Hell no. Allett original. Fabric or leather. Creates two stacks of cards so it ends up thinner than anything else out there. Holds as many bills as you want in the bill pocket or in the extra large full size pocket. Not cheap now that they’ve got this new material but I’ll never use anything else. Did I mention that it ends up being thinner than anything else. I looked at a lot of different ones trying to find the thinnest wallet out there 10 years ago. It went through the wash a few months ago and nothing fell out. It was rolling around free out of the pants pocket in the front loading machine when I found it at the end of the cycle.
You can't compare the big flashlight in the sky to the little flashlight in your hand.
After doing many hours of research and then carrying it for 10 years. Allett has a design patent for the “original” wallet. So it’s more than a preference, there are some facts backing up my preference. Depending on how you are going to carry it, if thick is not a problem for you then I’m sure you are happy with yours. But that is not the best wallet for most people. If you’ve never looked at the Allett original then it’s easy to understand your confusion. Period end of story. Edit. The title of the thread was changed. My comments made more sense before the change.
Anybody have a recommendation for a nylon wallet? I keep looking at Spec Ops, but reviews referencing size limitations keep me from pulling the trigger. 50 bucks is outside my gambling limits. BTW, great review, Joe.
Edit: Sorry, Oli. Checked your link. Nice, but not for me.
I use a “card holder” and keep my bux separately. I hate bulky.
Did get a nylon wallet thingy, but haven’t used it yet for whatever reason. Buncha compartments for cards, coins, paper, etc., that gets nice and flat.
“Vegan-friendly leather”? Scares me that there is even such a thing.
It may not be obvious why the Allett “original” is so thin. The reason is the layout of the cards creates two separate stacks of cards when you close it. Almost all other wallets end up stacking all of the cards in the same pile when you close it. And there are no extra flaps and layers of material anywhere. Yes some cards get hidden but once you get used to your system and you know which cards are where and keep the frequently used ones visible it works good. So if you don’t want or need the thinnest wallet available then go elsewhere.
I have the leather version and I do love the slimness and the fact it is also good for carrying cash. It seems like most slim wallets focus on carrying cards with cash as a second thought.
Watt prevents the cards from spilling out if it’s inadvertently tipped too much in one direction?
PS. My leather trifold is setup so that my cards on both ends and in between are kinda friction jammed enuff against one another that this is prevented from happening. Also, there’s a driver’s license stand alone clear window in the middle also somewhat secured in the same fashion.
PSS. By far the most frequent reason why I show my driver’s license in that secured middle window (saves me from having to pull it out each time) is for age verification towards getting discounts at various retailers.
“In many things in order to truly understand the small picture you have to understand the big picture first.”
True Color Rendition (TCR)/Simplified Definition:
“On a scale of 1 to 10, with 10 being the highest rating, a TCR will equate to what true colors you see in sunlight vs the same object’s colors you see when illuminated with a flashlight. The closer the two are, the higher the TCR rating will be.”
The TCR Reference Standard is the Walmart Ozark Trail OT 50L , Model No. 6103.
It has a TCR rating of ‘10’. $1.00 including batteries.
Because the material keeps it secure and the non-solid structure doesn’t allow it to bounce out like the hard plastic ones do. Plus, officers always ask to hand them the license, never to show it in the wallet. That’s true anywhere.
“Because the material keeps it secure and the non-solid structure doesn’t allow it to bounce out like the hard plastic ones do. Plus, officers always ask to hand them the license, never to show it in the wallet. That’s true anywhere.”
Ok so cards don’t fall out. Good.
I have to show my Costco Card so much that I’d have to whip it out ad nauseum. A lot of unzipping, pulling out cards, zipping up again, fumbling about.
Besides it kinda reminds me of a little old lady digging coins out of her dinky snap pouch dealie.
IDK, man. I don’t think this thing rocks for guys ya know? I sure as hell wouldn’t flash it around certain Harley crowds. Unless it had a big as* chain attached to it.
Right now I only just show one third of the Costco Card sticking out of my trifold slot and they still let me in.
I’d consider your wallet if it had at least one clear window on the outside butt then with
all the pocket rubbing going on that clear flexible window would likely be toast pretty dam quickly.
Butt that’s just me. For sum tho’ just might be the best wallet out there.
Butt for me I have to show my Costco Card so much that I’d have to whip it out ad nauseum.
Right now I only just show one third of it and they let me in. I’d consider your wallet if it had at least one clear window on the outside butt then with
all the pocket rubbing going on that clear flexible window would likely be toast pretty dam quickly. Butt that’s just me.
I have the Spec Ops T.H.E. Wallet Jr. I’ve had it for years and love it. Plenty of card slots and room for cash. The “shark-bite” closure keeps everything secure. After maybe 5 years, it shows almost no wear. I spent a long time shopping before deciding on this wallet to replace my old one. It is a real good choice IMO.
Keep your nose in the wind and your eyes along the skyline.
