FastTech New Arrivals & Promotion
No problem :+1:
Hello Notmyrealname,
The tail cap is spring-loaded, there are 4 emitters(same Nichia 219C/Luminus SST-20) included, one is in the middle, you can see the below picture:
The previous three lights have the reflector cup but the middle one doesn’t have.
Ummm……Does anyone know if this is possible? and if it is what the purpose or reason is?. Just an aux LED?
Sure it's possible and this light, and OTR's in general, are nothing fancy so it's probably just another LED in parallel offering more lumens, more flood. I'd love to buy one just to see how it's done, unless FT wants to send me one to review (hint, hint)
Normally the wire hole is in the center but doesn't have to be. There's some sort of black showing on the left in the pic, and possibly a wire solder pad - could be the black wire.
It's not a bad idea to squeeze quad LED's into a triple, you keep the head diameter small and with lower amps these have, you get more lumens/amp I would think.
You could very well be right but as there are other specs being given that don’t seem to make sense on other new OTR lights I’m going to wait until I see OTR’s specifications or a review. If you’re right It’s an interesting design.
Fenix PD36 TAC Mechanical Tactical LED Flashlight
1*Luminus SST70 LED / 8-mode / 3000LM / pure white / 1*21700 / USB rechargeable / IP68 waterproof
Voltage: 3.7-4.2V
Head diameter: 26.5mm
Tail diameter: 25.4mm
Tactical and duty modes for flexibly needed choice and operation.
Patented dual-function tactical switch for instantly tactical activation.
Single-handed toggle switch for mode selection.
Lockout function avoids accidental activation.
Reverse polarity protection, to protect from improper battery insertion.
Made of durable A6061-T6 aluminum.
Premium type HAIII hard-anodized anti-abrasive finish.
The Fenix PD36 TAC flashlight is a mechanical flashlight that remains in pocket size but focuses on tactical employment. Included with a 21700 rechargeable Li-ion battery, the PD36 TAC emits a max 3000-lumen output and has an impressive beam distance of up to 274 meters. The PD36 TAC features a dual-function tactical switch which enhances its tactical capabilities. The Tactical Mode strengthens the PD36 TAC with a faster operation and simplified selection of high and instant strobe. Switch to the Duty Mode by rotating the toggle switch, the PD36 TAC delivers 6 output modes including a strobe. Made for professional use, security and law enforcement, the PD36 TAC is truly countable to deliver reliable, powerful lighting for a wide range of situations.
Fenix LR35R LED Flashlight
6*Luminus SST40 LED / 6-mode / 10000LM / pure white / 2*21700 / USB-C rechargeable / lanyard / IP68 waterproof (2m underwater)
Reflector diameter: 43.5mm
Head diameter: 51.5mm
Tube diameter: 46.5mm
Tail diameter: 46.5mm
This Smiling Shark…is it next-mode memory and what emitter does it use?
It is no memeory function, and the emmiter is L2.
Authentic Nitecore HC60 V2 Outdoor LED Headlamp
1*LED / 8-mode / 1200LM / pure white / 1*18650/2*CR123 / USB-C rechargeable / IPX7 waterproof / 180’ adjustable
Max Beam Intensity: 4240 cd
Advanced temperature regulation
Power indicator
100’ wide range flood beam
Elastic and breathable headband
1m impact resistance
UniqueFire UF-1404 LED Flashlight
authentic / 4*Cree XP-L / 3-mode / 4000LM / 6500K / 4*18650 / lanyard
Reflector diameter: 48mm
Head diameter: 59mm
Tube diameter: 48.5mm
Tail diameter: 53mm
Lanyard length: 18cm
Beam range: 100-200m
Working voltage: 14.8-16.8V
Fasttech,
do you have any sitewide promotions for this month or Labor Day?
Yes, we will have the sitewide promotion for the Labor Day.
Fenix E05R Mini Keychain LED Flashlight
1*Cree XP-G2 S3 LED / 4-mode / 400LM / pure white / Micro-USB rechargeable / IP68 waterproof
The Fenix E05R flashlight is a rechargeable mini flashlight that can emit up to 400 lumens from its built-in 320mAh Li-polymer battery. Fully rechargeable via a built-in micro USB charging port, the flashlight has a maximum runtime of 30 hours. This little flashlight is built tough with an IP68 dustproof and waterproof rating. Super small and compact, this keychain flashlight is a great choice for everyday carry.
Cree XP-G2 S3 white light LED with a lifespan of 50,000 hours.
Built-in 320mAh Li-polymer battery.
Hidden Micro-USB charging port.
Metal switch for on/off and output selection.
Instant Burst.
High-efficiency lens with a total reflective coating.
Head diameter: 15mm
That Fenix E05R looks interesting.
Any chance it has easy-to-implement lockout?
Yes, just double click to lock or unlock.
Fenix PD35 V3.0 Tactical LED Flashlight
1*Luminus SFT40 LED / 6-mode / 1700LM / pure white / 1*18650/2*CR123A / IP68 waterproof
  • The improved PD35 V3.0 flashlight is destined to enrich the PD35 series flashlights. This light delivers a maximum of 1700 lumens at a distance of 357 meters. This Fenix PD35 V3.0 is compact but tough and features five output levels plus instant strobe. The dual switch design, tactical tail switch, and metal side switch- which also has a built-in battery level indicator, offer rapid and user-friendly operation. Ideally powered by one rechargeable 18650 Li-ion battery, it is also compatible with two cold-resistant CR123A batteries. All these highlights make the Fenix PD35 V3.0 very suitable for military use, policing, outdoor exploring, emergency lighting, EDC flashlight use, and more.
  • 1700 lumens maximum output; 357 meters maximum beam distance.
  • One Luminus SFT40 LED with a lifespan of 50,000 hours.
  • Included a 18650 rechargeable Li-ion battery, compatible with 2*CR123A Lithium batteries.
  • Boot-up battery level indication and low-voltage warning.
  • Instant activation with the tactical tail switch; output selection with the side switch.
  • Digitally regulated circuit for maintaining a stable output.
  • Toughened ultra-clear glass lens with an anti-reflective coating.
  • Made of durable A6061-T6 aluminum.
  • Premium type HAIII hard-anodized anti-abrasive finish.
  • Head diameter: 25.4mm
Nitecore P20i UV LED Flashlight
1*Luminus SST-40-W LED + 4*365nm LED / 5-mode / 1800LM / pure white & UV light / 1*21700/2*CR123 / IP68 waterproof
Head diameter: 31.8mm
Tail diameter: 28.5mm
Nitecore P20iX Tactical LED Flashlight
4*Cree XP-L2 V6 LED / 7-mode / 4000LM / pure white / 1*21700/2*CR123 / IP68 waterproof (2m underwater)
Nitecore P10iX Tactical LED Flashlight
Head diameter: 28.5mm
