More New Cree Goodness coming....
Well that’s sucks…Hopefully we’ll see it in lights like the MF01S. I really want something like an X50 but cheaper.
yea, that is a friggen fail if I ever heard of one.. I know the flashlight industry is peanuts to a mfg like Cree, but that just sucks all the way around. I mean there are drivers made and that will be made, but it's another workaround and incompatibility issue..
anyway, yea a 2s2p massive light would be cool, with 3k or 5K tint :))
although- now I'm thinking- I can put one of these setup for 12v in a K1 (xhp35 hi model). In fact, I will be doing that. Once they are available more locally or with less shipping costs
Digikey has listed the XHP50.3 and XHP70.3 recently, MOQ of 1 and lead time of 10 weeks.
I am so confused by that website.. I hate being stupid lol. I will eventually order some 50.3 in 5K & 3k. Anyone who wants someone to "go in" with them, I will. I'm in the US
Just dropped by to tell you that Kaidomain is listing an XHP50.3 HI for pre-order. The only additional information listed is “Cree XHP50.3 HI J4 3A Neutral White 5000K”. Click/tap here for the official Cree XHP50.3 datasheet. High CRI options galore.
Nice, hope some good CRI90+ variants arrive soon at the usual retail channels.
Can’t wait!!
They’re now showing several different XHP50.3 and two different XHP70.3 in stock and can ship immediately. Anyone order some yet?
Nice, especially there are several 90CRI XHP50.3 HD in stock unfortunately no HI (high or low CRI)
The thermal resistance of the 50.3 is much improved over the 50.2, .4°C/W vs 1.2°C/W.
These are what I want
Nice ! 4500K, 90 CRI, 6V/12V
We should take bets on what the duv of this bin will be
And they’re going to stock it in December. I already know what I’d put it in.
It’s domeless, so at least it will be consistent
oh, quite interesting, flat XHP50.3
Thanks for sharing this information, thefreeman and the rest of you. I made my own, specific search for CRI90+ HI emitters at Mouser EU.
Wellp, out of 39 entries only the H2-45G (3-step 4500K) is available in small quantities. Other interesting easywhite parts are listed, like this F4-27H (F4 bin, 2-step 2700K), or this G2-27H (G2 bin, 2-step 2700K), these are “incandescent” while as close to the black body locus as Cree “bins” them. The second page of the above search contains many 2-step emitters.
I'd love to get a few “warm” HI emitters, 3500K or 4000K tops…
Sat, 10/16/2021 - 16:16
Not super hopeful, but without the whole package phosphor pour it’ll probably be more uniform, both for HD and HI, slicing might be a good option for obtaining lower duv ”HI” (with slightly lower perf since apparently they use some sort of texture to improve light extraction on flat lenses), and without the need to dice them it’ll be easier.
Hey mate i ordered a few XHP50.3 HIs and the new MCPCB design has the two solder dots that sit beside the LED and they interfere with the LED gaskets sitting flush with the MCPCB, do need them?
Like excess solder beads? You can remove them with a razor blade
I think these have to be filled but not sure how much is needed because its in the way of the centering ring. See the two beads one on each side of the LED its below the J? Its meant to be there but it would be better of in a different place.
Even if you put solder in the R position its a bad spot for the centering ring.
Ahhh. Yes. Poor placement indeed. I’d take a mini flat file or even an emery board and sand the solder blobs down a bit. Also, while it may be a pita, grooves could be filed into the centering ring. At least they are 180° apart, so the second idea is probably best
