I have the triple SST-40 5000K WT3M prototype, but the WT3M is smaller in both head width and length, lighter (128g vs. 181g). It's pretty close in size to a D4SV2 actually, but thinner tube and 11g lighter (D4SV2 w/SS bezel). They kept the light weight in mind in these designs, like they did with the WT90.
The prototype is very close to the production release. I should be able to post better pics of the WT3M next to a EC03.
ANSI throw I assume? Single reflector will out throw a triple reflector of the same width, but the WT1M has a bigger head to maximize throw, while the WT3M is more for flood, so size isn't as important. The WT3M even has an OP reflector to soften the hot spot and make a more uniform beam, and with the 3 reflectors it doesn't need depth so overall, the WT3M has a smaller head.
I just ordered a WT1M w/XHP50.2, silver of course...
Never mind, after looking at the pictures again it seems the battery tube is approximately the same. The head of the flashlight is where the extra length comes from. For some reason, I was thinking one had a longer battery tube and was confused since both use a 21700
Too bad the 50.3 won’t be 3V in hiCRI… I like the 3M, but the days of low cri flooders are over for me. Wish I could support WT with my $ but not this time. Fingers crossed they knock the SFT40 model out of the park. Maybe something in the 50-55mm class to fill in the dead zone between C8s and 60mm lights. 250kcd and 2200lm in the smallest package possible might be a hot item.
agreed about the sft40 model in that size. I have a sft40 in a Emisar d1s with a 50mm head and it is a perfect setup, also the gt mini would be like that too. A 21700 gt mini sized light would be AWESOME
Yea, it's not that kind of flooder for sure, more like a power flooder but with a nice hotspot, big, but not as big as you get with the tir optics. I should take some wall and beam shots. It's really a decent looking smooth beam with the OP reflectors.
those look awesome, but will wait for version on SFT40 emitters
almost bought 2 of them yesterday, but stopped myself last minute (I already have EC01, and FW21 pro on XHP50.2, so very similar flashlights)
