I’m wanting to make a removable filter cap to give the Osram CSLNM1 Red a bit more flood for closer range, what d-c-fix type would work? The Convoy L21B has a very tight beam, so it would be great if I could spread it out for use at 80 - 200m. This L21B achieves a range of 850m ANSI and it’s fairly tight for anything under 300m.
Still need that hotspot with just a bit more spread to it, if possible.
Thinking of getting a red filter and remove the red lens and replace it with a spare L21B lens with the d-c-fix.
Try some dc fix but cut it smaller than the full diameter. Leaving 1/8” or so around the circumference uncovered will give you more flood but still keep your throw. I used the original dc fix.
I just received mine today. This is incredible and it gives new life to all lights.
I managed to convert my rarely used FW3A 6500k to 4500k with a layer of F4 and 2 layer of minusgreen Z3. It’s comparable to my D4V2 SW4500.
The #2 diffuser has a very slight warm tint compare to the MacBook diffuser film I’ve been using. I have a D40A with 50.2 and it sucks. The beam, hotspot, tint and I managed to make it smooth and rosy with layer of #2 and 2 layers of minusgreen 1/4.
I lose lumens but I have a “new” lights
The F4 is not heat resistant and it will melt.
You’ve sent me those films like 2 years ago. I just want to say they are great, still using them and really happy with the results. They’re best at turning donut beam into mild, even and nice beam.
Planning new order, hope sending to EU won’t be too big trouble.
hey boaz, i apologize if you posted pictures before, but i didnt feel like going through 15 pages of posts but do you have pictures of each option you listed in the first post so we can visually see what it is and how it looks? cuz just reading the words, it doesnt really paint the picture for someone like me who never used a dc fix before
I just got around to testing some of the film I ordered from Boaz. I really like the “F4 - LEE FILTERS 205 SHEET 1/2 C.T. ORANGE CONVERTS 6500K TO 3800K”. Though in my case, it only seemed to lower the tint to around 4500k (using my old Olight S30R). I’m still pleased with the result.
I opened each in a new tab and could toggle back and forth to see the difference in full size pics . Looks really nice and colors are popping . I've had real fun mixing it up with that filter too .thanks for the helpful post.
The loss using filters is less than if you swap a warmer emitter . Depending on the filter .
the diffusion filters are in some cases less then10% and minus green filters are 14% and 16% for the 1/8th and minus 1/4 . 15% is imperceptible to the human eye so it’s pretty meaningless
