Sometimes ya’ get the good nurse – Sometimes ya’ don’t.
So here are some pics of my rear derailleur…
This is how mine is threaded. Taken from the opposite side from the cassette so you can see the path better.
The chain is surrounded on four sides by the derailleur wheel, the two arms that make up the derailleur, and the tab that is a bent hunk of metal that is part of the derailleur arms.
There is no way that I can see to get the chain on the other side of the tab without breaking the chain or dissembling the derailleur.
Breaking the chain is way easier/safer for a duffer like me. Besides it will give me the opportunity to clean that sucker.
Mine
Here is a capture from a Park video showing the correct way to thread the derailleur arm.
Correct
Thanks for all the info and links!
All the Best,
Jeff
Some bikes have a single arm on the shifter. Easy to remove and reposition the chain.
My chain is surrounded on 4 sides. It is not possible to get the chain in the current location without threading it through there in the first place.
Here is another shot from the back side. You can’t see the problem from the front.
The chain is supposed to go above the tab so that it rides on the wheel not the tab.
Easy to do it wrong if not paying attention when installing the chain.
See that tab by the red arrow?
The chain must go on one side or the other.
On one side, the chain rubs on the tab.
On the other side it does not.
The chain goes around the cassette.
Over the first wheel.
Then on my bike - there is a tab in between the two derailleur wheels.
The chain must pass on one side or the other.
Take a look at the pic below. The correct way has the chain passing on the left side of the tab.
The chain does not rub on the tab.
The incorrect way has the chain passing on the right side of the tab.
The chain rubs on the tab.
See this video at 4:53 to see the chain routed and the tab of which I speak.
Not real easy to get a better pic in there.
After I get it corrected I’ll post a new pic.
All the Best,
Jeff
Yeah, I’m a bit spooked by this too. Didn’t notice it till I got it home.
I hope what happened was the chain broke (or?) and the bike got put up. Then new tires got installed (look nearly new to me) and the chain got put on incorrectly.
I’ll know more after I get feeling better (takes a day or two) and get the chain off there.
Thanks for the SRAM suggestion
Just looked. The current chain is marked: PC 951 and it has a magic link so it will be easy to remove.
wfe - are most chains basically the same as far as using them on a bike like mine?
Obviously I don’t need anything fancy.
The SRAM at $22 seems like a good deal to me. I’ll count the links/measure after I get it off the bike. https://www.amazon.com/SRAM-9-Speed-Bicycle-PowerLink-Connector/dp/B07XYG3M38
Just loosen that socket head cap screw that is holding the arm to the upper pulley wheel and loosen the cap screw in the idler pulley, then the arm can be moved to let the chain ride in the correct position, then reinstall the arm and tighten the screws. No chain break required.
You are correct that the chain is not threaded correctly. It should be inside the derailleur cage, not riding on the tab. If you are lucky, there will be a master link that you can open. That’s a lot easier with an $9 master link tool https://www.ebay.com/itm/353565699003 but if you remove the tension on the chain as shown at 1:09 in this video it is easier. Bicycle Chain Master Links: Tips & Tricks KMC Shimano SRAM - YouTube If your chain has no master link, then you need a chain tool for opening one of the pins or simply cut it if you are going to replace it.
The alternative is to unscrew the bolts that hold the jockey wheels in place, re-rout the chain, and reinstall the bolts. This is a bit difficult because it is tough to deal with loose parts and the chain. A new chain will make it a lot easier. The KMC chain with a master link is the OEM chain on a lot of bikes.
You can get a good price on eBay compared to going to your local bike shop. Just count the number of gears on the cassette and select the right chain.
KMC X8.93 6,7,8 speed chain $13 postpaid https://www.ebay.com/itm/284426075943
KMC X9.93 9 speed chain $19 postpaid https://www.ebay.com/itm/393386368206
Not mine! Tried everything except Devine intervention.
Almost got it when my snap ring pliers gave up the ghost.
That sucker is really on there.
Think master link pliers is my only hope.
All the Best,
Jeff
Just thought I’d update.
Got in a Park Master Link tool.
8 seconds later the Master Link is out with no damage.
Wow is this chain in need of a clean and lube. It’s so gummed up with old lube it will almost stand up on it’s own.
Thanks everyone for all the help!
All the Best,
Jeff
Kennybobby (post #47 above) has the exact best solution to this problem. No chain break required. Seriously. Take it to a bike shop. They could fix this for you in about 30 seconds.
Doesn’t matter, post 53 it was done in 8 seconds, plus he gets to dip the whole chain in a bucket of kerosene.
After the dip and wipe down with old newspapers, he can soak it in a can of oil; another wipe down and get the excess oil off and it will be the best lubed chain on the block.
I once bought a bike off auction. A really nice Specialized one. I had checked for maximum seat height, but… had neglected the seat post to front post distance. It was really too short. I could ride it, albeit hunched over, but when I had someone photograph me and a buddy with his bike that fit him properly, I looked like a giant on a circus bike. I hope your sizing is good. If you plan to ride much, you really want that part right. You may want to take it to a bike shop to get it properly serviced, and while there make sure a tech can verify it’s a good fit for you.
