I seem to be the odd one out here but I would probably make use of different flood/throw combinations. Sometimes you want lots of throw but need a little more light at your feet.
One option would be to allow this to be user configurable, like brightness ramp speed. This makes Anduril more complicated, so doesn’t come without down sides.
The you could set it like this:
0 - immediate switch between flood and throw
1 - still only flood and throw available but a quick smooth transition between the 2 for effect
2+ - slow down ramp speed so you can pick any combination
the whole discussion about the beam ramp is because
I don't have any 2 channel flashlight, if I want to see something far, I just go for TURBO. So from my perspective it was ment just as digital zoom feature, and we just set it once to our liking (not something for active use).
We must first discuss if we want
no beam ramp, all led go 100%
some implementation of beem ramp, it could be even instant on 3 levels, 100% flood - 0% throw, to 50% flood - 50% throw, to 0% flood - 100% throw, to preserve flood and throw working at the same time.
beam ramp, by ramping.
two channel flashlight, and instant switch between throw and flood.
I'm good with all, it will just change, if I use this feature actively, or just one in a while, depending on where I want to use it.
My vote is instant switching. I see the appeal of being able to ramp between them but I think the slow ramp would be annoying and instant switching would be better.
I’m impressed Terry. The first pass design is pretty well executed IMO. I really think the SST20 and SFT40 combo is the right one. Arguments could be made for LH351D, most notably the availability of 5700K 90CRI to better match the SFT, but the 3535 footprint allows this to be an option later.
Only idea I’m going to throw out there is a dual switch UI. One for throw, one for flood. Both with the same FC11 or Anduril UI. Already have two output channels, why not have two input channels? Curious what others think here. I can see it both ways.
That is really helpful, and we can also supply button top 21700, then we don’t have any issue with the battery.
Thanks Toykeeper for pointing out this potential issue, and tactical_grizzly for solution to solve.
Hi all, thanks for your constructive post/suggestion, now I am chating with Toykeeper about the throw/flood ramping, maybe not smooth from throw to flood, but ThrowOnly—-FloodOnly—-Throw&Flood(3 emit styles) similar to tint ramp of LT1 Lantern, once emit style is selected, you can ramp from 1% output to 100%(this part is still unknown, should be workable, but still need confirm from ToyKeeper), feel free to comment how you think about this.
Please join us, comment, speak out your idea, and let’s make another great light to this community.
Hereby, I would like to thank Toykeeper a lot, words can not express well.
Seems like 2 switches, one for flood, one for throw, both with their own Andruil, might meet the needs of many customers.
In the FD65, the switches are for starting at low or high from off, and after on, and a short press of either ramps one mode lower or higher. Instead, one switch for flood, one switch for throw.
I’d really prefer an aspheric, or very tight TIR for the center LED, like the Olight marauder 2.
I like that idea of three steps (all throw, half-and-half, and all flood). It will still allow the use of both channels at the same time without taking too long to ramp between like it does on BLF LT1.
A few suggestions to make the light really high quality:
Regulated constant current driver.
Battery charge cut off around 4.14V. There are so many lights that needlesly push the batteries above 4.20V. The gain is minimal and the battery life is deminished.
Low Voltage Protection around 3V. The same as above + I have it when a light will keep going forever on 1lm, draining the last remnants of the battery. Let it turn off once it cannot sustain Low mode.
How many Amps will the Power bank function be able to give? With phones that support PD being the norm now, a PD supporting power bank at higher than 5V would be fantastic. Is there such a control chip that can be incorporated in the driver? It would make light realyl stand out, as there are a few lights now that have Power Bank fucntionality but none that I know that can do more than 5V, 2A.
Oh, er, another possible method to control it, without making it slow, is to just make the tint ramp faster. It currently does 255 steps at 62 Hz, so it takes about 4 seconds. But it could skip several steps per frame and ramp in like 1 second instead. It’d just be harder to precisely pick blends in the middle.
TK, would it be possible to skip several steps per frame towards the edges of the ramp, fewer as it gets towards the middle and not skip any steps in the middle?
I like that idea. Tint ramping takes a little too long for me on the LT1. A 1 or 2 second channel ramp on this light would not be too bad. Would it be possible to allow the user to choose between a smooth ramp and instant switching?
What about stepped channel ramping? We have discussed previously but think it is possible. It should inherit the main ramp (stepped or smooth) for channel ramping and inherit the number of steps if stepped ramping.
If the user happens to be at a low brightness where the number of steps they have selected is not possible, just lower the number of steps in the channel ramp. That’s basically what it already does right? It starts out with a ton of steps at the top of the brightness range and then lowers down to three steps at the bottom of the brightness range, right?
If you’re happy with more complexity in the code base then this is a way to please everyone. Attempting to please everyone with lots of options isn’t always the best strategy in the long run though!
