ASTROLUX® ST01
SST40/XHP50.2 3500lm Compact EDC 21700
4 Modes Basic UI USB Rechargeable Flashlight Group Buy
For reference, this is my order timeline for our Group Buy.
Note: speed of delivery varies from country to country.
Group Buy Price: from $23.99 (usual $35.95)
Freeme's Exclusive Coupon: Request in this thread
Can't wait for our reply??
Price: from $25.99 (usual $35.95)
Coupon: BG8520
Specification:
Brand |
Astrolux® |
Model |
ST01 |
Material |
Aluminum alloy |
LED |
XHP50.2, SST40 |
Glass |
Tempered coated glass |
Driver |
High efficiency direct driver |
Lumens |
3500lm |
Intensity |
25281cd |
Max distance |
318m |
Waterproof |
IPX6 |
Impact resistance |
1m |
Size |
130x27.5x27mm (length x head diameter x body diameter) |
Battery |
1 x 21700 battery (not included) |
Modes | High(1200lm >12h) - Mid(450lm 6.5h)-Low(20lm 5h) - Turbo(3500lm 4h) |
Max range | 318m |
Operating Instructions:
Clicks |
Off |
On |
1 click |
Memory mode (low by default, the mode will be memorized after staying at this mode for over 2s) |
Mode 1 : Low-mid-high-turbo Mode 2: Low-high-turbo-strobe-SOS |
Press&hold |
Close | Close |
2 clicks |
Strobe |
Turbo |
3 clicks |
Mode change (1-2) |
Mode change (1-2) |
4 clicks |
Voltage check |
No response |
5 clicks |
Lockout: unlock Unlock: lockout |
Lockout: Unlock Unlock: Lockout |
6 clicks |
Momentary mode (physical power off to exit) |
No response |
Note:
- It will active temperature control function and step down when the temperature is over set point.
- Low voltage protection, green LED will flash as a reminder.
- Over-discharge protection.
Features:
- XHP50.2/SST40 6500k/5000k super bright LED.
- 318m max beam distance.
- 3500lm max output, 4 modes adjustable.
- Compatible with 21700 battery, type-C charging.
- IPX6 waterproof.
Package included:
1 x Astrolux® ST01 LED Flashlight
1 x Clip
1 x Lanyard
1 x Manual
2 x O-ring
Images:
