Perfect setup imo. But note to self and maybe others. Make sure to use a half drained 14500 battery @3.4v or less. When setting up brightness levels. Because upon first setup try my perfect cri 219b was trying to pull 4.1amps going angry pinkish/purple. So a half drained battery is a must for single emitter 219b settup!
Being this was my first time using H17Fx driver. There was a massive learning curve for this dumb dumb!
For others who may have wondered. Factory Convoy T2 4mode driver is pulling 2.25amps+, with full 14500 batt! But drops rapidly with voltage drop!
Hum, let me ask you: which PCB do you have? It is aluminium, or copper DTP MCPCB?
I have a T2 with the same driver and a Luxeon V2, and I have the FWAA with the same driver and a Samsung LH351D, both using Shockli orange cells (high drain) and neither turned angry blue/ purple. I know they are different leds, not the Nichia you are using, but still, the PCB can make a difference, eventually!
I flowed the 219b onto the new copper mcpcb, With leaded solder. My problem was that with learning how to use the H17Fx. Which is an awesome driver! I kept accidentally put it into direct drive, vastly overdriving the 219b. Imo sw40 led only likes about 2 amps. Surely not 4 amps in direct drive
Thank you, it took about one week of working during the evenings, but all components, including getting the instruments shipped, took many months. I almost gave up with this flash light.
Today I have modded my Z1 with glowing resin, it’s took about 15 minutes of ‘dirty’ work, maybe I’ll rework it later.
Really nice! I love Ledil Spot optics with the ’20. Also was thinking about a 7up version of this optic and 7 NM1s. Thinking it would out do a 90.2 in throw and lumens in same size setup.
Thanks, I bought a luminescent powder on Aliexpress and mixed it with UV epoxy resin, I think someone else here has done something similar.
It’s not so intensive glowing like a plastik gascets but it still pretty.
Yes it was that one, thank you.
(Poor it have a different tail switch not like S2+)
running H17Fx driver & sw40 emitter with op reflector! For daily use! Set @ 2amps max for now.
running mnt 17ddm fet + 1 & SFT40 emitter with smo reflector. Luckily I have spare M1 smo reflectors, to find best focus! SFT40 with mnt fet is able to pull 11amps+ at the tail. I left the tail sping un bypassed, for now to help regulate current.
If anyone has experience with proper guage wire bypass, to limit current to 9.5amps? Let me know!
A mod that’s been devised a long time ago (back in Jan. ’21). Replacing the stock SST40s (6000ºK) with Osram’s CULPM1.TG (HX Boost) in a Sofirn SD01.
I didn’t want to splurge on Convoy’s so I went with YinDing’s which were half price. Initially made a bench test and these are not up to specs. They go angry bluish-white at 8 Amps, but they do work well at about 6½ A.
I tried to measure the tail amps, but in no manner I could get any proper readings. Sofirn SD01 tail amp woes
Then there was the cracking open of this light. Sofirn is renowned for gluing things and I foresaw some problems. The 3 bezels have the smallest of indents and not much stick-out for any wrench. I had ordered a watch cover removing tool, but being of low quality, the metal prongs had to be replaced with some hardened ones. I used the shanks from some broken drills, 7/64” being a common pre-drill for #8 hardwoods.
The driver is readily removable via 3 screws and the board seems well laid out. There are 3 FETs and controlled via the MCU, no sense resistor here, all pre-programmed PWM. Switching via 4 HAL effect transistors, magnetic ring. I can’t figure out if / how the ring can be disassembled.
So they didn’t glue this end, may have a brute shot at the bezels? Well, first try the tool would twist open. So I had to add some retaining screws and trying my best, one did finally give. No glue! That was encouraging, but still a strong man’s test for the next two. After much fiddling and re-working the indents, got them all opened.
So, based on the manufacturer’s specs, the SST40 would have a Vf = 3.3 at 5 A. and the HX = 3.35 at 6 A. – I’ll try my luck as they are in the same ballpark.
The original MCPCB is 24 mm and my CULPMs are mounted on 20 mm. There is no retainer but a screw shank through the shelf that acts as an anti-rotational lock. This did catch my smaller board. The bezel with the reflector holds the star in place. The Osram footprint is 4 x 4 mm, I used a 5.7 mm x 7 mm (ID x OD) gasket being just 0.1 oversized ID. May not be perfectly centred, but there is an inner ring artifact. Something I’ve never encountered before. Dome-less, I doubt the LED be too deep in the reflector’s throat, but the lens doesn’t seem to have any AR. Stray reflections?
Here I have some beam shots. Living in an urban environment, my closest target is the parish church. This is not far enough for a proper thrower, but it gives me a relative idea of the beam characteristics.
The first pics are of the SST40, the seconds are the Osram HX.
The YinDing’s are above their power curve, the light is in the violet hue * on a white wall, but this is not seen outside. So I would suspect about 7 Amp draw. The lumens also took a hit, from 5900 down to 3300. I foresaw some lower values, but again the YD’s aren’t up to par. I suspect they are seconds from Osram, but that is just speculation. (Is there a W2.2 neutral white?) Also, at lower levels (Low, Med1, and Med2), the beam is considerable lime green – argh! The light does get hot faster than the SST40s.
As for throw; was 77 kCd, now is 87 kCd. A tad improvement.
In conclusion, I’ll play with this for a while, and revert back to the original SST40s. They are not too harsh, somewhat on the warm side for a cool white CCT. The YinDings may eventually find themselves in some future project(s).
Only one emitter was in the violet. Changed (had a four-pack) and the beam is better: ~3450 lm. which is in line with my other CULPM1 (Simon’s) in a K0B host.
The green is not as bad as I had originally said.
Sounds like you should wait for the next batch of SFT40s.
If not, I’ll say the Hank’s 3030 CSLPM1 have shown in my testing to deliver the exact same performance as Convoy’s HX. Definitely the better price to performance ratio. Over driving would still be a problem though. Thiiinn wires could maybe fix this.
That was my intention (the SFT40s) as the YD aren’t up to specs. But I wanted to do something this Sunday and being this was a project I wanted to tackle, cracking open the light was an adventure.
source for strontium aluminate powder and premixed into acrylic paint
this is one of my most fun applications:
the acrylic paint was applied to the mcpcb before I changed the LEDs… neither the heat of 1200 lumens, nor a 200C hotplate, have damaged the glow dots… fun stuff
a couple other experiments were less successful:
this is a Ti3 AAA:
the paint on the reflector cut the output in half, and changed the beam into a mule like flood… only useful at very close range
similar loss of output by painting a triple Carclo optic,
this is a fail:
and a pebble Tir optic painted with glow paint also failed to retain a useful beam and output
Convoy S9 had too narrow beam with Nichia 219B. It also had annoying yellow hotspot. I changed S2+ reflector in to it and it improved a lot. Had to narrow the base of the reflector a little. I didn’t know this flashlight also has ramping. I was little surprised when I first tried it.
