Do you often use facebook and reddit? Sometimes I want to post pictures of some new things. Uploading pictures here is a troublesome thing. I have to upload the pictures to flicker first, and then copy the link to post here.
I use imgur (https://imgur.com), which is much quicker as you can copy and paste images or drag and drop them. You still have to copy the link to post here but it’s much simpler.
Simon, I received your new M3C today the one without a head spring. Spring tension on the 26800 with extension and the 26650 with the body tube only is mild to weak. On moon mode a mild tap will turn it off. Other modes it flickers. My quick fix so far is to remove the retaining ring. Press a P60 outer dropin spring into the hole along with the supplied tail spring. It fits very snug but a longer stronger tail spring is needed.
There is a possibility that this is a temporary solution to the problem. The spring will squeeze again over time and everything will repeat itself. I think need a more powerful spring or a double spring for flashlights with heavy 26650 batteries.
Found on r/flashlights, credit: u/N0b0dyfromsomewhere. He says “A new SBT90.2 flashlight model, 81mm head, using 26800 battery
from Simon’s FB profile”
It looks wicked. I hope there’ll be an adapter for a 21700/26650 because I can’t get a 26800 in New Zealand. I can get the light shipped with one, but no spares are possible
