I happen to like 60° to even 90° for floody. Mine are all clear, but if you got the options (they’re cheap enough), get a few of each. Pebbled is nice, like my E3A twisty, clear is fine, frosted is probably like diffusion film.
My 120°s tend to have a ring around the periphery, but 60° and under are all perfect. 90° can be either.
Again, just need to try ’em and see what you prefer (which might be different from what I prefer).
Mine works perfect with lighted switch because it has the new driver witch works with lighted switch (the old driver with on/off always change to next mode). Look inside the tube, if you see silver band between the fets it’s the new driver with option 12 selected (only 1 mode). You need to change the option that you like in config mode.
Your S2+ comes with old driver. Not bad because at the moment with the new driver I can’t enter to config mode, with 10 or 20 clicks always change to next mode.
It’s a 219b 3500k custom builded from Simon. Silver with rubber button and OP reflector. I use the lighted switch from another S2+ that didn’t work well with old Biscotti driver.
I freakin love this thing!Nichia B35AM 5000K R9080 with 6V/3A driver.But it anoys me not having anything between 20% and 100%. I like simple 3 mode but a jump from 20% to max is too much so i find my self constantly taping tailswitch.Simon if you read this i would apreciate if you could rearrange modes on your drivers. 5%-50%-100% for nightshift workers…
Nearly 10mm² of emitter area equals lovely large spot in edc sized optics. I want one with a LumeX1 in my FW1A. 21700 mates well with this emitter though, really nice build!
