Test/review of Samsung INR18650-35E 3500mAh (Pink) 3
10 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 week 3 days ago
DSC_4617
Official specifications:
  • Nominal capacity: 3500mAh
  • Minimum capacity: 3350mAh
  • Nominal voltage: 3,6V – 3,7V
  • Charging voltage: 4,2V
  • Discharge current: 8A
  • Maximum discharge current: 13A
  • Charge current: 0,6C 2000mA
  • Discharge end voltage: 2,65V
  • Pluspol: FlatTop
  • Chemistry: LiNiCoAlO2
  • Diameter: 18,55mm ± 0,1
  • Height: 65,25mm ± 0,15
  • Weight: 48g ± 1
Samsung%20INR18650-35E%203500mAh%20(Pink)%203-info
This is a new 35E cell (Supposed to be 2021) from Samsung where there the cell includes a warning. It is a high capacity cell.
DSC_4618 DSC_4619
DSC_4620
DSC_4621
Samsung%20INR18650-35E%203500mAh%20(Pink)%203-Capacity
The two cells tracks fairly well, the cell can handle the rated 8A.
Samsung%20INR18650-35E%203500mAh%20(Pink)%203-Temp-5.0
Samsung%20INR18650-35E%203500mAh%20(Pink)%203-Temp-7.0
Samsung%20INR18650-35E%203500mAh%20(Pink)%203-Temp-10.0
Samsung%20INR18650-35E%203500mAh%20(Pink)%203-Temp-15.0
Samsung%20INR18650-35E%203500mAh%20(Pink)%203-Temp-20.0
Samsung%20INR18650-35E%203500mAh%20(Pink)%203-CapacityTimeHours
Samsung%20INR18650-35E%203500mAh%20(Pink)%203-Energy
Samsung%20INR18650-35E%203500mAh%20(Pink)%203-PowerLoadTime
Samsung%20INR18650-35E%203500mAh%20(Pink)%203-TripCurrent
Samsung%20INR18650-35E%203500mAh%20(Pink)%203-Charge
Discharge-Samsung%20INR18650-35E%203500mAh%20%28Pink%29%203-pulse-1.0%2010%2010-IR
Conclusion
This is a good cell, performance is better than the 2020 cell I tested and better at high current than first 35E cell I tested.
Notes and links
The batteries was supplied by reader for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
raccoon city
raccoon city's picture
Last seen: 2 min 14 sec ago
Location: Palm Desert CA ~ West Coast is the best coast
"Never install, carry or handle."
I haven't heard that one before.  :BEER:
MascaratumB
MascaratumB's picture
Last seen: 5 hours 23 min ago
Thanks for the test HKJ Wink
Seems a good one to use in powerbanks and flashlights with moderate “high-drain”.
thefreeman
thefreeman's picture
Last seen: 2 min 8 sec ago
Thanks for the test. Is it a higher cycle life version like the 40T3 ?
Would be nice to see the datasheet.
funwok
Last seen: 3 weeks 11 hours ago
Thanks for your tests man! Always appreciated!
Th558
Th558's picture
Last seen: 41 min 5 sec ago
According to Vapcell, their new T42 beats the 40T in runtime and performance. Any chance of testing it? Would buy one but I’m in the UK so can’t order just cells on their own.
HKJ
HKJ's picture
I have some Vapcells in queue, but not the T42 and I do not know if Vapcells have or will send it to me.
Superstocker
Superstocker's picture
Last seen: 3 hours 54 min ago
Thanks HKJ!
stephenk
stephenk's picture
Last seen: 2 hours 37 min ago
Thanks for the review. Good to see products improving.
Caleb
Caleb's picture
Last seen: 4 min 30 sec ago
Thanks for another test!
The discharge curve looks similar to the Sanyo GA… maybe even a little better.
