BUT please still make it with only ONE 26800 battery tube as well, Simon. please. I know many like 2x26800 or 2x26650, but that is enough for me not to buy. one battery , 26800. such a beautiful design. the raw silver is perfect. my L21a is a light i will never get rid of.
Question for Simon
Are you able to implement below 0.1% mode on most of your drivers?
My 4x amc7135 draw ~ 3mA,it’s too bright indoor on late night. Need real firefly mode
And i got the driver sample for M21D with KW CULPM1.T/SFT40 ,It has a reverse charging function. It will also be put into production soon.
The test result of the 26800 sbt90 driver is not good. The driver manufacturer claims that the current is around 22A, but I think this is theoretical data obtained in the laboratory. In the actual test, due to the internal resistance, I only got 19A. When I tested the charging function, the driver board burned out.
Very low current requires high-precision chips, and the price is relatively expensive. You can consider using frosted lenses or TIR lenses to diffuse the light spot, which will cost much less
With the large head I think this is more of a 2*26650/2*26800 lights. A bit smaller head for single cell build, such as a heavier and finned L2 or M3. But you do have a support base for it as is. So Simon have you become a 26800 convert? I believe it’s what the 26650 could be if newer tech was done to it.
I did the same with 90° lens and 2.8A driver,a bit too high. Hope will be lower on T2 Driver and on the next Quad light CCT and AA headlmap.If have true firefly mode cost me a pairs $ more, no problem
Has anyone done any measurements on the current T2 drivers with 219B? What’s the lumens on 1%?
I managed to find one of Simon’s staff member shops is still selling a few units of 219B T2. Wondering if I should just spring for a few in 3000K, 3500K while stocks last - or just wait until Simon gets new drivers in his main store.
Hi. If someone have idea can I order that black version of S2+ metal switch. I ordered my new red S2+ yestarday and I want it to have one of this black metal switches
Oh I see… That’s possible. I guess Simon can do it easily for you. Just add a note in your order. Now that you have ordered, maybe message Simon at AX Store if it has not send out.
Ok, now I get it! My bad, I understood it wrong :zipper_mouth_face:
I would ask Simon if can sell you one! The shiny ones are for sale out there, but I am not sure about the black one.
