So, is this light regulated on 4x ni-mh/alkaline C-cells? That would add an extra useful battery choice if it is.
informative thread thanks!!
I wonder why shopbot and benkie are pulling 42-55W at 8.4V, while it seems EVERYONE else is only at 30-35W? Sample to sample variation perhaps? I would think 8.4V is still too high for low voltage protection to be kicking in??
Hi Kramer,
Its pretty weird man. When I test the 2x18650 configuration, the reading fluctuates ALOT. There was like a range of up to 2A. I cannot pinpoint a good average whereas for all other configurations, I can get a nice somewhat consistent reading. Don't really know. Mind you my DMM was a $15 eBay one, so take it for what its worth.
I forget the current measurements, but I calculated the power at about 28 watts for any battery configuration (2 or 3 18650 and 2 26650). I only have 4 26650s, 2 of which are IMR, and two LiFePo4, so I don't want to mix chemistries/voltages to try 3 26650s.
About 4 days after I received the tr-j12, the spring behind the battery contact in the head either broke or dislodged, and now I have to use magnets as spacers for either 18650 or 26650.
Anyone know how to remove the pill from the head with breaking anything? It seems that the head is press-fit into place.
Most likely melted the spring. Mine did that, in the 26650 thread...
https://budgetlightforum.com/t/-/8886
If yours is like mine, there really is no "pill". The driver "engine compartment" comes apart, unscrews and separates the LED+reflector half from the DC-DC driver half. A pair of long wires deliver power from one section to the next. See my pics in the linked thread. The DC-DC board is pressed into the aluminum and a brass collar is threaded over it to lock it into place.
I gently stretched the spring back out and used copper braid to releve the spring of some of the current flow.
Welcome to the club, CME!
Mine doesnt have a spring at the head. It does have a spring with a cover on top. I get 3.85 V with two 26650's
Definitely viffer750 is right.
The input voltage is not higher than what 5 LEDs need and If the driver is regulated it has to boost the amps to maintain the brightness of all those 5 LEDs the multimeter+ leads will act as a voltage drop, showing high current draws, as it's already boosting the voltage. It doesn't matter matter how good the DMM (reg.Fluke) all have some burden voltage that will affect the reading in series with the flashlight on boosting circuits.
Thank-you. Glad to be here.
That is extremely helpful Kramer, thank-you very much. I didn't know that the head/heatsink was 2 pieces, though I had my suspicions.
Since I didn't hear anything rattling inside the button, de-tempering of the spring makes perfect sense. Guess I will add a new spring with copper braid (I think I have some old RG-58 floating around - the shield would probably work well for that). I might see if I can retain the button spring cover as well. I will try to post pics and measurements once I get everything all fixed. Once I get repairs done, I may get one of the tr-j10's and see if I can properly drive the led - they look like they could be good throwers.
Anyway, I am really impressed with the output from this light, as well as the seemingly good thermal transfer to the air. I would love to see real measurements of the output using a true integrating sphere. The folks in Asia always pad all their numbers to make their products look better in advertisements.
It also seems, from looking at the performance curves from Cree, that the individual leds in this light are driven nearer the most efficient part of the curves than typical single-led lights. My only real complaint (other than the poorly-chosen spring design) is the fact that this light is very top-heavy - makes it cumbersome to hold and maneuver.
So everyone knows, I am an old-school flashlight modder, back from the days when xenon and halogen were the cutting-edge technology. Since Cree, SSC, Luninus, etc., have gotten the efficiency so high on leds, I can see no purpose for those old tungsten relics, except as museum pieces.
With Kramer5150's help, I figured out how to get everything apart in the head of the TR-J12. Same problem - spring was de-tempered and squashed. I will also use his fix - adding a piece of braided copper to assist current flow. I suspect, however, that the contact between the spring and the button is creating a high impedance failure point (maybe even arcing?), which may be contributing more to heating than anything. Also suspect is the cheap plating on the spring. I will try to dig up some conductive grease or epoxy so that the spring and cap make better contact.
Thanks again guys
So if anyone else purchases this light, prior to use, some braided wire should be installed at both ends and perhaps this failure may not happen?? Thanks.
Sure np... if you are familiar with incan mods, the wire braid is the same thing. Current is current, wattage is wattage, be it LED or incan.
It should be noted that time duration is also a factor. If you only use it for short burst only, then you may not really need to add the wire braid. Mine only melted after leaving it on for 10-15 minutes to intentionally get it cooking, to let some moisture vent out of the head.
