Wurkkos FC12S (side switch version from FC12) what do you think?
227 posts / 0 new
Jerm
Last seen: 1 month 1 week ago
I recently ordered a fc11 and fc12. I chose the 2700k fc11 hoping the warm light will be good for tracking deer blood at night? Should these lights be adequate for hunting? Maybe the fc11 in 4000k or would have been a better option?
Lightbringer
Lightbringer's picture
Last seen: 3 hours 14 min ago
VOB made a vid using fresh and… stale?… blood, testing it with various lights, from UV to blue to WW/CW white to whatever. Forgot the results, but someone probably got a pointer to the vid somewhere.
Jerm
I’m not very knowledgeable about flashlights other than basic experience with them. The cool led lights don’t make the blood color “pop” as well as natural warm lights. I’m sure a 3000ish is a perfect light temp. I just found out the fc12 is a 6000k? After I ordered it. Maybe i will send it back for a tc11 or ts21 in 4000k.
WL27
Last seen: 10 hours 22 min ago
Why not get a Sofirn IF 25 with Tint Ramping from 2700k-6500k
dthrckt
dthrckt's picture
Last seen: 1 day 21 hours ago
Didn’t they sell blood tracking headlamps? Green, blue, some color is supposed to make blood stand out on the ground. I haven’t needed to track at night, I would probably favor lumens to some old gimmick light, but maybe there is some best color.
An Adjustable color temp light is a great suggestion, I might buy it just to figure out what I like.
Anyway, I wouldn’t use an sft40 for close up blood finding. Color temp, cri, yes – but also just a wider even beam.
Jerm
I’ve always heard an old Coleman lantern was the best for tracking. I assume the 2700k would be closest to that?
Jerm
I looked at it. And I still might lol!
Wurkkos
Wurkkos's picture
Last seen: 15 min 34 sec ago
Chips2 wrote:
No stock black, when do you sell the new colors?
the new colors will at batch 2# soon, out of stock right now because of SFT40 LED is rare, when LED ready, new stock will ready
weklund
weklund's picture
Last seen: 7 hours 20 min ago
Loving my new Purple Wurrkos.
... Happy Landings ...
Wurkkos
Wurkkos's picture
dthrckt
dthrckt's picture
Definitely…when you can find sft40s…
will34
will34's picture
Last seen: 7 hours 1 min ago
I would get 1 OD green and 1 purple please!
Wurkkos
Wurkkos's picture
have booked a large quantity from the manufacturer
Chips2
Last seen: 2 days 16 min ago
Like a SC31 pro? I don’t see the point
Wurkkos
Wurkkos's picture
Except the UI may keep same as sc31pro, FC12S is on the basis of the FC12, use SFT40 LED ,more throwing, will add magnet tail and reverse charging
TheIntruder
Last seen: 6 days 11 hours ago
Quote:
Features will:
UI improved—anduril 1/2 ???
Charging&Reverse charging 2A
Body color- black/purple/metal gun/champagne/Christmas red
I can take or leave Anduril, but the developer, TK, has stated that v1 has been deprecated, is many patches behind, and going forward v2 should be the only one considered for use, so heed that advice at least if the decision is made to proceed with it.
Given the relatively low capacity of 18650s, which limits its utility as a power source, perhaps other than in emergency duty, so I don't see much point in adding a reverse charging feature.  I'd rather see such effort and cost  put toward improving the fundamental, primary functions of a flashlight, such as optimizing the regulation and efficiency of the driver.  Even more so if it's going to be positioned as a "Pro" model with fancy UI.
Colors options are always welcome.
Tangra
Last seen: 11 hours 11 min ago
I think that FC12S (side switch version from FC12) is not necessary model. FC11 is good enough light. May be SST40 5000K version for more power.
It will be better to produce FC12 with 21700 battery.
Msf
Msf's picture
Last seen: 1 week 2 days ago
Side switch being able to turn the light on-off instead of only changing modes would be great.
Let the Darkness become As Day.
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 59 min 12 sec ago
The question is, which option is most desired?
A) Side switch works always, regardless in which condition the tail switch is. That would require a dual-tube design like Acebeam's T36.
B) Side switch only works when the tail switch is in "on" state. That would be some kind of "soft-off" mode like Sofirn's C8F or SP70. Downside is parasitic drain in this soft-off state.
Omega_17
Last seen: 2 days 15 hours ago
Its fine as it is . I much prefer the option B, we don’t need more clutter when there is already a button dedicated for that!
icpart
Last seen: 1 day 15 hours ago
I like that. Also please add OP reflector as option over smooth one.
TIFisher
Last seen: 9 hours 39 min ago
To cherry pick the suggestions thus far; I like the idea of a proprietary side switch, SFT-40, Anduril V whatever, magnetic (or non-magnetic low profile) tail cap, expanded color options, and 21700 capacity. I personally would not make use of a ‘reverse charging’ option, and agree that driver regulation is paramount.
You’re on the right track. I’d assuredly be a player if it comes in around the $30 USD mark.
story
Last seen: 7 hours 15 min ago
I have trouble finding the on button in my FC11 by feel.
Can the button light be on when not in use so it’s easier to find?
Wurkkos
Wurkkos's picture
21700 version with side switch, we planing update from TS21, use reflector instead of the triple TIR Optics, combine the two models seems a option too
zaxar0580
zaxar0580's picture
Last seen: 1 day 3 hours ago
I like it, just add neutral LED! I do not like cold
alumenum
Last seen: 1 week 3 days ago
I don’t like sideswitch-only lights. I prefer tailswitch.
The only things I would do to improve the FC12 is widen the head and reflector ~2-3mm to be in line with the width of the heatsink for even more throw, add crenelated bezel, and add regulated driver. I’d pay $45-60 for that.
And keep the purple. LOVE the purple! I’ll probably buy a 2nd FC12 if you release other cool bright colors like green, blue, orange, red, etc. Especially like a lime/bright green would be cool.
If I wanted a sideswitch FC12, I would have got a FC11 or sofirn SC31.
Now, a tailswitch TS21, THAT would be cool! And in purple too! Smile
whokilledJR
Last seen: 1 day 36 min ago
Wurkkos wrote:
TIFisher wrote:
To cherry pick the suggestions thus far; I like the idea of a proprietary side switch, SFT-40, Anduril V whatever, magnetic (or non-magnetic low profile) tail cap, expanded color options, and 21700 capacity. I personally would not make use of a ‘reverse charging’ option, and agree that driver regulation is paramount. You’re on the right track. I’d assuredly be a player if it comes in around the $30 USD mark.
Carlco optics work much better than a reflector and produce a much better beam in more compact lights. Reflectors have too many imperfections and harsher transitions on the outer edge.
Why not make a version of the TS21 compatible with carclo optics? Far superior beam wise and gives the options for users to use different optics to find different beam patterns to suit their needs.
http://www.carclo-optics.com/optics-for-leds/10mm/
file:///C:/Users/Admin/Downloads/10508-60523_Rev-4B_Customer.pdf
Wurkkos
Wurkkos's picture
yes, single LED TIR edition TS21, good idea
my9221
Last seen: 1 hour 32 min ago
Just purchased a purple one with battery from wukkos.com. An extra 15% for only $25.49. Big Smile
Omega_17
I replaced the black switch with a blue one to match the blue ring. Now the aesthetics are much better. Cool
IMG-20210904-144924
