If you want lumens, I have and strongly recommend KR1vn, it’s a modified version by Vinh with SBT90.2. Get the aluminum for cost. The other two practical high powered flashlights would be the Acebeam L35 or the Acebeam E70.
If you want an alternative for quality emitter and not feeling the D4v2 sw35. Consider the Bobralight, a modified Zebralight SC64c with your choice 219b emitter (the sw35 and the sw45k are his lot popular lights). You can find him here on Re-edit to see if he is still taking custom orders. Below are other good references that have helped me:
I have a Nitecore P30 so no need to buy a C8 but i am considering a Convoy M21B with SST40 because you are correct that its about the best all purpose light and is essentially the M1 but with 21700 support.
And double the lumens
The Convoy you link to is a 21700 light, it will be thicker and a bit longer than the one in your picture. The choice in this segment is almost unlimited, there’s no brand without several different models in this format so I think you should start with defining a bit more what you want: the higher capacity of the 21700 or the lower weight and smaller size of the 18650? Side-button, rear-button or a combination? Throw or spill or something in between? Simple UI or complicated like Anduril? CW, NW, WW and hi-CRI or not?
One I’m looking at myself is the Sofirn SP31Pro, don’t need it but still want it for fun, especially now they are starting to introduce colors……
For your own safety, You should add None, and sell the ones you have.
You have demonstrated by your numerous posts of stupid questions, and your troll responses in which you argue with those who give answers, that you are a low-IQ person that lacks the necessary intelligence to safely handle and operate flashlights.
Though Black Friday (sales) are just over a month away i am finalizing my intended light purchases.
Right now i am looking at replacing two lights i sold with these upgrades, the Convoy M21B and Convoy S21A.
My criteria are a tube light and all purpose light, most lumens and reliable. And 21700.
Are these the best choices?
Just got a Convoy 3x21a with 90.2 LED from Alibaba.com. Quite nice. Highly recommend you to give this some consideration, if you especially like 21700 flashlights.
But couldn’t find this either at “Convoy flashlight Store” in Ali Express, or Banggood.
You need a beater. Something that if you hit or lose it doesn’t matter. 550 lumens.
Ilumn has the Wowtac A1. This lights comes with a chargeable battery built in the battery. 2600 mAh.
Has dual switch and a pretty balanced beam. Moonlight and SOS. Strobe too.
The original price is 24 bucks. They have it for 9.99 WOW!.
I bought 3, I’m sure they have more.
Cheers.
