How do you know this?
It seems weird and I'm curious.
The older SC62 had a buck-boost driver which was always a solid selling-point compared to most other compact 1000lm lights if one likes to use high-mode.
Just a small note, the green ring at the edge of the H503c’s beam is due to the GITD surface around the LED rather than tint shift from the emitter intself.
Today I received a SC64c LE from NKON, ordered just a few days ago. It definitely has a high CRI emitter mounted, color reproduction looks similar to other high CRI lights (Zebralight H600Fc, Armytek Wizard Pro Nichia 144AR, Acebeam H40 with SST-20). But my H503c which I ordered from NKON in April this year seems to have a much less vivid color rendition. So maybe it also has a low CRI emitter mounted like in some of your units. Comparison of the phosphor color is not so easy between those two very different headlights, at least for my naked, untrained eye… I contacted NKON what to do about it (exchange under warranty?).
The SC64c LE has the modified anode contact (6 small contact points).
Thanks for providing this information. I have to study the pros and cons of having a dedicated display in the measurement device vs. instruments like the X-Rite i1 Pro. I also haven’t found a distributor for the Hopoocolor OHSP350C for Germany/EU. German customs adds about 25% fee on items coming directly from China…
I received a LE from Nkon :
CCT = 4147K (Duv 0.0032)
(Ra) = 91.3 [ R9 = 70.9 ]
Not too bad How do you like it??
Was going to say, don’t post this thread over at reddit, or the hiveminds will lose their minds.
@ peter_b
Have you considered the Opple Light-master-III. It is much cheaper (around 40 €) compared to something like the X-Rite. It is of course most likely not as good as a professional solution, but it seems decent enough for hobby usage. There is a wohle thread about the Opple over at TLF > Link.
thanks for making me aware of that option
Im interested in buying one in USA
anybody have a link?
I found a link in Europe, but shipping is $50
I finally received my replacement SC64c LE and H503c from Zebralight.
They didn’t include a note or anything, just two brand new lights in their original packaging.
I’ve verified that both lights have the correct high CRI LH351D. The SC64c LE has the new style battery cathode contact.
I also noticed there’s some schmoo on one side of the H503’s emitter. It’s probably some excess thermal paste or potting compound. It’s probably not an issue since this is a AA light and the emitter won’t run high enough power to burn the dome. It’s a mule so it won’t affect the beam either.
Sounds like their QC is slacking.
Thanks for your suggestion and the link. The little Opple Light Master G3 unfortunately doesn’t measure R9…
I found an upgraded version called ‘Opple Light Master Pro’ (hardware, not the app!). This gadget received the IF Design Award 2020 for good design, see https://ifworlddesignguide.com/entry/282367-lightmaster-pro
I can’t find any retailer selling this improved version yet. Here is a picture from the IF World Design Guidewebsite showing the measured data (incl. R9!):
I finally got access to a C-7000 SpectroMaster. I measured the SC64c LE that I received from NKON few days ago, and my H503c from April this year (also NKON).
SC64c LE looks good (CCT=4057K, Duv=0.0034, Ra=93.5, R9=76.0), my H503c definitely has a low CRI Samsung LED (CCT=4227K, Duv=-0.0067, Ra=74.2, R9=-28.2)
This is very strange because If it isn’t able to measure R9 then it shouldn’t be able to measure CRI at all.
Try contacting Zebralight for an RMA. It took about eight weeks but they replaced mine without any fuss.
CRI (Ra) is actually just the mean of R1-R8.
You are located in the U.S., did you send your lights to Zebralight USA or to China? I will first try to solve things through NKON as their European dealers, otherwise I might have to pay again customs and import fees for the replacement…
I sent my lights to Zebralight in the USA. If NKON can take care of you without extra fees, that’s probably the best option.
It’s not that it can’t measure R9, the app is just extremely limited in what data it displays because the manufacturer intended to sell a more fully featured version for a higher price. You get lux, CCT, CRI Ra, CIE coordinates and uv, as well as a postage stamp CIE 1931 chart. It doesn’t show R9 or Duv (which you can obviously calculate). Also based on results posted on TLF the lux and CCT measurement is fairly inaccurate for warmer CCTs. There isn’t a comparison of measured Duv with a known good device. I would say it’s ok for telling whether you have a CRI 70, 80, or 90 light as well as approximating the CCT above 3500-4000K. If it can give a reasonable approximation of Duv too it’s probably a useful device for the money, though not that great.
It was good ol’ product segmentation of course.
