Ok, now I get it! My bad, I understood it wrong :zipper_mouth_face:
I would ask Simon if can sell you one! The shiny ones are for sale out there, but I am not sure about the black one.
Is there a way of removing the AR coating from the glass on my convoy s2+?
I have the convoy s2+ with the 219b sw45k emitter and I noticed that when I remove the glass, the tint looks slightly better. When lighting up white objects with the glass in place they look a little green, and I suspect it has to do with the AR coating.
Same principle like using a razor to scrape your old registration sticker off your windshield. Glass might be brittle, but it’s incredibly hard. Steel wool works nice, but it’s tedious to do, and you gotta get both sides if it’s coated on both sides, too.
DON’T use sandpaper of any kind, not even fine grit, as that is harder than glass, and will frost it.
I only tried it (steel wool) because I was okay if it’d frost it, as I’d likely be using diffusion film anyway if I wanted a flooder. Wasn’t an S2/S2+, but I vaguely vaguely vaguely recall it was one of the older Sofirn SPs that had AR coating on the glass. Might be mistaken, though.
Anyway, it came out fine, enough so that I can’t even recall which light it was. Ie, not “damn, I ruined the glass on that light…” or anything.
Sit back and veg out watching teevee while doing it, as it’s tedious and takes quite a while.
Hey Funtastic whats your plans?
I was looking at buying a Z1 and fitting one of those 10w 850nm IR led into it and see how it goes as I think my IR is the weak link with my old scope.
Before I go out and buy a new NV scope for my new Air gun “rabbit hunting”. I would like to try a better IR light on my old trusty Photon XT.
