code valid start from 23th, Aug
There’s a spending min for B284EVPED9J9
It doesn’t work if you only added one HS05. You need to add two.
Story, you are right. I ended up buying one HS05 and one SC21 in order to make use of the 20% discount code.
~ $38 shipped for two HS05. It’s a really great flashlight / headlamps. I especially enjoyed the AA compatibility. This comes with a magnet, clip, headband, battery and charger (up to 21700 size) at this price.
Hello Jackie and thanks for the sale. I already have a number of nice Sofirn flashlights so good for now. What I would like to buy from you is a Uv dive light, which Sofirn doesn’t make. Why not take one of your existing dive lights and make it a Uv? Currently, other brands start at around $100 us, and go up from there. Way up. A Uv dive light near $50 would sell well I think. Modify one of those SD02’s and I’ll try it out for you.
Two hs05 and two sc21 later, i feel the buyer’s remorse .
I wanted to buy the HS05 with the 20% coupon, but now I have to buy 2 to get the deal? That’s not a deal anymore.
updated code :46353CFMTRVP
it sounds good, there is one model DL07 with UV light and for diving, may i ask what is the use of a UV light underwater?
New code works. Thank you very much!
HS05, SC21 20% code update :46353CFMTRVP
https://www.aliexpress.com/item/1005002780636018.html?spm=a2g0o.store_pc…
Jackie. Thank you for the link. In the ocean some corals and fish have fluorescent qualities which show up at night. When shining a Uv dive light on them they will light up with color and brightness, while everything else remains darker, much like the yen note in the advertisement. It would be interesting to see what effect a red light has on coral. Never seen it myself but it might be fun. The Wurkkos with three different lights is a great idea, provided the beams are bright enough for diving. In terms of underwater Uv, it would be interesting to see the difference between 395 and 365nm.
The Last day of deal
Ordered two SC21 mini, great deal even after the EU tax change. Thank you!
New release Sofirn HS20 Headlamp 15% code 7KMTTNKVB659
Seems like a very good light! Type C charging, separate buttons for spot/flood, nice!
Ordered. Thank you!
Code didn’t work for me
code update on page 1MY7001VGT2Y
