I actually suspected both my L3 L11C and my first generation ROT66 were SW45, but didn’t have any way to verify. Both look very neutral to me. They only look rosy if comparing to lights with worse tint. It looks like Maukka tested his ROT66 at moderately rosy on middle outputs, and very rosy on turbo:
I was not aware SW45 (non-K) was not actually available in R9080, but I’ll take Bob McBob’s word for it. I guess one or the other of my lights might have actually had R85.
Maukka’s ROT66 measurement technically meets R9080, but is consistent with Bob McBob’s statement about the typical performance of R85 219B’s.
Also, here is the chromaticity diagram showing the range of DUV possible within SW45K that Bob mentioned. It looks like the theoretical range is even bigger than he stated, but from tint measurements I’ve seen shared, the numbers he mentioned seem realistic.
Yeah, that’s the same reason I haven’t used the newer ROT66 much. It looks like it’s 5500K. Granted, it’s the best-looking “5500K” I’ve ever encountered, but I was hoping for more a neutral CCT instead of a colder shade.
I don’t have any reason to suspect the original ROT66 didn’t use D220 R9080 sw45k as Fireflies claimed. I believe they ordered an entire reel straight from Nichia, and I seem to recall the label being posted somewhere. The limits I gave are calculated from the CIE coordinates in the datasheet and are specifically at the rated current, so in actual use sw45k can be much rosier (D200 often measures –0.0180 at 3A in an SC64c). The “official” spec is 4260K to 4745K at 700mA. All my ROT66s measure reasonably close to known D220 reels I’ve used.
Yes, the quality of data is much higher with a spectrometer than it is without. Comparing visually against a few dozen lights with known tint bins is better than nothing, but a spectrometer would be even better.
Fortunately, Bob has a spectrometer and rather a lot of experience with 219B LEDs… so I’m inclined to trust what he says.
the 3 left greener ones, are older 219b 9050. could be d240
the more violet one on the right is sw45k 9080 (could be D200 or D220)
I have bought sw45 non K 9080 from Andy,
second from left:
(sw45 9080 is less pink than sw45k 9080, but more pink than sw45 9050)
Ive also bought sw45k D200 and sw45k D220, they differ in output by 10%, and they vary in how pink the Tint is, as McBob said, generally lower bin, more pink (not always, there can be bin overlaps)
the violet portion is what makes the sw45k work so well during the day, without being green at night
True. A spectrometer is the end all be all, but that does discredit our own eyes. And regarding the idea of "you like what you like", it is obvious if the old is different than the new. It doesnt matter in this situation "by how much exactly" unless that is in fact what the person wants to know. And in fact, that was what TK had originally asked, but not what they or I were referring to in the above comment. We were just simply insinuating COLD LIGHT = BAD LIGHT :))
You’re right, the “V1” update was before my time in flashlights, and I was always under the impression there was a noticeable physical difference too, but that is definitely a 219A.
It’s he D220 from Simon? Doesn’t look deep rosy as others sw45k but hope pinkish it’s visible when shine alone to eyes.
You are official Nichia Ambassador
atm he has sw45k D200, which are usually more pink than D220…
I see the pink of sw45k during the day (because daylight has higher DUV), but not at night. (because sw45k is cooler and looks bluer than incandescent)
