Thank you for your feedback. The memory function is already a regular function, so we didn’t write it out specifically, but it will be shown in the manual.
Looks like a nifty edc keychain light. I do have a UI question that I think hasn’t been asked yet. How does one access the strobe mode? Is it “hidden”, or always reachable when clicking thru the other modes (ie, L-M-H-STROBE-L-M-H-…)?
I would definitely support getting rid of the mode memory. Keychain lights are for occasional use and there is no way I’m going to remember what mode I left it in last time I used it. L-M-H is right for this. I would get rid of the strobe too.
If you’re ok with telling us, what size battery does this use? I just spent a while on aliexpress looking for possible replacement cells and didn’t find anything with 200mh that looked like it would fit in there.
Hi, Forsyth. Normally it is in L-M-H mode. This is the built-in battery. You cannot replace the battery unless you take it apart. The battery has about 500-time charge and discharge circles, which are at least equal to 500* AAA batteries. I think there is no need to replace the battery. If there is something wrong with the battery and charge, you can require after-sale services.
Yes, I understand that. This is an enthusiast forum and taking lights apart is what we do around here . Do you have a photo of the battery if you don’t know the exact size? Thanks.
Thanks! Are you sure of the number 722018? I wasn’t able to find replacements with a web search, which is a little unusual, and I’m wondering how you fit it into the light given the light’s 20mm diameter. A photo of the inside would be interesting!
