S2+ xhp50.2
18 posts / 0 new
axo65
S2+ xhp50.2
I have a question
I built a convoy s2+ with xhp 50.2 3v with convoy sst40 4 mod driver 5000Ma
How can i increase current on led can i do that with modification r sense resistor
Edited by: axo65 on 08/25/2021 - 07:18
PeyoX
PeyoX's picture
Last seen: 7 hours 2 min ago
If you want to double the current (theoretically), you can stack another same value resistor on top of the stock R sense resistor.
Limited English, still working on it.
axo65
Is 10A to much for xhp 50.2
Geuzzz
Geuzzz's picture
Last seen: 4 hours 23 min ago
texas shooter
Last seen: 3 hours 36 min ago
On a 3 volt XHP50.2 no, but for the 76 gram host yes. S2+ at 76 grams isn’t a host that’ll take 10 amps. 5 amps is probably max.
mattlward
mattlward's picture
Last seen: 1 hour 38 min ago
Agreed, that host is not built for that kind of current or the heat generated by it. I would call that good and it still is a monster pocket rocket!
EDC rotation:
FW1A, LH351D 4000k (second favorite)
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
axo65
Now ist running on 5 amp and is damm bright
Stock R sense is R020
I think i will try to put R015 instead
texas shooter
axo65 wrote:
Now ist running on 5 amp and is damm bright Stock R sense is R020 I think i will try to put R015 instead
Welcome to the club. Slightly larger/heavier version. https://www.aliexpress.com/item/33011209997.html
Tomogchi
Last seen: 10 hours 23 min ago
ive built quite a few s2+ with xhp50.2 now. Sure it gets unbearable to hold in no time flat… but man, it starts things on fire – instantly. Want to light a cigarette or cigar or even a dutch? absolutely! just as quickly as youd light it with a lighter too… will it last long? long enough to end up as daily carry…. havent replaced much other then lenses and switches..
my thing is, its not the flashlight that cant handle it. its the switch.
At the point it gets really close to desoldering / going nuclear, the switch has melted before any real damage can happen… think of it like a fuse lol. But not many switches this size handle high current (even omptens). 5 amps sure. 15 amps well… how long is the question…
specs:
Convoy s2+ host w/Orange peel reflector
Xhp50.2 5400k 3bo
Mtn fet+7135 driver
blue sword special beryl springs bypassed..
https://imgur.com/a/P322v1T
getting really crazy, i kept trying to modify a 5050 triple series pcb to be parallel (couldnt find one), and put 3 xhp50.2s on it. got one to finally work but it cant even run for 30 seconds before it goes nuclear…. THAT really is too much for a little s2 .
ill leave you with something to think about it. flashlights turbo to an unsustainable level for what, 30? 45 seconds? then drop to half if not less. if you treat an s2 xhp50.2 in the same fashion, you should never have a problem. YOU are the turbo timer
It all started with just one flashlight.
ArturoSC1
Last seen: 4 days 14 hours ago
What about D4 and similar……?
zoulas
zoulas's picture
Last seen: 1 hour 19 sec ago
I bet you can use that to light a cigar. Just wear dark sunglasses when doing it.
axo65
Now on 5amps i can light thin paper
max
max's picture
Last seen: 1 hour 1 min ago
 max
loshihyen
Last seen: 4 days 6 hours ago
I guess the guy already has a bunch of S2+ and just want to keep the consistency?
max
max's picture
Maybe so, however, I took my S21B (from the link above) and did the sense resistor mod and then measured tail cap amps - it was pulling 8.8 amps and much much brighter. It's now one of my favorite lights. Of course it gets warm quick and then the drivers temperature control kicks in.
But can you imagine what those amps would do in the smaller S2+? It'd burn your hand in about 10 seconds!  I've modded S2's, S2+'s, and S8's up to 6.3 tail cap amps and I would consider that too much.... no matter which LED.  Anything over 5.5 tail cap amps in the S2 size is too much IMHO.
YMMV.
 max
axo65
R020 removed and bypased still same 5a someone knows why
texas shooter
You might just be reaching maximum current flow. Driver resistance, battery resistance, LED resistance, etc micro resistance everywhere. Time for a spring by pass and the best high current battery topped off to see if it goes just a little higher. On the driver PCB trace thickness is getting to be a factor with high current low voltage.
axo65
Spring is by passed baterry is samsung Q30
