Impulsive as I am I just ordered one black/5000K. The stud instead of a spring with the short tail spring may cause some crushing on longer cells. I know driver area is limited and this method gives a little extra. Tail spring needs to reflect this as a bit longer. I have three other lights that have crushed the tops of cells. Haikelite HK4S was so bad I had to grind down the stud 4 mm’s just for unprotected cells.
The 4000k in the S11 is so darn nice. It really does compare very well to the 219B sw-4500k. My S11 seems to be a bit more rosy than the one shown above… But, that could just be the recording.
Could we perhaps come up with a different config list of mode groups for Convoy’s 12 group firmware, most of it is groups no one would use.
I’d especially love that 50% level in with the 100, sure it may not be a big visual difference, but it allows for longer runtime and longer bursts than 100
Also each blink in config represents each group, it’s way too slow as it is currently
How I would love a group where the low, med, high could be configured by the user. Like a ramping menu to set the brightness.
