<!DOCTYPE HTML PUBLIC “-//W3C//DTD HTML 4.01 Transitional//EN”>
Test of Samsung INR18650-35E 3500mAh (Pink) 2
Official specifications:
Nominal capacity: 3500mAh
Minimum capacity: 3350mAh
Nominal voltage: 3,6V - 3,7V
Charging voltage: 4,2V
Discharge current: 8A
Maximum discharge current: 13A
Charge current: 0,6C 2000mA
Discharge end voltage: 2,65V
Pluspol: FlatTop
Chemistry: LiNiCoAlO2
Diameter: 18,55mm ± 0,1
Height: 65,25mm ± 0,15
Weight: 48g ± 1
This is a fairly new 35E cell (Supposed to be 2020) from Samsung. It is a high capacity cell.
The two cells tracks fairly well, the cell can handle the rated 8A.
Conclusion
This is a good cell, but performance is lower than the one I tested some years ago (This may be because this cell was produced some time ago).
Notes and links
The batteries was supplied by reader for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