The 7.5a manufacturer rating is current output to be split between all 5 LEDs. That equates to around 24 watts with XM-L vf. Yours, pulling 6.8 amps at the tail, is at around 55 watts and if the driver is letting all that to the LEDs will be at a current output of around 18 amps! Well over the rated 7.5.
I am starting to wonder if we have different driver board components. I am wondering if the SMT components in our lights are all identical... or if the supplier populated the boards with close-compatible parts, and scratches out the part numbers. Threads like the one below make me wonder about the manufacturing process quality of the PCB-fab houses.
https://budgetlightforum.com/t/-/8945
Not sure about everyone else but my J12 has scratched out part numbers. Why on earth would the supplier go through the extra work to do that, other than to hide the identity of the part or BIN used?... and why would they want to hide that in the first place? It would certainly help explain why some of you are pulling upwards of 50-55W from two cells, benkie in particular pulls a typical 27W from 3 cells.
You missed the point.
Most flash lights have scratched of part numbers, i think we have diffrent drivers and yours was a bad example as it has had moisture, discoloration and spring issues.
Did I? Sorry if you were joking about it being under the rated specs or something else? Maybe I did miss it.
I tested it with good fully charged cells, i never do tail caps with any thing else. 6.5 amps is still under the 7.5 amp digital regulation. I have not been able to find my fluke since i moved house in last December, so i have brought another DMM it should be here next week.
So then one could think this about the tr-j12, since the manufacture has claimed it is regulated at 7.5 amps it would be on two cell's as the light does not work well on one cell it run is dim mode and if it was like the other tr lights i have the manufacture claimed regulation would be on 2 x 18650's.
Just these other posts seem to back up what you said in the latest one too.. I just wanted to point out that the 7.5a regulation does not refer to what you should measure at the tailcap. It is the output current and so correlates to around 3 amp tailcap current on two cells.
The Tr-1200 is digitally regulated at 2 amps and will pull this on 2 x 18650,s at the tail cap. The tr-3t6 is digitally regulated at 3 amps and will pull this on 2 x 18650,s at the tail cap, i have other multi cell trustfire lights that work in the same way.
So then one could think if the tr-j12 is regulated at 7.5 amps and if it was like the other genuine tr lights it would be 6 or 7 amps on 2 x 18650's but not go over the max 7.5 amp regulation, mine behaves in the same way as the above regulated lights and will not go over 7.5 amp as the volts drop, till it hits low voltage and drops out of regulation and dims and the current draw drops right off.
Cause some sellers claim max out put of 7.5 amps, some claim current of 7.5 amp, others claim 7.5 amp max with no reference, the same seller claim 3 amp for the TR-3T6 and other sellers claim 2 amp max for the TR-1200, so i would not take any of what they say to seriously.
I would not take it as written in the Bible because some Chinese shop says 7.5 amp Maxim out put, even more so when others say 7.5 amps max as its not clear, i have read on here and else where more people are getting readings like me, some are on this forum and have not posted some are on other sites. Either way mines still working well.
The TR-J12 has to be digitally regulated or the amps would just keep climbing up as the voltage drops and the light will burn up like the early skyrays.
I found my fluke today and my cheap multi meter i ordered on line turned up this arvo so i will re test and compare to my results from my first post over the weekend so i will have 3 digital multi meters to compare to.
Yeah now that I got mine dialed in its running great. Spring issues have been resolved although I still might buy some higher current springs at a later date per Eriks suggestion, and the moisture is definitely gone now too.
You mentioned earlier your meter probe wires are getting hot. Thats something I have never encountered. I am not sure if or how that can throw off your tailcap measurements, but measurement inaccuracy I think still might be something to keep in mind.
I'm kind of curious, at 55W / 8.4V, wheres the extra power going if you are able to run your light for ~20 minutes straight? Lets assume driver efficiency around 80%, which is typical for most FET driven non-7135 circuits. With 5 emitters your light should be doing 8.8W per XML. Estimating Vf at 3.4V, your light should be pushing each LED with 2.6A. That equates to 800Lumens per LED (and a TON of heat). Your J12 should be in the 4000 lumen ballpark, it should also be SMOKING-scorching hot within a minute or two. I mean my J12 pulls around 28W, factoring in an 80% efficient driver that equates to a very modest ~1.35A into each LED. Even at that low current it gets very warm (borderline hot) after a few minutes.
If your light is not doing 800 Lumens per LED (full charged cells), then a lot of those 55W are being lost somewhere in the the driver, switch or contact springs. Something in that light should be getting really hot. I would think its borderline thermally unstable at the end of a 20 minute run with panasonic NCR cells. Panasonics are KILLER cells, so I think we can rule out V-sag under load.
puzzling... something is not adding up in my mind.
