ASTROLUX 6th Anniversary
Limited Edition WP3 Titanium Alloy
Group Buy
Limited to 15 coupons for 1st Batch
LEP 562lm 2952m 21700 Rechargeable Flashlight
For reference, this is my order timeline for our Group Buy.
Note: speed of delivery varies from country to country.
In polished Titanium.
Group Buy Price: $289.99 (usual $499.00)
Freeme's Coupon: Reply on this thread
Can't wait for our reply??
Special Price: $319.99 (usual $499.00)
Freeme's Coupon: BGWP3T
Description:
Astrolux® WP3 LEP light source has high energy density, and then passes through a special lens reflection system to form a dazzling light column. High and low brightness modes are adjustable, simple and practical. WP3 LEP search light throwing distance up to 2.6 kilometers! , Luminous flux 562 lumens, light intensity reaches 1750000 candela, comes with one 21700 rechargeable lithium ion battery, high-quality drive circuit with temperature control, constant current drive and ensure that the flashlight will not overheat. It is designed for special lighting.
Flashlight Specifications:
Name | Astrolux® WP3 2645m Long Shoot LEP Flashlight |
Material | Titanium alloy, black hard anodized surface |
Reflective system | Acrylic lens |
Light source | Special LEP module, wavelength 450-700nm, lifespan about 10,000 hours |
Distance | 2952 Meters |
Intensity | 2,180,000CD |
Mode | Single Click: Low - Medium - High Triple Click: Strobe Long Press: OFF |
Lumens | 95lm - 562lm - 562lm |
Battery | 1x 21700 or 1x 26650 li-ion rechargeable battery (21700 Included) |
Impact Resistence | 1.5m |
Waterproof | IPX6 |
Switch | Bode side, 50,000 press life |
Lens | Double coated tempered glass lens |
Weight | About --0g (without battery) |
Size (±0.5mm) | (head diameter) 59.5mm, (body diameter) 34.5mm, (length) 187mm |
Battery Specifications
Item |
Astrolux® E2145 21700 Battery |
Typical Capacity |
4530mAh |
Minimum capacity |
4500mAh |
Nominal voltage |
3.7V |
End-of-discharge Voltage |
3.00 V |
Max Discharging Current |
28A |
Weight |
Approx:70±2g |
Operating temperature |
Charging:0℃~45℃ Discharging:-20℃~60℃ |
Storage temperature |
-5℃~35℃ |
Storage Humidity |
≤75% RH |
Size, Diameter | 22±0.5mm |
Size, Length | 71±0.6mm |
Net weight | 70±2g |
Features:
- High efficiency constant current drive circuit, no noise and no PWM
- Temperature control protection: when the flashlight temperature is too high, the flashlight will automatically reduce the brightness to prevent overheating
- Reverse polarity protection
- Low voltage prompt function
- Battery over discharge protection
Package Included:
1 x Astrolux® Limited Edition WP3 Titanium LEP Flashlight
1 x Astrolux® 4500mAh 28A 21700 Battery
2 x Spare waterproof O-rings
1x 21700 to 26650 battery conversion tube
1 x Lanyard
1 x User Manual
https://1thedeals.com/blf-flashlight-group-buy/
