With standard switch (without lighting) the old driver works well. Change the switch it’s very easy, only need a tweezers.
Just saw this on FB:
Convoy M21E 21700 flashlight ,type-c charging port,XHP70.2
Beautiful design!
Super stunning!
I can’t wait to get my hands on it!
i see the driver area (around the button and charging port) is the same as astrolux FT03 or Mateminco.
Impulsive as I am I just ordered one black/5000K. The stud instead of a spring with the short tail spring may cause some crushing on longer cells. I know driver area is limited and this method gives a little extra. Tail spring needs to reflect this as a bit longer. I have three other lights that have crushed the tops of cells. Haikelite HK4S was so bad I had to grind down the stud 4 mm’s just for unprotected cells.
The 4000k in the S11 is so darn nice. It really does compare very well to the 219B sw-4500k. My S11 seems to be a bit more rosy than the one shown above… But, that could just be the recording.
Pioneman K45-C…
I like the Pioneman K35 design. There are using Convoy drivers. Are we expecting a similar Pioneman K35 host with Convoy Name S???
Hmmm… Pioneman related to Convoy?
So are there any differences between the reflector in the M21C/D to the M21E?
Probably, the E looks like a C8 size head,44-45mm while c and d are 55mm
New convoy T3 !{width:70%}https://i.imgur.com/d3DKRJY.jpg! It is listed as a pre order at $999 with no specs “here”:11.6€ 30% OFF|Convoy T3 taschenlampe, hohe CRI, AA 14500 taschenlampe, XPG2 219B 219C LH351D 519A 13 gruppen|Taschenlampen| - AliExpress There is also a “s12”:30.43€ |Convoy S12 mit IR LED, infrarot 850nm 940nm|Taschenlampen| - AliExpress and a “s2+”:10.81€ 32% OFF|Convoy S2 + mit IR LED, infrarot 850nm 940nm 18650 taschenlampe|Taschenlampen| - AliExpress with IR emitters.
posted on facebook: Convoy T3, similar to T2 with 12 groups driver for AA/14500 battery
I hope it is a floodier/wider angle reflector than the one in the M21C, but we will have to see.
2021/8/6
Holy cow, that tint (DUV = –0.005) is amazing! The best 3535 3000k emitter I’ve seen to date!
Just saw this on FB: Convoy M21E 21700 flashlight ,type-c charging port,XHP70.2 30.19€ 13% OFF|Convoy M21E 21700 taschenlampe, typ c lade port,XHP 70,2 SST70 XHP 70,3 HALLO|Taschenlampen| - AliExpress !https://i.imgur.com/iMv8Ak2.png! !https://i.imgur.com/o39bTMD.png!
thank you for sharing this! What a absolutely beautiful design! Ordering now!
How do you put in for the t3 preorder? Why is $999 ??
That is just a placeholder. When they are ready Simon will let us know.
We’re gonna need the info on that T3. Is that using the new 17mm 12 group AA/14500 driver?
Could we perhaps come up with a different config list of mode groups for Convoy’s 12 group firmware, most of it is groups no one would use.
I’d especially love that 50% level in with the 100, sure it may not be a big visual difference, but it allows for longer runtime and longer bursts than 100
Also each blink in config represents each group, it’s way too slow as it is currently
How I would love a group where the low, med, high could be configured by the user. Like a ramping menu to set the brightness.
For this new T2 driver I’d like to keep a real 0.1% mode (sometimes it seems bit higher in my S2 + driver)which is useful indoors and close spaces
