Hi does this have Anduril 2.0? I just received mine. Clicking and hold 10c doesn’t change anything.
My link Aliexpress
My USB-C to Lightning cable doesn’t work with it.
My link Aliexpress
Hi,
Have you had any updates?
I was trying to get more information about this light before I bought it and I wasn’t sure what you were saying lately, other than the situation is not clear to you either.
Did Sofirn make any changes in the led power supply that make the LT1 hotter? If so that’s a bit sad.
You mentioned the button leds, are there any plans to change that in the near future?
Does anyone have the footprint of the new flashing pads so I can try to make a connector to flash the firmware?
In general, should I take advantage of the small promotions to get it on the Sofirn site or wait for a new version? And if I order on Sofirn’s website, will I get the latest version or is it random?
Thanks for the information if you have any.
Have a nice day.
I ended buying a second LT1 on Aliexpress because I liked the idea of having a USB-C compliant chip and being able to use it as a powerbank in a pinch.
Did some comparisons and made some pictures for you:
I have a USB-C Protocol and power analyzer, will test the new LT1 board later today.
Does anyone know how to differentiate which of the ground (black) cables from the new (with power bank) driver connects to the warm and which to the cold LEDs?
Since the manual PDF file on google is offline, who knows where to find it now?
https://drive.google.com/drive/folders/1HIFCFcBus5XRjKMfgkjAR7nH1R62qp_5
Here’s an Anduril 2 graphic for the LT1:
If you are looking for the original LT1 manual (and other Sofirn manuals), please check here:
I had to redeploy my files on Google Drive because the old links did not work anymore.
If you are looking for the manual of the new LT1 with Andúril 2, I need to ask you for patience. It is work in progress already. I do have a manual that Sofirn made on their own and that is currently being supplied with the new LT1 version. But there is a lot of wrong or missing information in it, it’s not worth putting it onto the sharepoint.
These versions are known:
|version|date|post URL|
|lexel 4.3|19.08.2020|https://budgetlightforum.com/t/-/38215/11664\|
|lexel 5.0|16.12.2020|https://budgetlightforum.com/t/-/38215/11042\|
|lexel 5.1|11.07.2021|https://budgetlightforum.com/t/-/38215/11580\|
|Sofirn 1.0|11.07.2021|https://budgetlightforum.com/t/-/38215/11578\|
|Sofirn A2|11.07.2021|https://budgetlightforum.com/t/-/38215/11595\|
Any more known board versions out there?
And what are the differences?
In a nutshell, is Sofirn A2 the “best” release of the LT1 thus far?
Also, if someone is OK with Anduril 1 and doesn’t intend to leverage the power bank feature, is it preferable to get the earlier version? I’m really concerned about all of these intermediary board changes. And I’m sure with the way things are, you can’t request a sub-version, only the LT1 Anduril-1 or LT2 Anduril-2.
My Sofirn 1.0 LT1 has limited power bank capabilities. It doesn’t work with Apple USB-C to Lightning while the Wurkkos HD20 works with the cable. It’s also on Anduril 1 without version check.
My Sofirn 1.0 LT1 has limited power bank capabilities. It doesn’t work with Apple USB-C to Lightning while the Wurkkos HD20 works with it.
Good to know this. Has anyone found that Sofirn A2 avoids that problem and a USB-C to Apple Lightning will charge an Apple device (iPod, iPad, iPhone, etc.)?
Where is the cheapest to get a Sofirn lt1 these days? I don’t mind getting version 1 without the power bank.
Cheapest would be from Sofirn store. But you have to consider shipping as well:
$52 - https://www.sofirnlight.com/products/brown-lt1-lantern-anduril1-usb-rechargeable-flashlight-without-power-bank-function
$58 - 22.9€ |Sofirn BLF LT1 8 * LH351D Camping Licht Mehrere Bedienung Verfahren Super Helle Taschenlampe Variable Farbe 2700K zu 5000K|LED-Taschenlampen| - AliExpress
$70 - https://www.ebay.com/itm/384253590938
$93 - Amazon.com
Thank you. Ordered the brown one in Sofirn website.
Hi There. I could really do with a little bit of help.
I bought myself an LT1 Anduril 2 in that really wicked on the eyes orange colour.
Anyway, my problem is that my LT1 will not allow me to set a timer in candle mode.
No signal flashes and also no time attributed to the number of button presses.
I now have a new problem called “Anduril 2 Thumb”
@Fruityfrog
Assuming you’re already in advanced UI (not candle mode otherwise): click five times and hold the last one. The light will flash every second, each adding five minutes to the timer.
I got the Sofirn v1.0 and BLF-LT1-A2.
BLF-LT1-A2
- The green power button light is on even when it’s in use. It’s necessary as it’s hard to find the button when you need to turn it off. It’s distracting.
Sofirn v1.0
- The amber light will be dim when it’s on. It’s too dim to be useful when I want to turn off my LT1.
- Power bank doesn’t work with my USB-C to USB adapter for iPhone
- Power bank works with USB-C to USB-C, I can power the SP36
I like the Sofirn v1.0 during standby. I keep this in the corner on a selfie stick with tripod mount. With the button towards the corner, it would reflect a very nice ambience light at night. It’s frankly easier to turn off the LT1 with my index finger when the button is away from me.
I will update it to Anduril 2 and see if the power bank will work for iPhone.
I just ordered an orange LT1, but that green light is making me change my mind.
This chart is incredibly useful.
I ordered a BLF LT1, supposedly the older model. It’s brown anodized. I received it and clicked 15 times. It showed flashes: 2 long, 1 short. That’s Anduril 2.1. OK, this is interesting. EDIT: I’m wrong, this is not Anduril v2. No wonder why I heard laughing from the stage wings… It took ToyKeeper to step up and tap me on the shoulder.
It turns out that I have the 2nd driver example, revision 5.0. My understanding is that this is the LT1 v1, with Anduril 1. I do have USB-C to USB-C, but discovered that it’s one way—to the LT1.
Did all of the rev 5.0 LT1’s end up with Anduril 2? Or was there some slipstream change at some point? Either way, I’m stoked! Saved me time & trouble of having to upgrade it.
Btw, the included manual stated that while charging, the switch LED would be blue. It’s not. It’s red. And actually, I prefer that. Who does blue WHILE charging? All of the lights I’ve had with e-switches and on-board charging shine red while charging, then blue when complete.
Question:
The battery level indication range is set for the voltage of a single 18650. So I’m presuming that what we see is an average taken of voltage across all cells? Certainly not cumulative, as you’d see on something like the Nitecore EA41 (4 x AA). Seems like that’s the case, as at times when I’ve selected the status (3-clicks from off) I’ll get a lower number first, then the 2nd display shows a higher number (as if adjusting for total voltage assessed across 4 cells). At first I thought it was “making the rounds” showing the levels of each of the 4 cells individually, but the lower number never appeared again after cycling over 4 times.
Question:
Since the batteries are in parallel they all have the same voltage. Or am I not understanding your question?
I removed the 18650 cells and checked them out in my charger, individually. At the start of charging, I had 3.65, 3.71, 3.76, and 3.77. In the LT1, the power check showed 3 long flashes, and 7 short flashes. Then became 3 long, 8 short and continued to show that with repeated checks as it continued charging. But I get it now. By virtue of the parallel circuit, the voltage is inherently averaged out across the 4 cells.
