First, is it the correct size for you? It’s very frustrating trying to buy a used bike from someone who doesn’t even know that frames come in different sizes, but that’s how I know a lot of people think the only size a bike has is the wheel size. If this one doesn’t fit you, get rid of it.
That’s a pretty hard-core mountain bike. At that age, you might want to have a mechanic look it over before you get too far from home with it.
I don’t know about rear shocks, but Answer products doesn’t supply parts for some of their forks just a little older than that one. That fork is probably a coil spring with oil damping. Oil rebound dampers require regular service, and the seals don’t last long, even in storage.
Looks like you can still get parts for the rear shock, and those seals will probably need replacing, also.
Klein made good frames, and this one came from the factory with good components. But it looks like this one has Grip Shift shifters. That’s a very controversial subject, but I hate them. Since the photo isn’t the component side, I can’t tell if they swapped anything else out.
The original target audience for this bike was mountain bikers with an emphasis on fast, technical downhill. Even if you’re not in that group, if you can get it in good running order without too much expense, it’s still a much better bike for almost anything than any department store bike.
How much you can sell it for will be highly dependent on the modifications made to it, and the condition. Check the Blue Book, but if it’s in “Very Good” shape, you might get $300 if you’re lucky.
Something no one has mentioned is that the bike uses 26in wheels and cantilever brakes. The industry standards changed years ago to what they call 29in wheels and disc brakes. I’m afraid most avid bikers would not be interested in this bike as it would be considered obsolete by most. From what I understand quality 26in tires and tubes are getting hard to find. If you keep it that shouldn’t matter as unless you ride it often or long distances a set of tire will probably last years.
If you decide to sell I’d initially ask around $500. Klein’s haven’t been made since 2009 but still have a small following and you might get a guy who’d buy it out of nostalgia.
A collector wouldn’t be interested in this bike for several reasons.
I still mountain bike often and have a 29" wheel hard tail/ crows country Felt 960 with about $1800 in parts on it.
the industry standard WAS 29" when I bought mine in 2017, it's much more of a standard to have a 27.5" bike now, although 29" is still,popular. 26" is still very popular too with the downhill and stunt community of mountain bikers. I still have a 20year old jamis 26"bike.
OP-
id keep the KLein, they made great bikes. Your parts are outdated but the frame isn't. Biggest things to try and update are drivetrain and BRAKES. especially BRAKES.
have fun on it and if you like it, ride it! Upgrade parts (if you can) as hints BRAKE. The bicycle community is fill with a bunch of snobs like any community. People will always disagree, but just like here. If you enjoy your $20 Convoy triple, don't throw it out for a d4v2 lol..
Thanks again all.
Looks like I have me some learning to do to see if it’s in ride-able shape. I have a buddy who is an ex-racer. If I can convince him to leave his hiddy-hole down in Alpine. To take a look at it.
There is a really nice bike shop here in town but I want to put as little extra money into this as possible until I figure out if starting to ride again after all these years is in the cards for me.
It does have grip shifters. And I believe all the gear is OEM.
I’ll know more after I get it home tomorrow.
I should have asked this before I put in my bid. But the moment overcame me.
Always nice to find such knowledgeable and helpful folks at the BLF.
A further question. It has the little clippie looking pedals that obviously are made for specialty bike shoes.
I’ll need to change those out to something that works with normal street shoes.
Trying to stay on the cheap side.
Recommendations?
I have a pair of these on my hybrid, use them as a guide, there are cheaper options. Pedals One thing I can stress to you is sizing the bike. You haven’t said what size the bike is, nor what size you are. If you and the bike aren’t a fit don’t drop a penny on it, flip it and move on.
I’m kinda large 6’3”, 33” inseam.
Don’t know what size the bike is.
I didn’t even think about fit until after I pressed the button. Actually I apparently didn’t think all that much……
Frame size is measured from the crank axle center to the top of the seat tube (I believe).
About what size would be correct in a Mtn. Bike frame?
Thanks,
Jeff
Good info here. I might add that that if it doesn’t fit don’t waste money trying to MAKE it fit, (changing stem,handlebars, raising the seat etc) it never works.
you might make it work with just one kludge but not 2 or 3
one of my kleins [the fanciest, the quantum race pro] is slightly too small
but it came with a ‘setback seat post’
now it’s like goldilocks oatmeal
just right
plus all dura ace!
$475
it;s a 2001
worlds most expensive paint, also
i think they called the color ‘plum crazy’
purple metallic fade into midnight blue
It was either made in 2001 or 2002 and since there were different rims and different brands of rear shock used for each year that should allow you to decide which. MSRP was either $1,750 for the 2001 or $1,500 for 2002. Lots of people look with a bunch of skepticism at the suggested prices they come up with, especially these days with new bikes being so hard to find. A 20 year old MTB can be a great bike if properly cared for and stored over the years. I own two of them. It’s a good idea to inspect the tires for age related deterioration and replace the brake pads if they are hardened with age. New pads stop a lot better than brittle ones. The fastest way to make this bike way too expensive is to take it to a bike shop. You can find videos on how to maintain bikes yourself with very few specialized tools. Don’t put any money into it if you will resell it, just clean and polish it if needed.
If you are 6’ 3” tall the likelihood of this bike fitting you is not great. Using a really long seatpost is a bad idea to make if fit as the frame geometry will be off. I’m at the other end of the height scale for humans and bought a couple of bikes at police auctions where you could look at them from a distance but not up close. It was a real crap shoot and most times did not work out. The bikes were great for the price but weren’t a good fit for my height.
If you want other peoples opinions on how much it is worth, check out this site
Classic and Vintage Bicycles: Whats it Worth? Appraisals. Classic and Vintage Bicycles: Whats it Worth? Appraisals. - Bike Forums It’s free to join and you can’t post a picture until you have 10 posts but there are pictures at the bicyclebluebook website you can have people look at.
