Yes, I do realize that — I should have annotated from “Advanced Menu” and will now do so. My point being, you can be in the Advanced menu and really use this UI in a simplistic manner. But yes, the Simple UI mode is terrific for someone like Lightbringer who wants to keep things simple, doesn’t want blinkies or to get caught up in an unexpected menu.
I always assumed that was your humorous take on a nickname.
Users will have their reasons for wanting, or not wanting Andúril, and the same applies for the manufacturers.
Many logical reasons have been cited. In general, the higher end brands cater to “pro” users who want tools, and can afford to employ staff to develop firmware and driver solutions in-house to meet their specific product goals. The budget brands cater to their enthusiast market, with less demanding fundamental needs, but more demands for the bells and whistles that serve to bolster the “value” quotient, modification potential and bragging rights of sorts. A low-cost solution that makes for an easier sales pitch to their most loyal customers, requiring little other than attribution (which some do better than others). Despite the open source nature, there are few attempts to make modifications, and the community can be leaned on to implement those, with some individuals doing it for themselves, which get shared with the community.
Personally, I think there is a still a lot of untapped potential, but for whatever reason, also a lot of reluctance to do so on the part of the manufacturers.
Ultimately, the whys and hows are resolved by the market and sales numbers.
Andy 2 sounds good in simple mode. I wish top of ramp could be set to say 120 and still be able to use turbo. Otherwise you have to set top of ramp to max then ramp down to a sustainable level each time. It’s a constant guessing game.
I just think it’s funny some think that Ace Beam/Fenix/Nitecore are “higher end” lights.
I have plenty lights with many different UIs but I keep coming back to the ones with Anduril. Maybe because I’m just used to it or know the UI better than others. Some modes of Anduril I wish were on other lights like the electronic lockout, battery check, moon and low modes on lockout just to name a few. And the ramping, oh lawd the ramping.
I was following that/a thread for a while, and I (very) vaguely recall some discontent between starting out in “simple” vs “muggle” mode. Ie, it would start out, not just dumbed down but also throttled back, to keep The Muggle from hurting himself, with max brightness being limited, etc., “safe enough to hand to the kiddies”.
Simplified, great, but throttled down… nah. No point in buying a 2000lm light if it only goes to 500lm or so.
Someone fairly recently had a video-review of such a light, pretty sure it was in Muggle Mode, that limited max output to a nice “safe” level.
Lost track of recent developments for A2… are those separate and distinct? If so, then sure, Simple Mode might address most of those issues, which’d be great.
And right smack in the middle, ie, 3click, is ramping vs stepped (from on), and blinkies (from off).
So if the light’s on and you want to try strobe (on/turbo/strobe as 1/2/3 clicks for most lights), you don’t get into blinkies, but it will switch to stepped ⇆ ramping mode. Next time you try to ramp up/down… wtf?!?
Most Other Lights with the usual shortcuts will get into blinkies whether from on or off with a 3click. Only now you’re wondering why no blinkies, and why (next time you try bumping the brightness), it switches in steps vs smoothly, or v/v.
You just illustrated my point by the gap (what would be item 2.5 in the “from on” list).
And that’s what drives people crazy, inconsistency vs more orthogonal commands.
Man I’m just a fat guy in a wheelchair. Lots of different lights of different types and uses. Anduril ruined all of my lights without it. Except for Fenix HL50. I have many different headlamps but keep coming back to HL50. Even have the brightest wheelchair in town. Wish it’d Anduril
I don’t see the benefit of Anduril in a headlamp. I like the ability to change things quickly in a handheld but it is not like I walk around with my hand on a headlamp button.
In the simple mode, 3 clicks while on does nothing.
While off:
1C: On (mem)
1H: On (floor)
2C: On (ceiling)
2H: Momentary ceiling
3C: Battcheck (returns to off after one readout, other blinkies are blocked)
4C: Lockout
While on:
1C: Off
1H: Ramp up (or down, if pressed again)
2H: Ramp down
2C: Ceiling
4C: Lockout
While locked:
1H: Momentary moon
2H: Momentary low
4C: On (mem)
4H: On (floor)
5C: On (ceiling)
… or to go into advanced mode, it’s 10H from off.
