That’s amazing! Can’t wait for your 20m measurements mate
Over 3.08km? Quite impressive throw indeed. What about stepdown or tailcap amp reading?
I don’t have the equipment to do step down readings, but I did do some amp reading. I need some thicker gauge wire really, but this is what I got:
Low - 1.1A
High - 2.9A
Turbo - 3.6A
Have mine and it is very impressive! I wouldn’t change the bezel I think it looks excellent!
I’m interested. Can I still get in on the group buy?
Mine was shipped 25.8. to Europe, probably the second batch?
Just got mine. Very happy with the quality. Thank you freeme. I cannot distinguish the high from the turbo at all, which is not surprising and not important since the differential is relatively small.
I have ordered one,thank you.
When you double click from low to turbo you can clearly see the difference between high and turbo.
Robert
I put a type c cable to charge the battery,but I hadn’t seen any green/red light to show if the battery is charging,or it is in low voltage stage.Is it OK?
Is it USB Type-C to USB-A or Type-C to Type-C cable?
Type C to type A.
Is the battery close to 4v? Try discharge the capacity by activating Turbo for a minute or two first?.
Type C to type A.
It was 3.6V,so I put the battery in a charger at 2.5A to charge it.
By right it should work if inserted battery is 3.6V. It is better to identify the issue first. You might want to try different battery, cable, and input source?
Trying to buy it from Banggood but none of the coupons available seem to be working, am i too late for the sale or is something up with the codes?
I have already replied your pm.
For those who received my earlier pm. Perform these steps to reveal our latest code:
Previous image is being cached by BLF site.
Try these:
- Place your cursor over the previous image and right click
- Open image in new tab
- Hit F5 key(refresh browser) to reveal code.
Could I please have a group buy coupon code? Interested in this WP3 for the specs alone.
Interested
