POST #2
Some history of how the yearly contest started:
Old-Lumens was a predominant member of Budget Light Forum who loved to make things, particularly flashlights and related items, with his own hands.
He went even further and encouraged others to do likewise by starting the annual Old-Lumens Contest which involves members making their own flashlight using only hand tools in one category or machines in another.
Sadly Justin (Old-Lumens) passed away in 2016, we here at BLF wish him to rest in peace and to continue to celebrate his life by hosting the yearly Old-Lumens Competition.
You may enter into only one of the three categories below with a single build.
Hand Made:
Your light must be made from scratch.
You must make a build thread, show images, give an explanation of the build progress. Remember we can only judge on what you show us in your thread.
No outside services are allowed.
Single or multiple emitter, driver and alternate power configurations are allowed.
Should be a portable and battery-operated light such as lanterns, headlamps and similar devices.
All small hand tools are acceptable, as well as these power tools:
Soldering gun/ station
Electric Drill/ Drill Press
Dremel style Rotary Tool
Electric Saws
Disc or Belt Sander
You may use some manufactured components related to flashlights such as reflectors, drivers, LEDs, MCPCB's, O-rings, switches, lenses, optics and clips.
You may not use manufactured flashlight parts such as a bezel, a body, a tail cap, a head or a pill. Basically anything originally designed specifically for a flashlight host may not be used.
Machine Made:
Should be a portable and battery operated light such as lanterns, headlamps and similar devices.
All machine shop tools are allowed, such as:
Lathe
End Mill
Programmed Automated machines
Standard 3D Printers
Plus all small hand tools
You may use some manufactured flashlight related components such as reflectors, drivers, LEDs, MCPCB's, O-rings, switches, lenses, optics and clips.
Modified Light Category:
Enter this category with a light you have modified or something you have modified for or into a light.
You must show us something that was modified by you and how it was done.
You can make a new thread or link to a mod you have posted on BLF within the stated time-frame.
You can build or modify by any means at your disposal and your mod can also be some form of self built flashlight attachment(s), clips, lanyards, paracord wraps, pouch or other related paraphernalia.
Judging the entries and prizes:
Everydaysurvivalgear is supervising the judges and prizes.
The following points are the judging criteria used in previous years.
Skill Level/ Finished Build Quality: Judged fairly on the persons access to tools, materials and abilities. Is the finished build functional & looking good? Difficult to make? Was the build completed, started or no work done at all?
Uniqueness/ Inventiveness of the build: Is the light unique, one of a kind or does it operate in a special way?
Build Thread Quality: Did the contestant do a good job of showing and explaining to the forum how they did the steps in the build? Good thread organization, pictures and descriptions of the methods used?
Purpose Built: Was the light purpose built for a specific use? Is it a special new EDC, upgrade or something for use that simply can't be bought easily?
Technical Details: Including new driver firmware, PCB designs, new technical ideas, programming and special switches etc.
Problem Solving & Obstacles: Were any specific problems encountered, documented and resolved by the contestant? Documenting the obstacles and using the power of the BLF community to solve them is seen as a big plus!
Enthusiasm to Participate: Did the contestant give it their best shot even knowing they would be up against more skilled veterans? Did they support other contestants build threads by posting encouragement and even giving help?
Following the Guidelines: Did the contestant follow the rules and guidance given?
Shown Operational: Did the contestant show us the light operating, its functions, beam-shots, videos etc?
