【convoy】H4 and B35AM options are updated
How about using a headband to fix C8+ L21B on the head? Is it too heavy?
And i got the driver sample for M21D with KW CULPM1.T/SFT40 ,It has a reverse charging function. It will also be put into production soon.
The test result of the 26800 sbt90 driver is not good. The driver manufacturer claims that the current is around 22A, but I think this is theoretical data obtained in the laboratory. In the actual test, due to the internal resistance, I only got 19A. When I tested the charging function, the driver board burned out.
I can produce additional 2*26650 and 2*26800 tubes, but in this case, the charging function is not available.
Very low current requires high-precision chips, and the price is relatively expensive. You can consider using frosted lenses or TIR lenses to diffuse the light spot, which will cost much less
With the large head I think this is more of a 2*26650/2*26800 lights. A bit smaller head for single cell build, such as a heavier and finned L2 or M3. But you do have a support base for it as is. So Simon have you become a 26800 convert? I believe it’s what the 26650 could be if newer tech was done to it.
I did the same with 90° lens and 2.8A driver,a bit too high. Hope will be lower on T2 Driver and on the next Quad light CCT and AA headlmap.If have true firefly mode cost me a pairs $ more, no problem
Has anyone done any measurements on the current T2 drivers with 219B? What’s the lumens on 1%?
I managed to find one of Simon’s staff member shops is still selling a few units of 219B T2. Wondering if I should just spring for a few in 3000K, 3500K while stocks last - or just wait until Simon gets new drivers in his main store.
Okay, I will pay attention. But compared to the high price, what is worse is that the chip is out of production.
Hi. If someone have idea can I order that black version of S2+ metal switch. I ordered my new red S2+ yestarday and I want it to have one of this black metal switches
I wanted a Black S2+ with metal switch too. But no, it doesn’t have.
I ended up buying the Lighted Metal Switch as an accessories and put it in… The Lighted Metal Switch can only fix on Rubber Tailcap S2+…
I know for that metal switch conversion kit for S2+ but I wanted that black metal finish button not raw metal color from picture.
Oh I see… That’s possible. I guess Simon can do it easily for you. Just add a note in your order. Now that you have ordered, maybe message Simon at AX Store if it has not send out.
Not from Convoy, but check this:
https://www.aliexpress.com/item/33018646981.html
Oops :blush:
I mispronounced. I wanted metal switch with black color, not flashlight color body.
Ok, now I get it! My bad, I understood it wrong :zipper_mouth_face:
I would ask Simon if can sell you one! The shiny ones are for sale out there, but I am not sure about the black one.
I wonder if Simon will ever sell a triple S2+… I would love one but don’t have the skills to build it myself.
It would be a must have.
I think an S21A triple is in the works
That’s excellent news!!
Hey! just noticed the presale for 940nm IR S2+ (https://fr.aliexpress.com/item/1005003202811071.html)
I will take it as soon as it is available :face_with_monocle:
Will it work with lighted metal switch ? (https://fr.aliexpress.com/item/1005002370385808.html) : is the driver compatible? and the body ?
