Can’t wait for the first 2x26800 - this seems like a good candidate.
Yes, it’s a sample ,but the driver is not good ,
it’s a FET driver, The manufacturer claims that the maximum output can reach 25A, but when I measured it was only 19.2A
spring can soldered on the the 26mm plate, The area used for welding the spring on the driver is too small, and I cannot find a suitable spring that can withstand large currents.
Maybe talk to BlueSwordM about his high current springs, together they can handle 21A. Maybe they will fit
Di_Joker: Simon Mao: texas shooter:Simon, I received your new M3C today the one without a head spring. Spring tension on the 26800 with extension and the 26650 with the body tube only is mild to weak. On moon mode a mild tap will turn it off. Other modes it flickers. My quick fix so far is to remove the retaining ring. Press a P60 outer dropin spring into the hole along with the supplied tail spring. It fits very snug but a longer stronger tail spring is needed.
Di_Joker:
Yes, there is a similar problem with the S11 spring. I put a vertically switched flashlight on the table and it switches the mode. :person_facepalming:
i can send the 26mm plates if you need it
There is a possibility that this is a temporary solution to the problem. The spring will squeeze again over time and everything will repeat itself. I think need a more powerful spring or a double spring for flashlights with heavy 26650 batteries.
Pilotboy:Found on r/flashlights, credit: u/N0b0dyfromsomewhere. He says “A new SBT90.2 flashlight model, 81mm head, using 26800 battery
from Simon’s FB profile”
Can Simon please confirm?
Looks good, that’s your biggest reflector yet. Any chance of a M3 or L2 size head for us pocket rocket people?
L2 pocket rocket? Haha
Those are some extra Texan pockets
Any ETA on the IR lights? Thanks!
Love the design on the new 26800 light! Finally a proper SBT90.2 mid size thrower with adequate cooling. I’ll sure order one when the driver and spring issue gets sorted out. Just squeeze in a bigger FET and worst case scenario use solid brass +ive contact and 18awg bypassed rear spring.
Will it be called the L5?
texas shooter:Are these parts on aliexpress?
It’s these, the large spring only. 5.82€ 5% OFF|DIY Batterie/Fahrer Kontaktieren Unterstützung Quellen für P60 (26,5mm) Drop in 10 sets|battery contact spring|contact battery springcontact spring - AliExpress
base diameter should be less than 5mm
Simon Mao: Di_Joker: Simon Mao: texas shooter:Simon, I received your new M3C today the one without a head spring. Spring tension on the 26800 with extension and the 26650 with the body tube only is mild to weak. On moon mode a mild tap will turn it off. Other modes it flickers. My quick fix so far is to remove the retaining ring. Press a P60 outer dropin spring into the hole along with the supplied tail spring. It fits very snug but a longer stronger tail spring is needed.
Di_Joker:
Uh, what I mean is that the positive electrode of the battery and the driver are not in contact with the spring
This is exciting! Will a host version be available?
texas shooter: Simon Mao: Di_Joker: Simon Mao: texas shooter:Simon, I received your new M3C today the one without a head spring. Spring tension on the 26800 with extension and the 26650 with the body tube only is mild to weak. On moon mode a mild tap will turn it off. Other modes it flickers. My quick fix so far is to remove the retaining ring. Press a P60 outer dropin spring into the hole along with the supplied tail spring. It fits very snug but a longer stronger tail spring is needed.
Di_Joker:
The driver now only has a stud. Prefer springs on both ends to allow travel under shock without loss of contact.
Thank you very much
Simon. Please consider making some sort of shock dampener for the positive contact on drivers using the brass stud. This would ideally be a low durometer rubber or high density foam that prevents the positive end of the cell from being dented from impact. A plastic ‘cap’ that surrounds the stud and only let’s it protrude a mm or less would work too
Simon Mao: texas shooter: Simon Mao: Di_Joker: Simon Mao: texas shooter:Simon, I received your new M3C today the one without a head spring. Spring tension on the 26800 with extension and the 26650 with the body tube only is mild to weak. On moon mode a mild tap will turn it off. Other modes it flickers. My quick fix so far is to remove the retaining ring. Press a P60 outer dropin spring into the hole along with the supplied tail spring. It fits very snug but a longer stronger tail spring is needed.
Di_Joker:
Like a gun-light, I’d imagine.
Recoil would be Hell on a driver…
What a beauty in polished silver/raw!
Simon, do you plan to make these in 2 x 26800 with one piece battery tube (no adapters)? Then you could use your L7 driver. Please do and I will buy.
There is a very simple way, you can use silicone o-ring of appropriate size for the thread,
For example, 26650 battery, you can put some 26mm O-ring on the positive pole
