Initial bezel design is rather aggressive. Fortunately they listened to my advice to tone it down, else shredded pants and backpack stories would arise later.
I don’t mind it, I think it looks good!
Now this thread is unlocked again, I can share my findings. I thought this light just had high-low, but it actually has turbo, with a double click from on or off. Whilst playing with it inside I thought a double click just took it to high, and high and turbo are that intense I couldn’t tell the difference. So when I took my initial readings, I was only reading high. I’ve taken some more reading since and got the following:
Low - 619Kcd
High - 1.7Mcd
Turbo - 2.38Mcd!
All taken at 6m whilst wearing sunglasses! Haha
Still need to try and do some at around 20m when I get chance.
That’s amazing! Can’t wait for your 20m measurements mate
Over 3.08km? Quite impressive throw indeed. What about stepdown or tailcap amp reading?
I don’t have the equipment to do step down readings, but I did do some amp reading. I need some thicker gauge wire really, but this is what I got:
Low - 1.1A
High - 2.9A
Turbo - 3.6A
Have mine and it is very impressive! I wouldn’t change the bezel I think it looks excellent!
I’m interested. Can I still get in on the group buy?
Mine was shipped 25.8. to Europe, probably the second batch?
Just got mine. Very happy with the quality. Thank you freeme. I cannot distinguish the high from the turbo at all, which is not surprising and not important since the differential is relatively small.
I have ordered one,thank you.
When you double click from low to turbo you can clearly see the difference between high and turbo.
Robert
I put a type c cable to charge the battery,but I hadn’t seen any green/red light to show if the battery is charging,or it is in low voltage stage.Is it OK?
Is it USB Type-C to USB-A or Type-C to Type-C cable?
Type C to type A.
Is the battery close to 4v? Try discharge the capacity by activating Turbo for a minute or two first?.
Type C to type A.
It was 3.6V,so I put the battery in a charger at 2.5A to charge it.
By right it should work if inserted battery is 3.6V. It is better to identify the issue first. You might want to try different battery, cable, and input source?
Trying to buy it from Banggood but none of the coupons available seem to be working, am i too late for the sale or is something up with the codes?
I have already replied your pm.
For those who received my earlier pm. Perform these steps to reveal our latest code:
Previous image is being cached by BLF site.
Try these:
- Place your cursor over the previous image and right click
- Open image in new tab
- Hit F5 key(refresh browser) to reveal code.
