there was a fade in out to memorized level ala klaurus. With adjustable fade speed. Need to upgrade my coding game first unless somebody?
I have some non flashlight lamps like that. Just saying, since we’re talking ramping.
I’m just curious… what’s the point of doing this? I mean of course it’ll be more of a thrower, but aren’t there other AA lights already in existence of the same form factor with decent throw?
Hum, it will not be a “thrower” per se, it will only have a more narrow beam, if compared with the FWAA triple.
As for the size, the smallest AA light with clicky switch is the DQG Slim Ti, and I’d say that this is the second smallest now! All the other AA lights do not have this form factor! I would bet that it will probably be smaller than the upcoming FW1AA …
The DGQ doesn’t allow UI configuration, nor does it allow “turbo” or firelfly modes, or even the blinkies! This one will allow.
I could have kept the original light and change only the LEDs and optic, but then…there would be no fun!
And besides all this, the fun of modding and doing something a) useful, b) usable and c) different, thrills me
Again, comparing sizes…nothing gets near these FWAA lights, even if mine is now modded!
Jaxman E3 > Tool AA V2.0 > Skilhunt M150 > FWAA modded > DGQ Slim Ti > FWAA
Got mine this morning, it’s properly small unlike many AA lights, very nice. Very, very floody though, I chose 219Cs 4000K but should probably have gone with SST-20s. I think I’ll try slicing them to improve that a bit, as well as the tint, regarding the later here are measurements with the default advanced UI steps :
My FWAA Cu is still SST-20 4000k stock. I really enjoy it. For me, the tint works and illuminates colors nicely. My FW3A XPL-Hi 3D (5000k) looks nicely neutral next to it. Now there are so many triples available by other makers. I’ve been tempted, but these work so well.
imo the TS10 is better because, the beam is more throwy, the switch is more firm, and the waistline is more centered. Plus the TS10 has Aux, and a better version of Anduril without blinks in the ramp.
otoh, the FWAA clip is better because it is fully captive, and the hatclip portion is slightly longer and easier to put on a hat.
