The Fenix E05R flashlight is a rechargeable mini flashlight that can emit up to 400 lumens from its built-in 320mAh Li-polymer battery. Fully rechargeable via a built-in micro USB charging port, the flashlight has a maximum runtime of 30 hours. This little flashlight is built tough with an IP68 dustproof and waterproof rating. Super small and compact, this keychain flashlight is a great choice for everyday carry.
Cree XP-G2 S3 white light LED with a lifespan of 50,000 hours.
Built-in 320mAh Li-polymer battery.
Hidden Micro-USB charging port.
Metal switch for on/off and output selection.
Instant Burst.
High-efficiency lens with a total reflective coating.
Made of durable A6061-T6 aluminum.
Premium type HAIII hard-anodized anti-abrasive finish.
Head diameter: 15mm
The improved PD35 V3.0 flashlight is destined to enrich the PD35 series flashlights. This light delivers a maximum of 1700 lumens at a distance of 357 meters. This Fenix PD35 V3.0 is compact but tough and features five output levels plus instant strobe. The dual switch design, tactical tail switch, and metal side switch- which also has a built-in battery level indicator, offer rapid and user-friendly operation. Ideally powered by one rechargeable 18650 Li-ion battery, it is also compatible with two cold-resistant CR123A batteries. All these highlights make the Fenix PD35 V3.0 very suitable for military use, policing, outdoor exploring, emergency lighting, EDC flashlight use, and more.
1700 lumens maximum output; 357 meters maximum beam distance.
One Luminus SFT40 LED with a lifespan of 50,000 hours.
Included a 18650 rechargeable Li-ion battery, compatible with 2*CR123A Lithium batteries.
Boot-up battery level indication and low-voltage warning.
Instant activation with the tactical tail switch; output selection with the side switch.
Digitally regulated circuit for maintaining a stable output.
Toughened ultra-clear glass lens with an anti-reflective coating.
I am sorry that the sitewide promotion for Labor Day was canceled temporary, since another sitewide promotion is coming recently. Please don’t worry, we will have a sitewide promotion soon. Please pay attention to the update and notification on our website.
Smart screen displays mode, lumens, voltage and power
Operation:
Press and hold for three seconds and then turn on the flashlight, display WELCOME, then enter L1 mode (200LM), click again to enter L2 mode (500LM)
Click again to enter L3 mode (1200LM), click again to enter L4 mode (STR flashes), click again to return to L1 mode
Quickly double-click to enter H mode (2200LM super bright mode), click in this mode to enter SOS mode, and click again to return to H mode
Long press for three seconds to turn off, the screen displays GOODBYE
LED Source: 1pc OSRAM PUSRA1.PM (3W) LED & 3pcs OSRAM PUSRA1.PM (2W) LED
Output: Max 3050 Lumens with Turbo
3*LED 6000K (CW): 2350 Lumens
1*LED 3000K (NW): 1100 Lumens respectively
Intensity: 8380cd with medium brightness
Beam distance: 183 Meter with medium brightness
Switch: Side control Switch with LED indicator to monitor battery level
Charging Port: Type-C Fast charging
Battery: One high drain and unprotected 18350/20350 cell (not included)
User interfaces: Press side switch to on/off. Hold the switch after on, smooth ramping will be able to switch the brightness from low to high and high to low. Ability to toggle between Smooth and Stepped ramping. Double clicks will get instant access for turbo mode.
Other functions/modes: Timing mode, Flash alternative mode, Power monitoring, Firefly mode, Single or dual head mode. (pls refer to user manual for more exciting modes)
Lockout: Yes, clicks 4 times to lock and unlock
Memory: Yes. Will memorize the last brightness mode
Optic: Standard TIR Optic Lens for 3*LEDs Lens and Orange Peel reflector for 1*LED Lens
