Interested
Interested in 26800
I’m interested
Interested, also for the 26800 tube.
I will do a comparison (indoor) in a few hours time.
I was focusing on max output yesterday. MT35mini managed to clock
- 6215lm with VapCell 3100mAh 35A 21700 (30T). 8.6% short from claimed valu, which is not too bad imo.
- 5682lm with half inserted extension tube(mend for EA series) for QB26800
Is this at turn on?
Correct, max output for the few seconds, not ANSI FL1 Standard.
Candela (cd): 239561
Throw Distance: 979m / 3211ft
freeme:I will do a comparison (indoor) in a few hours time.
AlexGT:Interested! Is the beam wider or narrower than the FT-03 XHP-50 version?
Is this at turn on?
Interesting, thanks. So in the same host:
- XHP50.2 - 31 cd/lm
- SFN55.2 - 39 cd/lm
- SST40 - 79 cd/lm
- SBT90.2 - 113 cd/lm
Are you using the same lux meter with the same calibration as when you measured the SST40?
I have dedicated LUX meter for candela test. It is the same set that i have been using for the past 3yrs. This particular set tends to report slightly lower value than others, so whatever i published in my reviews, it should be easily attained by majority of the testers.
freeme:Candela (cd): 239561
Throw Distance(@7m): 979m / 3211ft
Interested
Interested!
Interested in a MT70 Mini SFN55.2, Blue
They can stock some later.
Need the 26800 tube from the start.
Hi, i’m interested
I’m interested.
Interested
List updated.
I’m in very interested
