FastTech New Arrivals & Promotion
It is no memeory function, and the emmiter is L2.
Authentic Nitecore HC60 V2 Outdoor LED Headlamp
1*LED / 8-mode / 1200LM / pure white / 1*18650/2*CR123 / USB-C rechargeable / IPX7 waterproof / 180’ adjustable
Max Beam Intensity: 4240 cd
Advanced temperature regulation
Power indicator
100’ wide range flood beam
Elastic and breathable headband
1m impact resistance
UniqueFire UF-1404 LED Flashlight
authentic / 4*Cree XP-L / 3-mode / 4000LM / 6500K / 4*18650 / lanyard
Reflector diameter: 48mm
Head diameter: 59mm
Tube diameter: 48.5mm
Tail diameter: 53mm
Lanyard length: 18cm
Beam range: 100-200m
Working voltage: 14.8-16.8V
Fasttech,
do you have any sitewide promotions for this month or Labor Day?
Yes, we will have the sitewide promotion for the Labor Day.
Fenix E05R Mini Keychain LED Flashlight
1*Cree XP-G2 S3 LED / 4-mode / 400LM / pure white / Micro-USB rechargeable / IP68 waterproof
The Fenix E05R flashlight is a rechargeable mini flashlight that can emit up to 400 lumens from its built-in 320mAh Li-polymer battery. Fully rechargeable via a built-in micro USB charging port, the flashlight has a maximum runtime of 30 hours. This little flashlight is built tough with an IP68 dustproof and waterproof rating. Super small and compact, this keychain flashlight is a great choice for everyday carry.
Cree XP-G2 S3 white light LED with a lifespan of 50,000 hours.
Built-in 320mAh Li-polymer battery.
Hidden Micro-USB charging port.
Metal switch for on/off and output selection.
Instant Burst.
High-efficiency lens with a total reflective coating.
Made of durable A6061-T6 aluminum.
Premium type HAIII hard-anodized anti-abrasive finish.
Head diameter: 15mm
That Fenix E05R looks interesting.
Any chance it has easy-to-implement lockout?
Yes, just double click to lock or unlock.
Fenix PD35 V3.0 Tactical LED Flashlight
1*Luminus SFT40 LED / 6-mode / 1700LM / pure white / 1*18650/2*CR123A / IP68 waterproof
  • The improved PD35 V3.0 flashlight is destined to enrich the PD35 series flashlights. This light delivers a maximum of 1700 lumens at a distance of 357 meters. This Fenix PD35 V3.0 is compact but tough and features five output levels plus instant strobe. The dual switch design, tactical tail switch, and metal side switch- which also has a built-in battery level indicator, offer rapid and user-friendly operation. Ideally powered by one rechargeable 18650 Li-ion battery, it is also compatible with two cold-resistant CR123A batteries. All these highlights make the Fenix PD35 V3.0 very suitable for military use, policing, outdoor exploring, emergency lighting, EDC flashlight use, and more.
  • 1700 lumens maximum output; 357 meters maximum beam distance.
  • One Luminus SFT40 LED with a lifespan of 50,000 hours.
  • Included a 18650 rechargeable Li-ion battery, compatible with 2*CR123A Lithium batteries.
  • Boot-up battery level indication and low-voltage warning.
  • Instant activation with the tactical tail switch; output selection with the side switch.
  • Digitally regulated circuit for maintaining a stable output.
  • Toughened ultra-clear glass lens with an anti-reflective coating.
  • Made of durable A6061-T6 aluminum.
  • Premium type HAIII hard-anodized anti-abrasive finish.
  • Head diameter: 25.4mm
Nitecore P20i UV LED Flashlight
1*Luminus SST-40-W LED + 4*365nm LED / 5-mode / 1800LM / pure white & UV light / 1*21700/2*CR123 / IP68 waterproof
Head diameter: 31.8mm
Tail diameter: 28.5mm
Nitecore P20iX Tactical LED Flashlight
4*Cree XP-L2 V6 LED / 7-mode / 4000LM / pure white / 1*21700/2*CR123 / IP68 waterproof (2m underwater)
Nitecore P10iX Tactical LED Flashlight
Head diameter: 28.5mm
Tail diameter: 25.4mm
Thanks, what is the the sitewide promotion for Labor Day?
I am sorry that the sitewide promotion for Labor Day was canceled temporary, since another sitewide promotion is coming recently. Please don’t worry, we will have a sitewide promotion soon. Please pay attention to the update and notification on our website.
Take advantage of Labor Day sale and save up to 18%
1*LED 6-Mode 2200LM Tactical LED Flashlight w/ Focus Zoom
pure white / IPX4 waterproof / clip / OLED display
  • Head diameter: 44mm
  • Tail diameter: 35mm
  • Smart screen displays mode, lumens, voltage and power
  • Operation:
    Press and hold for three seconds and then turn on the flashlight, display WELCOME, then enter L1 mode (200LM), click again to enter L2 mode (500LM)
    Click again to enter L3 mode (1200LM), click again to enter L4 mode (STR flashes), click again to return to L1 mode
    Quickly double-click to enter H mode (2200LM super bright mode), click in this mode to enter SOS mode, and click again to return to H mode
    Long press for three seconds to turn off, the screen displays GOODBYE
1*LED 3-Mode 2500LM LED Flashlight w/ Focus Zoom
pure white / IPX4 waterproof / window breaker / power display
Head diameter: 60mm
Tail diameter: 33mm
The design of the extension tube of the flashlight can be switched between long and short models.
Niwalker ETmini V2 EDC LED Flashlight
1*OSRAM PUSRA1.PM (3W) LED+3*OSRAM PUSRA1.PM (2W) LED / 2350LM / 3000K & 6000K / IPX7 / USB-C rechargeable
  • LED Source: 1pc OSRAM PUSRA1.PM (3W) LED & 3pcs OSRAM PUSRA1.PM (2W) LED
  • Output: Max 3050 Lumens with Turbo
    3*LED 6000K (CW): 2350 Lumens
    1*LED 3000K (NW): 1100 Lumens respectively
  • Intensity: 8380cd with medium brightness
  • Beam distance: 183 Meter with medium brightness
  • Switch: Side control Switch with LED indicator to monitor battery level
  • Charging Port: Type-C Fast charging
  • Battery: One high drain and unprotected 18350/20350 cell (not included)
  • User interfaces: Press side switch to on/off. Hold the switch after on, smooth ramping will be able to switch the brightness from low to high and high to low. Ability to toggle between Smooth and Stepped ramping. Double clicks will get instant access for turbo mode.
  • Other functions/modes: Timing mode, Flash alternative mode, Power monitoring, Firefly mode, Single or dual head mode. (pls refer to user manual for more exciting modes)
  • Lockout: Yes, clicks 4 times to lock and unlock
  • Memory: Yes. Will memorize the last brightness mode
  • Optic: Standard TIR Optic Lens for 3*LEDs Lens and Orange Peel reflector for 1*LED Lens
  • Body: Aluminum with hard Finishing
  • Magnetic Tailcap: Yes, hands free while work
  • Waterproof: IPX7 1m underwater for 30min max
Purchase our gift card and get an extra 3% free value automatically
Nitecore TM06S LED Flashlight
4*Cree XM-L2 U3 LED / 8-mode / 4000LM / pure white / 4*18650 / IPX8 waterproof (2m underwater)
