【convoy】219B R9080 TEST
6093 posts / 0 new
ArtieT59
ArtieT59's picture
Last seen: 7 hours 27 min ago
How do you put in for the t3 preorder? Why is $999 ??
[FLF] Five Light Friday https://budgetlightforum.com/node/78749
Check out some of my new lights (picture heavy) and quick first impressions of them here: https://budgetlightforum.com/node/77180
My Sft40 beamshots / comparison thread: https://budgetlightforum.com/node/78100
captainkirk
Last seen: 42 min 7 sec ago
That is just a placeholder. When they are ready Simon will let us know.
This space for let.
jasontheguitarist
Last seen: 1 day 20 hours ago
We’re gonna need the info on that T3. Is that using the new 17mm 12 group AA/14500 driver?
Funtastic
Funtastic's picture
Last seen: 1 min 29 sec ago
Could we perhaps come up with a different config list of mode groups for Convoy’s 12 group firmware, most of it is groups no one would use.
I’d especially love that 50% level in with the 100%, sure it may not be a big visual difference, but it allows for longer runtime and longer bursts than 100%
Also each blink in config represents each group, it’s way too slow as it is currently
How I would love a group where the low, med, high could be configured by the user. Like a ramping menu to set the brightness.
Texas Ace Lumen Tube calibrated with maukka lights
New Zealand store – https://www.piercingthedarkness.co.nz (NZ customers only)
YouTube channel – https://www.youtube.com/channel/UCIUWi2vYp4CWrRkOJM70t_w/videos (Demos for my customers, and reviews)
Sari33
Last seen: 2 days 8 hours ago
For this new T2 driver I’d like to keep a real 0.1% mode (sometimes it seems bit higher in my S2 + driver)which is useful indoors and close spaces
stephenk
stephenk's picture
Last seen: 1 hour 18 min ago
Personally I think the 0.1%, 1%, 10%, 35%, 100% spacing works well. 35% on the 5A versions is approximately where the lights balance due to thermal limiting, so I set it on 35% and know that the brightness will be relatively stable for night photography. The only improvement I would like to see is a constant frequency strobe instead of the terrible alternating/two frequency strobe.
Funtastic
Funtastic's picture
I guess it depends on what it’s being used for. I’m a dealer and stock the C8+, L21A & L21B for hunting, so 50% allowing a longer duration is far better than a short burst on 100%. For example the 5A driver paired with the NM1 gets 3 minutes at 100%, where 50% gets quite a decent amount longer and when you’re out searching for animals you need the extra range than what 35% provides.
At the moment I’ve discussed with Simon to get the SST40 ramping firmware on the Osram red model. The 100% level is too bright for closer range and it’s spooking the animals, and 20% is far too dim to be useful. Having adjustable levels is going to be awesome. Currently the 100% level is 280 lumens and the 20% level is only 20 lumens, so it’ll be great to have access to everything in between.
I get that the 35% suits general use, but it has been brought up quite a few times for others also. It’s not always about the maintained temperature, it’s also about runtime
id30209
id30209's picture
Last seen: 3 hours 23 min ago
Gents, wouldn't be better if you could set each level of output to your own liking?
We have such a driver already in Simons store, now all it needs is a bit tuning and that's it.
Ramping driver just calls for v.2 upgrade and to be imported in aa/liion, boost and buck options that Simon has.
WTB Titanium 4sevens 2xAA tube
Funtastic
Funtastic's picture
id30209 wrote:
Gents, wouldn’t be better if you could set each level of output to your own liking?
We have such a driver already in Simons store, now all it needs is a bit tuning and that’s it.
Yes, but it would be great if it was an additional UI on the 12 mode groups so people have a choice as to what they prefer. That would be the ideal driver I reckon.
Have 3 levels that are user configurable, I reckon that would be quite popular.
will34
will34's picture
Last seen: 1 day 6 hours ago
Some improvements can be made on the modes on the 12 group driver, but what i really wish for is battery check with 4 or 5 quick half clicks. I have 4 of these installed and always use group 5 no memory. Temperature step down should be able to be disabled or adjusted.
Ramping driver is quite nice for “tactical” use even with reverse switch. It can be improved with two way ramping and 4-5 click special mode access.
Funtastic
Funtastic's picture
Temp cannot be adjusted when most of the drivers rely on the NTC. Temp can be disabled by removing it
Sari33
SKV89 wrote:
Simon Mao wrote:
2021/8/6
Holy cow, that tint (DUV = -0.005) is amazing! The best 3535 3000k emitter I’ve seen to date!
