"Review" - Wuben D1 - 1100 Lumens - 18650 powerbank battery
The lighted switch is in my opinion the only thing missing on the T050R to make it perfect. I don’t know if you like it as much as I do but what a fantastic wall of light, pur high CRI joy
Yup, probably one of the best lights I have too :wink:
That is a “beast” of a light! I am afraid of using it more giving it is almost a “premium” light, but whenever needed, it comes out of the “light-box” :wink:
And yes, an indicator LED could be good on it! Using a 21700, any parasitic drain would still make no harm on it!
BTW, I am not sure if Wuben uses the led indicator on the C3 and the C5 as well!
After checking Unheard’s thread reviewing the D1 I changed the information about the LED : it is a Cree XP-L HI 6500K instead of an Osram P8 or P9 as I initially suspected.
Thanks Unheard for the correct information :beer:
Very interested in this light, but would require me to swap in an 2700K 80+ CRI to be happy with it. Does disassembly seem feasible to do this?
So far I wasn’t able to remove the bezel and I am afraid that when I do that I will damage the host a little bit. Maybe I don’t have the proper tools for it or the skills, but it is really stuck :weary:
If or when I can do that I will post it here referring to the method to retrieve it!
Tried and failed, too. I fear it needs heat, but optics and electronic components are close to the bezel. I think I’ll live with it. It’s ok outside. Actually I’m happy about every single candle I can squeeze out of it.
Thanks for telling your experience Unheard :wink:
Yeah, I suspect some heat would be needed, despite I also think that it can be some pressure downside up! But for that I’d probably need to remove the driver and that may not turn good :weary:
I did it :person_with_crown:
I disassembled the head! :smiling_imp:
So, it is not glued, but pressed. I used the tools in the photo below.
The work-knife is quite tough so I used the “baton” method around bezel, starting on one side and making the diameter tryin to push the knife edge in. After a while, it started opening a gap and then I used the knife to press the bezel towards the top. And it poped-up! :wink:
Structure:
  • bezel,
  • white o-ring,
  • optic/reflector (single piece as far as I can tell),
  • black thick o-ring,
  • copper DTP MCPCB star with around 1.2-1.5mm thickness and
  • gray thermal paste below.
  • EDIT: there is also a screw in the shelf to prevent the MCPCB from rotating
As Unheard has mentioned and confirmed before, this has a XP-L HI emitter.
As far as I can tell, a 3535 led seems to fit below, but careful if you want to try a XP-L HD, that has a larger dome.
Some notes:
  1. the optic/reflector has a slightly flat area on the side that allows to “disengage” it from the bezel, and I used pointy tweezers in that area to pull it out
  2. the bezel is somewhat “ridged” (not sure if the expression is correct) and those ridges leave a mark in the head structure, meaning that it was pressed into the head. Or the head already those grooves and the bezel fits into them
 I guess the first theory is more suitable in this case.
Note that the bezel and the head have some marks because I used pliers and other tools before, unsuccessfully :frowning:
Any questions, let me know :wink:
And good luck in case you folks try to disassemble it! :+1: :beer:
Well done :+1:
If ano scratches are visible, a sharpie/edding hopefully helps. Do you have an idea what LED you’ll reflow?
Thank you :wink:
Hum, the scratch on the optic does not interfere with the beam, and the scratches of the host
well, I’ll say it adds personality :stuck_out_tongue:
As for the led to reflow I don’t have many options around me so a Luxeon V2 may be the candidate! I don’t know the tint yet :person_facepalming:
The optic sits really over the led, I can see the marks in mine, so it needs to be a carefull operation :wink:
And
done!
Luxeon V2 4000K on the board :wink:
It guess the beam is - structurally - the same, but the tint is obviously different :wink:
Here are some photos from it and from the driver.
BTW, the solder on the wires is quite tough, so if you’re going to replace the led, be ready for that!
Or maybe my soldering iron may is too weak, eventually :stuck_out_tongue:
hello.
the battery can charge ony with 5V 1A charger? - because nowdays is hard to get. can i charge witg 5V 2.1 A or above charger?
thx
And it fits with the dome left on! :+1:
What was the reason to choose the Luxeon? What CCT is it?
The joys of RoHS? :weary:
I do.
Yup, the dome fits in :partying_face: But I still suspect that a XP-L- HD wouldn’t fit well!
As for the Luxeon, I have a bunch of them that I bought from Led4Power. I really like these leds, they have a warm tint, with some rosy notes (not like Nichia, though).
I used a 4000K, similar to the one I installed in the OTR 311, RovyVon A23 and also FW1A :slight_smile:
It is a balanced LED for my current tastes, even if they are not High CRI leds.
I suspect so, maybe lead-free solder is the reason . Or maybe my soldering iron needs to be powerfull :smiley:
Hi there,
Thanks foĐș great review!
Do you think any CRI 90-95 (4000-5000K) led will fit this light?
Hi and welcome to BLF!
Sure, as far as I can see, any 3535 led will fit and can be used, so Nichia, SST-20 or Samsung LH351D can be used.
The only ones I don’t think that can be used without damaging the led is Cree XP-L HD.
I guess that the Samsung leds, even being larger than Nichias concerning the “dome”, can be used.
Thanks man! Just looking for an ideal flashlight as usual, with type-c built-in, nice flood\combo light, hi-cri, protected batteries (paranoid, that’s why fireflies or noctigon lights won’t go), found this WUBEN and the only drawback is a little cold and not h-cri led, so with your information hope it will be cool (not meaning tint!).
Your welcome and I hope you can enjoy the light :wink:
Please note that the flashlight itself doesn’t have built-in charging, only the included battery.
If you’ve read what I posted regarding the bezel, it takes a while to get it out and it may leave some bruises in the flashlight body. So, please note that before getting the flashlight to modify it.
Hello. Here is my video review of the D1 :wink:
Just curious, any idea if the current shipping version of the Wuben D1 uses Osram P9 LED or XPL-Hi LED?
