On 2 trustfire protected 26650's charged to 4.2 volt each, I'm getting 6.83 amps. I does seem easy brighter on 2 cells over 3. I say all yours are just under driven since mine is still with in the manufactures claimed 7.5 max.
The light runs in dim mode only once voltage hits around 6 volt or below and is not that bright at all, but mine still is running in full brightness and you can change modes drawing 6 + amps.
Once the cells run down it will top out at 7.5 amps and will continue to run till it hits low voltage then drops out and dim,s the same as the manufacture claims.
6 volts or under the current draw drops drastically due to the dimming circuit and so does the brightness, the TR-3T6 and TR-1200 work in the same way once they are in dim mode below 6 volt. this is also about when the protected batteries cut out approx 5 to 6 volt depending on the battery.
The skyrays did not do this hence all the fried drivers with there early triples. Useless info 3.7 volt loaded the driver in mine will draw under 1.6 amps and at 2.7 volt it will draw under 0.58 amps.
I wonder why shopbot and benkie are pulling 42-55W at 8.4V, while it seems EVERYONE else is only at 30-35W? Sample to sample variation perhaps? I would think 8.4V is still too high for low voltage protection to be kicking in??
Its pretty weird man. When I test the 2x18650 configuration, the reading fluctuates ALOT. There was like a range of up to 2A. I cannot pinpoint a good average whereas for all other configurations, I can get a nice somewhat consistent reading. Don't really know. Mind you my DMM was a $15 eBay one, so take it for what its worth.
I forget the current measurements, but I calculated the power at about 28 watts for any battery configuration (2 or 3 18650 and 2 26650). I only have 4 26650s, 2 of which are IMR, and two LiFePo4, so I don't want to mix chemistries/voltages to try 3 26650s.
About 4 days after I received the tr-j12, the spring behind the battery contact in the head either broke or dislodged, and now I have to use magnets as spacers for either 18650 or 26650.
Anyone know how to remove the pill from the head with breaking anything? It seems that the head is press-fit into place.
If yours is like mine, there really is no "pill". The driver "engine compartment" comes apart, unscrews and separates the LED+reflector half from the DC-DC driver half. A pair of long wires deliver power from one section to the next. See my pics in the linked thread. The DC-DC board is pressed into the aluminum and a brass collar is threaded over it to lock it into place.
I gently stretched the spring back out and used copper braid to releve the spring of some of the current flow.
The input voltage is not higher than what 5 LEDs need and If the driver is regulated it has to boost the amps to maintain the brightness of all those 5 LEDs the multimeter+ leads will act as a voltage drop, showing high current draws, as it's already boosting the voltage. It doesn't matter matter how good the DMM (reg.Fluke) all have some burden voltage that will affect the reading in series with the flashlight on boosting circuits.
That is extremely helpful Kramer, thank-you very much. I didn't know that the head/heatsink was 2 pieces, though I had my suspicions.
Since I didn't hear anything rattling inside the button, de-tempering of the spring makes perfect sense. Guess I will add a new spring with copper braid (I think I have some old RG-58 floating around - the shield would probably work well for that). I might see if I can retain the button spring cover as well. I will try to post pics and measurements once I get everything all fixed. Once I get repairs done, I may get one of the tr-j10's and see if I can properly drive the led - they look like they could be good throwers.
Anyway, I am really impressed with the output from this light, as well as the seemingly good thermal transfer to the air. I would love to see real measurements of the output using a true integrating sphere. The folks in Asia always pad all their numbers to make their products look better in advertisements.
It also seems, from looking at the performance curves from Cree, that the individual leds in this light are driven nearer the most efficient part of the curves than typical single-led lights. My only real complaint (other than the poorly-chosen spring design) is the fact that this light is very top-heavy - makes it cumbersome to hold and maneuver.
So everyone knows, I am an old-school flashlight modder, back from the days when xenon and halogen were the cutting-edge technology. Since Cree, SSC, Luninus, etc., have gotten the efficiency so high on leds, I can see no purpose for those old tungsten relics, except as museum pieces.
With Kramer5150's help, I figured out how to get everything apart in the head of the TR-J12. Same problem - spring was de-tempered and squashed. I will also use his fix - adding a piece of braided copper to assist current flow. I suspect, however, that the contact between the spring and the button is creating a high impedance failure point (maybe even arcing?), which may be contributing more to heating than anything. Also suspect is the cheap plating on the spring. I will try to dig up some conductive grease or epoxy so that the spring and cap make better contact.
So if anyone else purchases this light, prior to use, some braided wire should be installed at both ends and perhaps this failure may not happen?? Thanks.
Sure np... if you are familiar with incan mods, the wire braid is the same thing. Current is current, wattage is wattage, be it LED or incan.
It should be noted that time duration is also a factor. If you only use it for short burst only, then you may not really need to add the wire braid. Mine only melted after leaving it on for 10-15 minutes to intentionally get it cooking, to let some moisture vent out of the head.
The 7.5a manufacturer rating is current output to be split between all 5 LEDs. That equates to around 24 watts with XM-L vf. Yours, pulling 6.8 amps at the tail, is at around 55 watts and if the driver is letting all that to the LEDs will be at a current output of around 18 amps! Well over the rated 7.5.
I am starting to wonder if we have different driver board components. I am wondering if the SMT components in our lights are all identical... or if the supplier populated the boards with close-compatible parts, and scratches out the part numbers. Threads like the one below make me wonder about the manufacturing process quality of the PCB-fab houses.
Not sure about everyone else but my J12 has scratched out part numbers. Why on earth would the supplier go through the extra work to do that, other than to hide the identity of the part or BIN used?... and why would they want to hide that in the first place? It would certainly help explain why some of you are pulling upwards of 50-55W from two cells, benkie in particular pulls a typical 27W from 3 cells.
Most flash lights have scratched of part numbers, i think we have diffrent drivers and yours was a bad example as it has had moisture, discoloration and spring issues.
Did I? Sorry if you were joking about it being under the rated specs or something else? Maybe I did miss it.
Just these other posts seem to back up what you said in the latest one too.. I just wanted to point out that the 7.5a regulation does not refer to what you should measure at the tailcap. It is the output current and so correlates to around 3 amp tailcap current on two cells.
The Tr-1200 is digitally regulated at 2 amps and will pull this on 2 x 18650,s at the tail cap. The tr-3t6 is digitally regulated at 3 amps and will pull this on 2 x 18650,s at the tail cap, i have other multi cell trustfire lights that work in the same way.
So then one could think if the tr-j12 is regulated at 7.5 amps and if it was like the other genuine tr lights it would be 6 or 7 amps on 2 x 18650's but not go over the max 7.5 amp regulation, mine behaves in the same way as the above regulated lights and will not go over 7.5 amp as the volts drop, till it hits low voltage and drops out of regulation and dims and the current draw drops right off.
Cause some sellers claim max out put of 7.5 amps, some claim current of 7.5 amp, others claim 7.5 amp max with no reference, the same seller claim 3 amp for the TR-3T6 and other sellers claim 2 amp max for the TR-1200, so i would not take any of what they say to seriously.
I would not take it as written in the Bible because some Chinese shop says 7.5 amp Maxim out put, even more so when others say 7.5 amps max as its not clear, i have read on here and else where more people are getting readings like me, some are on this forum and have not posted some are on other sites. Either way mines still working well.
The TR-J12 has to be digitally regulated or the amps would just keep climbing up as the voltage drops and the light will burn up like the early skyrays.
I found my fluke today and my cheap multi meter i ordered on line turned up this arvo so i will re test and compare to my results from my first post over the weekend so i will have 3 digital multi meters to compare to.
