Seems like it’s a choice between SST20 (high CRI) or Cree XP-L HI at 4000k, but given what was mentioned at the start of this thread I’m leaning towards Cree XP-L HI in 4000k for more throw/lumens but with (hopefully?) neutral colouring.
Am I on the right track? I guess what I’m really looking for is something similar to my PD32 but that doesn’t turn everything white.
Looks like a neutral equivalent of the PD32/35 isn’t possible because those emitters only come in 6500k colour, so I’m guessing Cree XP-L HI at 4000k is about as good as it’ll get.
For a thrower you want a very small led to maximize focus by the reflector or optic, and Osram seems to be the champion of that.
I’d go for a Noctigon KR1 with an Osram W2 led mainly because it’s Anduril and everyone seems to like Hank lights around here:
I’m sure there are alternatives though. Anyway, look at the candela ratings of the different leds on that page (scroll down) to get an idea of the throw. The Osram would seem to give quite a pencil beam. Next thing after that would be a LEP (white laser).
rather than 7135*8 which would be the highest output driver. Why would you not want the strongest driver? Surely output can be regulated through the software if you want to run it on a lower brightness… so I think I’m missing something.
I looked up the max forward current of the Cree XP-L HI v3, 3A, so I think the biggest driver is the one to get. Will wait before ordering though as I’m sure others on here know more than me.
The original version of the driver had no thermal protection. 2.8A is a bit much for the S2+ host and with 8x7135 chips it could quickly reach very high temperatures. 6x7135 is more manageable.
The newest version of the driver does have thermal management but I don’t know if that is what ships with this light.
Okie doke, have requested cancellation and sent a message.
I also have an S2+ with 219B on the way which seems to only have a 7135x8 driver and no other options, so guessing that one has the thermal protection and I’m guessing it’ll work fine with this one too, so I guess it probably doesn’t really matter.
Cool so I cancelled the S2+ order and found an S2 with the XP-L HI 5000k and a thermally-regulated 7135x8. Should make for a nice little neutral mini thrower.
About ‘throwers’ S2 or S2+
I have both S2 and S2+ with variety of different leds, some with hicri sst20 (the smallest hicri led) and some with shaved lh351d (LES similar to xpl-hi ). And what can I say - both really are not true throwers, because of the reflectors shape and light distribution.
The reflector of S2+ is very shallow with big spill and looks ugly with small leds like sst20. Reflector is made for flood and much light goes into spill not hotspot.
The reflector of S2 opposite is very deep, too deep for its diameter and this also don’t allow the right light distribution for throw. Less spill diameter than S2+ but this spill is more intensive. And this give nothing to the intensity of hotspot. But this deep reflector looks good with small leds like sst20.
So both S2 and S2+ doesn’t look like real throwers even with the small led - to much light goes to spill, not hotspot.
There is one good variant for hicri tube thrower form the box, but it is 21700 - Manta ray S21 on aliexpress
Comes with sst20 and the reflector shape is similar to true thrower like C8 but smaller. It really makes maximum concentrated hotspot with dull spill. Basically it’s the same 21700 variant of S3 host listed above witch is also sold like “Ekoras R7”, but ekoras with sst40 is quite floody and cant throw much. It can be ordered with SMO reflector and with sst20 it produces the beam like little copy of C8 - pure thrower.
Output lens diameter of s2/s2+ is only 17,5mm and this variant of 21700 like manta ray or ekoras is 21mm but due to right shape of reflector and bigger surface it produces a real concentrated beam.
By the way - convoy s21a and s21b is also 21700 and lens diameter is 21mm, but the reflector is very shallow, even more shallow than s2+ and cannot really throw. Just a floody reflector.
