Interested
Interested
Interested! Is the beam wider or narrower than the FT-03 XHP-50 version?
Interested. If I have a choice,I prefer the 26800 option from the get-go and any colour other than black
My guess is that it will be pretty close in terms of hotspot size but with double the output.
Freeme, can you please ask Mateminco if they are willing to share some information about SFN55.2, e.g. datasheets, who the manufacturer is?
Interested
Interested in 26800
I’m interested
Interested, also for the 26800 tube.
I will do a comparison (indoor) in a few hours time.
I was focusing on max output yesterday. MT35mini managed to clock
- 6215lm with VapCell 3100mAh 35A 21700 (30T). 8.6% short from claimed valu, which is not too bad imo.
- 5682lm with half inserted extension tube(mend for EA series) for QB26800
Is this at turn on?
Correct, max output for the few seconds, not ANSI FL1 Standard.
Candela (cd): 239561
Throw Distance: 979m / 3211ft
freeme:I will do a comparison (indoor) in a few hours time.
AlexGT:Interested! Is the beam wider or narrower than the FT-03 XHP-50 version?
Is this at turn on?
Interesting, thanks. So in the same host:
- XHP50.2 - 31 cd/lm
- SFN55.2 - 39 cd/lm
- SST40 - 79 cd/lm
- SBT90.2 - 113 cd/lm
Are you using the same lux meter with the same calibration as when you measured the SST40?
I have dedicated LUX meter for candela test. It is the same set that i have been using for the past 3yrs. This particular set tends to report slightly lower value than others, so whatever i published in my reviews, it should be easily attained by majority of the testers.
freeme:Candela (cd): 239561
Throw Distance(@7m): 979m / 3211ft
Interested
Interested!
Interested in a MT70 Mini SFN55.2, Blue
