Is it really from a standard lighted tail switch ? cause I recently built another triple and stuck a lighted tail switch but its very dim compared to the one in the video, though I did use a blue to match the blue host.
Simon also sells these at the moment. In 3000k, 3500k and 4500k. If you order double of everything and send it all to me, I’ll build two, send you one and keep one as payment?
Hi that’s me. I got the bare Leds 219B from Convoy (AliX), optic (bicom) and mcpcb from KD. The driver is the “new (R020)” version 12 Groups 55 Modes 5A. It pulls 5.7A max with that triple.
Thank you! The plan is I want to sell it locally in my country at around $45, but haven’t upload the products yet.
As if you want to build that by yourself, the parts is available in Convoy Flashlight Store and KD. If you want the Carclo optics and Noctigon board, you can buy them at intl-outdoor.com. You can make the spacer at your local machinist or just order it from kiriba-ru.
Whole light, include the 18350 body. But no battery included, the price is a bit high for it’s specs because there’s some taxes and the copper spacer cost me around $8 each at my nearest machinist :’
I’m sorry, I don’t have access for the international shipping. I hope there’s a member here that would build you the flashlight, especially near you nor at least still in the same country.
negev, I am not sure if he can do it, if he is available or willing to put that light together for you, but try to reach member G0OSE (https://budgetlightforum.com/user/12792), as I’ve seen some stuff he modded and it looks good.
I just built S21A quad with 4500K 219b’s. With Kaidomain quad TIR and pcb it needed about 6mm high and 22mm wide flat spacer. Because its flat, it is easy to make yourself. If you have round stock aluminium or copper, you only need saw. Kaidomain TIR was perfect match to S21A. I used Led4Power 12 A driver.
