Maglite ML25LT - rarity short review
27 posts / 0 new
WestBam
WestBam's picture
Last seen: 1 week 3 days ago
Dear All,
You can find a full, more detailed review on my flashlight blog. Use google translate. Original language: Hungarian.
In this short article I will show you the Maglite ML25LT 2C flashlight.
Brand: Maglite
Model: ML25LT
Emitter: Cree XP-E2
Luminous Flux: 192 LM
Max Beam Intensity: 28473 cd
Switch: twisty
Battery: 2x C alkaline
Modes: 2 (high, eco)
Lens: Policarbonate
Waterproof: IPX4
Unfortunately, we do not receive an accessory for the flashlight. This model is sold in blister packs, there are no battery in the package.
It can be disassembled into 3 parts, but not the usual structure.
The head does not include the LED and driver, only the reflector, lens and bezel ring. The reflector is usually made of plastic. The lens is made of polycarbonate. Rubber seals are used everywhere.
The body is tubular, including the Cree XP-E2 LED and the driver in a plastic insert, not disassembled. The body is made with glossy anodizing, the pattern is slightly textured, not slippery.
There is nothing special about the tailcap, it has a simple current-carrying function. It uses a large steel coil spring.
Size comparison: C alkaline battery, Convoy S2 +, Convoy C8 +, Maglite Mini Pro Plus, Maglite ML25LT
No heat or heat is experienced during use, the LED is not overdriven. The horizontal axis indicates time, the vertical axis the temperature in ° C. Convert to Fahrenheit formula is: ° F = ° C · 1.8 + 32.
100 meters away is the tree on the right with an A4 white sheet on it. This was the target easily lit up so far by the Magite ML25LT.
Much more spectacular is the test at a distance of 200 meters. Because that’s what the Maglite ML25LT illuminates.
Conclusion: To my surprise, a whole usable flashlight is the ML25LT. Candle mode is unique in this size because you know it too. This lamp is quite a good thrower with a battery. There aren’t many complicated modes of programming. Just easy to use. It can be a great choice for older people.
You can buy: maglite.com
Edited by: WestBam on 05/20/2020 - 07:31
xxo
Last seen: 1 hour 19 min ago
Thanks for the review!
The ML25LT is my favorite budget light. The beam pattern on these is outstanding (big spill that’s just bright enough for a wide view up close without too much glare with a hot spot that throws real well for distance). The low mode on the 2C is great for indoors/up close and for candle mode. I find high too bright for candle mode – I just ceiling bounce it in high mode.
BTW the 2C ML25’s run well on single 18650’s or 21700’s. A good 3400 mAh 18650 will match a pair of Soshine 5500 mAh C cells for run time and a 5000 mAh 21700 will run a good bit longer. I use my own 3D printed adapters for these – in fact I have adapters to run about 7 different kinds cells in addition to the original C cells.
wle
wle's picture
Last seen: 3 hours 1 min ago
what does it cost?
prelim search says $15 to $20
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
xxo
wle wrote:
what does it cost?
I think $20 is about right, give or take a few $.
WestBam
WestBam's picture
wle wrote:
what does it cost?
It is quite expensive on the Hungarian market.
Roughly ~37USD the ML25LT and also one of the cheapest Maglite flashlights. Solitaire ~25USD, Mini Pro Plus ~ 57USD, ML50LX ~ 99USD, ML300LX ~ 105USD.
But a Maglite is worth all the money to me Cool
xxo
Same with me – if I had to pay more for Mags, I would still buy them, maybe not as many but, I consider a ML300 and /or a ML50, a 2C ML25, Solitaire LED and a 2 AAA Mini Mag LED to be must haves.
I started out with Mags back in the day, moved on at times to Streamlight, Surefire and others, but I always come back to Mag – I like that Mags are simple, well made, affordable lights that just work and I get more enjoyment out of using them.
samgalax
Last seen: 7 hours 49 min ago
I also love maglites… but….
2xAAA minimag a must have?? Why??? The newest model is single mode and 111 lumens…
Do you have it? Explain why please.
Please SUBSCRIBE to my youtube channel (flashlights, electronic gadgets and various stuff..)
https://www.youtube.com/channel/UCCF3RcoQ3Ff05Cr4-Gg5qAw
I am a beginner. So please help me to make the channel "grow up"
Thanks!!
xxo
Lumens are not an all that important measure of flashlight performance. Beam pattern and cd/throw are where it’s at for me. The 2 AAA MM LED I use most is an older 98 lumen version – I prefer it over the 111 lumen version because it throws a little further.
The main reason I consider the 2 AAA Mini Mag to be a must have is the beam pattern: wide spill for up close and a tight spot for distance. And the 2 AAA form factor is a great for carry in a shirt pocket. I am not much of a fan of the Mini Mag Pro 2 AA’s – too much glare for up close, spill beam is too bright and too small. The PRO Plus is better than the regular PRO because it has a low mode, but on high mode I consider these to be outdoor lights. When I am heading outside I am more likely to grab a ML25 which blows away the MM PRO for throw and beam pattern in a light that is about the same length but chunkier. If I need something smaller, it is back to the Mini Mag 2 AAA, with it’s better beam pattern and decent for a small light amount of throw.
samgalax
The 98 lumen has more throw than the 111?