Del Gue
That one looks a little thick for me. I carry one of those oddly shaped front pocket wallets and like it best. A pick will have to face me to try and take it. Plus, the bulk of a back pocket wallet while sitting messes up my posture and long ago caused pain. I suppose I could put something of equal bulk in the other back pocket to even things out, but I don’t like carrying things in back pockets so there’s that.
Great discussion, thank you all for bringing it up. I’ve been suffering with an expensive leather trifold my wonderful wife bought me for years. It seems, at times, to be as thick as it is wide. The huge bulge in my front pants pocket where I keep the thing would be more attractive if it wasn’t a square shape.
Thats why I find the Allett original design intriguing. Interesting that if you buy it direct you pay shipping whereas if you get it off Amazon it’s free shipping. Love this: “MONEY-BACKGUARANTEE
If you don’t love your Allett, return it to us for free in the first 30-days for an immediate full refund.”
The issue with the smaller designs, such as clips and such, is that you can’t fit what you want in them. I’m sure the Allett is top-game, but I can’t help but listen to complaints about size and not being able to pull out cards when needed—exactly what you never struggle with with mine. I do understand going minimalist and not wanting to carry much of anything. It’s just not doable for me.
I like a traditional wallet. All of them have tradeoffs. You have to ask yourself, what do you take out of your wallet the most often? The wallet RJ shows makes you have to unzipper it for each and every item. Not ideal. Yes my driver license does stick but I almost never have to remove it. As for cc’s, I only have two and they work well for the traditional wallet.
This one doesn’t work for me. I need more space for money bills.
You’d be surprised. I’ve carried $400.00 before.
My Youtube Channel
joeholmanonline.com
Good to know people have their preferences.
My Youtube Channel
joeholmanonline.com
link
My Youtube Channel
joeholmanonline.com
https://www.all-ett.com/products/nylon-original-wallet it is available in leather also but that’s going to be slightly thicker. Read all the reviews. Some people do nitpick a little, but they are not giving it up.
might be the end of the story, but not the end of the movie:
Thanks for the info Rusty Joe and for sharing your impressions. Looks like it's $44 for the nylon version with no zipper --
Your link leads here: https://www.all-ett.com/collections/rfid-wallets/products/nylon-original-wallet?variant=40213941452964
https://www.amazon.com/Allett-Original-Wallet-Green-Blocking/dp/B08Q8QNQ36
I could not find the one you demonstrate in the video with a zipper.
Here's the one I have (Eagle Creek brand) that I've had longer than i can remember, at least 10 years, and it's still holding up well. I don't want a zipper as the Velcro on mine holds great and is super easy and quick to rip open and get what i need or show my drivers license. A zipper is a little cumbersome in my opinion. https://www.amazon.com/Credit-Bifold-Wallet-Rainbow-California/dp/B07CLH3P2H/ref=sr_1_52?dchild=1&keywords=eagle%2Bcreek%2Bwallets%2Bfor%2Bmen%2Bvelcro&qid=1630793293&sr=8-52&th=1
And I can buy two for the price of yours. To each their own I guess.
max
Looks nice, but I still like my 20+ year old leather trifold that has rounded out comfortably in my back pocket.
I’d rather use my flashlight around the house than turn on the lights.
Rusty,
True Color Rendition (TCR)/Simplified Definition: “On a scale of 1 to 10, with 10 being the highest rating, a TCR will equate to what true colors you see in sunlight vs the same object’s colors you see when illuminated with a flashlight. The closer the two are, the higher the TCR rating will be.”
My Youtube Channel
joeholmanonline.com
Just try it. The cards are secured nicely.
My Youtube Channel
joeholmanonline.com
Del Gue
Thanks Rusty Joe, but one of my requirements for a wallet is that it fits comfortably in my pocket.
My current wallet is the DAX: https://www.allocacoc.com/Home/Home/Product/category/category_id/25
I replaced my first one after several years because the microfibre was looking a bit shabby but you can get them in other materials.
I carry mine in right side pocket. No issues.
My Youtube Channel
joeholmanonline.com
I like Big Skinny wallets.
The model that I like holds a bunch of cards, and is very thin.
I haven't been able to find any other brand that's even close to as good as Big Skinny.
Big Skinny is kinda pricey, but sometimes they can be found relatively cheap on eBay.
How to Post Images on BLF // Many knives for sale (USA only)
How to move a thread // raccoon's light reviews
Rusty Joe – can’t get yours in Australia but AliE has something similar – https://www.aliexpress.com/item/4000720920548.html?algo_pvid=7adb0049-c4...
Thats why I find the Allett original design intriguing. Interesting that if you buy it direct you pay shipping whereas if you get it off Amazon it’s free shipping. Love this: “MONEY-BACK GUARANTEE
My Youtube Channel
joeholmanonline.com
Here's my wallet, but Big Skinny has plenty of other models available...
https://www.amazon.com/dp/B006LQCJWE
Big Skinny World Bifold
My vote for EDC and travel. I added a slim stylus/pen into the crease and been happy for ~10 years.
https://youtu.be/LmBBJDzlN5U This guy just reviews wallets, probably over a hundred on his channel. Allett Leather Original.
This couple has actually used it.https://youtu.be/zb7EOEKvJ1k