I don’t know how certain it’s measure beam rebounce from wood color table but still quality emitter
Simon Mao
Simon Mao's picture
Last seen: 2 days 9 hours ago
stephenk wrote:
So are there any differences between the reflector in the M21C/D to the M21E?
the reflector of M21E and C8 are the same
Simon Mao
Simon Mao's picture
yes
jasontheguitarist
yes
Cool. I’m gonna need one of each color and like 5 of those drivers for other AA sized lights I have sitting around.
tactical_grizzly
tactical_grizzly's picture
Last seen: 2 hours 11 min ago
Simon, do you run the “Dongguan Kangwoyi Electronic Co.,Ltd” store on Amazon US or is that a reseller? Thank you.
Simon Mao
Simon Mao's picture
It’s my company.
The pronunciation of “Kangwoyi” in Chinese is similar to the English word “convoy”.
LTC
Last seen: 2 hours 45 min ago
Hi Simon,
Curious and will be nice to know…
I thought Chinese name for Convoy is 毛裤?
It’s my company.
Simon Mao
Simon Mao's picture
LTC wrote:
Hi Simon,
It’s my company.
毛裤 is my nickname
LTC
Thumbs Up Thumbs Up Beer Beer Beer
Simon Mao wrote:
LTC wrote:
Hi Simon,
It’s my company.
毛裤 is my nickname
dthrckt
dthrckt's picture
Last seen: 3 days 20 hours ago
googling 毛裤 turns up some interesting images
raccoon city
raccoon city's picture
Last seen: 14 hours 59 sec ago
Yup.
I'm seeing people wearing pants that look like very hairy legs.  :BEER:
lazerEagle
lazerEagle's picture
Last seen: 13 hours 1 min ago
Hairy pants for the win!
Funtastic, some interesting UI suggestions! Definetly agree a review of the various modes would be nice.
I’ve just received a M21B GT FC 3000-3200K and S2+ sw30k, really loving the warm tints + hi cri.
Have been running the UI on the default mode with memory mode turned off. I find this very usable and I can get into battery check easily enough (after a short epileptic episode) which is a nice feature.
- the best way to predict the future is to create it -
ArtieT59
ArtieT59's picture
lazerEagle wrote:
I've just received a M21B GT FC 3000-3200K and S2+ sw30k, really loving the warm tints + hi cri.
Nice! i just ordered the same M21c, my first GT FC40 light, and i ordered some sw30 bare leds as well on a "whim". I also ordered that AWESOME m21e in 4000k, but still am wondering if i shoud've went 3000k like my gut was telling me to do..
Correllux
Correllux's picture
Last seen: 1 hour 44 min ago
Haven’t been on in a couple weeks and randomly discovered these new lights in Simon’s store. Man, they look great! The T3 looks interesting, and the IR lights. Also saw that he was able to source the ring magnet for the T2 tail cap in a proper 4mm height, and they’re at a good price, too. I had to source some thinner 2mm from a store on ali and glue them together, and paid more than I wanted for ten of them. I messaged four vendors and none of them could source a thicker ring in that size…Simon’s got the connections! Thumbs Up
ArtieT59
ArtieT59's picture
Simon and Convoy CONTINUES to have THE YEAR! all of the new releases (4x18 sbt90, 3x21a, L7, new gt fc40 variations, and sft40 variations!) are awesome so far, and then he comes out with the M21E!. so awesome. Very exciting for us Convoy and flashlight fans, Simon. Thank you!
Funtastic
Funtastic's picture
What I’d love to see is the M21E, M21D etc use the SFT40. Yes, I know it would require a new driver, but currently Convoy have nothing for longer reach using a side switch, except the SBT90.2 models. Need something a wee bit more compact
JaredM
JaredM's picture
Last seen: 15 min 29 sec ago
M4U not suitable?
Funtastic
Funtastic's picture
JaredM wrote:
M4U not suitable?
Needs to have a bit more grunt to compete with most out there now.
Sofirn now have the IF22 & IF22A. Convoy doesn’t have anything much in terms of longer range. There’s other brands I could stock, but I just love Simon’s pricing and customer service, unbeatable I reckon
Simon Mao
Simon Mao's picture
driver for M21E with KW CULPM1.T/SFT40 in production now