The old muggle mode went from about ~5 lm to ~300 lm. It was really kind of a terrible mode which was only added as an afterthought.
The Simple UI is much more robust, and has actual thermal regulation and stuff, and typically has a much higher limit. The settings are chosen on a per-light basis by the manufacturer though. For example, the LT1 and SP10 both go to full power in simple mode. The D4v2 goes from about ~5 lm to ~2000 lm in simple mode.
If the defaults aren’t what the user wants, it can be reconfigured, but that involves a trip to advanced mode and back. Like, they can set it up so simple mode goes all the way from moon to full turbo if they want, or they can make it do smooth or stepped ramp styles, or they can change the aux LED color, or whatever… but once they go back to simple mode, everything is locked in and can’t be changed. That way, people only have to refer to the manual once, and then they don’t have to worry about changing something by accident later.
One of my favorite new features is not enabled by default, but a lot of people seem to like it… there’s a timer for manual memory, also known as “hybrid memory”. That way, it’ll remember the last-ramped brightness during use, but when it’s off for long enough, it resets to whatever default level the user chose.
I usually set it for about 10 minutes, so if it has been more than a few minutes since I used it, it’ll reset to a consistent and predictable brightness. Basically, if I forget what level the light was at, the light forgets too.
Most non-flashlight enthusiasts I know who have owned Anduril based lights have found the user interface too confusing. Yes, Simple UI is an improvement, but really needs 2C turbo to be turned on, or even the top brightness step to be turbo to be acceptable for consumer market lights. Better calibrated temperature sensors, version specific instructions, and ANSI brightness/runtime charts would also be required by consumer flashlight companies.
That’s mostly up to the individual companies making lights. Some have stepped up to make lights with appropriately matched hosts and drivers, so that full power can safely be enabled by default. Some recent designs finally have good factory calibration. Some come with a nice version-specific printed manual. Not many do ANSI testing, but that’s more of a universal problem.
Historically, most Anduril lights have been hot rods… but that’s not inherent to Anduril. It just has been difficult to convince anyone to make more “normal” lights. I’d really like something like a ZebraLight SC64 or Olight S2 with Anduril on it, but nobody has been willing to make them. TBH, I’m getting kind of sick of multi-emitter photon grenades. I just want something compact and practical with a single LED and a pretty beam.
My favorite Muggle-ish reference in Anduril was the MISCHIEF_MANAGED return code in the FSM source files.
I don’t think I can deal with remembering 6 clicks this, 10 clicks that. I have the whacky idea of implementing a text based interface for FSM, yes text based. To go into flashing mode you’d use the button to key “FL” (…. .…) in Morse code, and so on. They made me learn Morse code to get my ham license back in the day, so I might as well put it to some use.
To enter advanced mode, of course, you’d have to key in “ISSIAUTNG” (I solemnly swear I am up to no good).
Well yes, all of that is true, and from a technical point of view you probably have done most of what you could to make Anduril 2 mass market compatible. But if we’re talking market adoption then I’m not convinced that’s enough. At the end of the day the Anduril developers (you?) find yourself in a B2B2C situation, where you’re trying to get manufacturers to use your software for consumer products. Anduril 1 has a reputation for being for nerds only, and for being used primarily on cheap hot rods. You can’t shake that off easily by changing some technical stuff (the UI) that you still have no hope of describing without a complex diagram.
If you were to just get rid of the advanced mode altogether, rebrand the result as Anduril Redux, make sure it’s not named together with “Budget”LF ever, drop the current license, and have a high quality (for the mass market!) reference light - then this might go somewhere. As I see it right now, Anduril “2” indicates that someone has doubled down on the feature set, while maintaining the core of Anduril 1. And I think that’s even true to a large extent.
Again – this is not a bad thing at all, and while I’m on a modified Anduril 1 with my lights I appreciate what Anduril 2 is and does. I’m playing devil’s advocate here. But at the end of the day you haven’t really countered my knife analogy. Anduril 2 still can do all of the things that are irrelevant to, and get in the way of, the mass market. Why would I buy something that can be whatever I want it to be if I need stuff on which professionals have already done all the thinking for me, and have come up with a narrow set of settings and features that are useful out of the box?