Specifications say that the 111 lunen version has more meters of throw than the 98…
Thanks!!
xxo
The 98 lumen was listed 4148 cd/129 Meters on the package and the 111 lumen 2712 cd/ 104 Meters.
samgalax
My bad!
Sorry for hijacking the thread.
However I consider the ml25lt one of the best maglites of today… If money were not the problem… I would have most of the maglites and other brands…
Thanks!!
Chatika vas Paus
Chatika vas Paus's picture
Last seen: 3 hours 37 min ago
Where is the switch in this light? Or is it rotary like mini-mag?
WestBam
WestBam's picture
Yes, twisty (rotary) switch and candle mode like mini mag.
xxo
Another thing I like about the ML25 is that it’s fat enough to get a good grip on – makes it easy to twist on/off with one hand.
xxo
The ML25 makes a good light to keep for emergencies, loaded with a couple of L91 ultimate lithium AA’s or even a single CR123A in adapters it can be stored ready to go for decades with no worries with parasitic drain or leaking cells.
With adapters, it can run on anything from AAA’s to 21700’s.
Chatika vas Paus
26650?
WestBam
WestBam's picture
26650?
It doesn’t fit in the tube. Too wide.
xxo
Yup 26650’s are generally too fat for C cell Mags.
26650’s work great in 2D LED Mags.
radellaf
Just got one of the ML25LT and I’m not understanding the mode switching. It has a high (1.4 amp), low (250mA), and lower (150mA) mode. It usually switches between low and lower if you just keep turning it on and off. Sometimes, if you wait a few sec or are turning it on for the first time, it’ll come on in high. So you sometimes get hi-low-lower-low-lower… and sometimes low-lower-low-lower… It may come on in lower sometimes, it’s hard to tell. A solid 500mA medium would have been useful. The two lows are pretty close.
Am I missing some trick or is there a random element? It doesn’t seem like the last mode it was on determines what it’ll start with.
Manual that came with it is for the one-mode. Manual on the website only mentions two modes “Turn flashlight on (by twisting the head) and you have Full (100%) Power Mode. Quickly turn flashlight off and on again to access Power-Conserving (15% Power) Mode”
I guess it is always supposed to come on in high if you leave it off long enough?
I was expecting it would just go high-low-high-low…
xxo
There should be only two modes – high and 15% low. It comes on in high first but you can switch to low by twisting it off and back on all within about 1 second – just enough time to do this if you are quick. If it takes you more than about a sec, it will comeback on high instead of low. In other words, a quick twist on/off/on within 1 sec, will go to low mode.
Note that you have to be fairly quick to twist on/off/on or you will miss the low mode. And that indoors it is often hard to tell high from low, especially if the batteries are starting to get weak.
radellaf
It definitely is not coming on in high first, every time. Maybe half the time. Guess I got a weird one. Fine with me, I guess, since high is a bit…high.
samgalax
Bad connection… Dirty threads… Bad switch…
Thanks!!
radellaf
I guess there could be some switch bounce that knocks it out of high but it doesn’t seem to blink at all. Stable output at each setting. (and there really are three distinct modes, by the ammeter, if not easily seen on the wall)
Messed up firmware, if anything. I’m happy with it, just good to know there’s something messed up about it rather than me not being able to figure out some trick. If it dies, the ML warranty is pretty good.
xxo
Have you lubed the threads? Mags usually come fairly dry from the factory and may snag a little. Also check that the tail cap spring is snapped in place properly and that all of the bare metal contacts are cleaned and lubed. And of course check your batteries tp make sure they are good.
radellaf
I’ve checked all that, it’s just the driver. I ordered a 3 C-Cell one along with a 2C ML50LX in foliage green, and warm white 2xAA, so it’ll be interesting to see if that one behaves as it should. I actually prefer the way the 2C is working. High overheats the LED pretty badly, and the 250mA mode is both bright enough, easy on the LED, and would work with alkalines in AA-to-C adapters. Unless it’s going to die from some driver fault, I like it this way.
Thanks for the help!
Rusty Joe
Rusty Joe's picture
Last seen: 22 hours 34 min ago
Mode confusion kills it for me. Long gone are the days of reliable, one-mode Mags, apparently.
radellaf
I like two or three modes, though it is easier with the ones with a button so you can click right to what you want. The 2C is just a keep-in-the-kitchen kind of light so most of the time it doesn’t matter what it starts at. Not like we’re talking a 1000lm pocket-roaster that’ll blind you if it comes on hi when you don’t expect.
I’m sure Mag would replace it if I asked. Bought direct from them so I’m sure I’d have to send it back and it’s not worth the trouble for $16 (20% coupon at the time). Amazon might just replace it with no hassle.
