Amazon Deal Alerts & Discussion Thread
5282 posts / 0 new
koss
Last seen: 2 months 1 day ago
SemiNormal wrote:
There is this one for $199.https://www.amazon.com/GOLABS-Portable-Station-Generator-Emergency/dp/B0...
And this one on lightning deal for $169.99, but it’s smaller and more expensive.
More than happy with the AFTIME, may grab a solar panel when a deal comes along
Richie086
Richie086's picture
Last seen: 1 hour 32 min ago
Both of those are very good, but I love my AFTIME with its built-in MPPT module to optimize solar charging
Richie
gman9
Last seen: 54 min 2 sec ago
https://www.amazon.com/SuperFire-GT60-Flashlight-Rechargeable-Floodlight...
supfire gt60, less price than aliexpress by 10 dollar and prime shipped – 23.99
SemiNormal
Last seen: 18 hours 28 min ago
Richie086 wrote:
koss wrote:
And "this one":https://amzn.to/3jTuBPX on lightning deal for $169.99, but it's smaller and more expensive. More than happy with the AFTIME, may grab a solar panel when a deal comes along
The one I posted uses LiFePO4 batteries, btw.
xevious
xevious's picture
Last seen: 3 min ago
Airoff wrote:
EBL AA/AAA battery charger + 8 AA batteries for $10.99
https://www.myvipon.com/product/8806656?sl=3d11aa126bd62513c138b0d8b04be71a
I received my EBL 8xAA battery set & charger. Batteries did not come charged. They were pretty low. Charging took a very long time. After 5 hours and only half-way through, I let it continue overnight. I assume it may have been about 10 hours total.
Btw, once off the charger, these 1.2v cells were reading at 1.42v. Is that normal? Are they actually capable of this voltage, or were they overcharged?
Richie086
Richie086's picture
I removed mine from the EBL charger before they were fully charged. They were so hot, you could barely hold them. So I use my AA/AAA PowerEx charger instead.
They don’t get nearly as hot charging them at 200mAh – 300mAh setting. They typically come off the charger at about 1.42v and the static voltage reduces to about 1.37v.
Richie
TexasToasted
TexasToasted's picture
Last seen: 6 days 22 hours ago
“long press for 2 seconds to turn off”. That’s a big nope.
will34
will34's picture
Last seen: 1 day 5 hours ago
Edit: Just noticed in the photos it shows 6x cells which makes a 20,000mAh powerbank not 26,800mAh, but in the descriptions it claims it uses 21700? which according to this you might receive the 8× 18650 version or the 6× 21700 version https://www.ipoweradd.com/blogs/news/poweradd-energycell-series
Poweradd is a well known charger & powerbank brand but something must have happened because seems like they’re pulling all of their products off amazon and selling them cheap under energycell store. I do remember they have been offering free stuff for positive reviews in the past, maybe same fate as tacklife?
Anyways $13.59 for a 26,800mAh powerbank with 30W PD charging is a steal, well that IF you get the real poweradd product. There is also a 15,000mAh version for $10.
https://www.myvipon.com/product/8841534-Power-Bank-30W-Portable-Fast-Cha...
https://www.myvipon.com/product/8844898-Power-Bank-USB-Portable-Charger-with-amazon-coupons?sl=4b55a0b492cafee65e57a7e177e5998e
weklund
weklund's picture
Last seen: 45 min 20 sec ago
... Happy Landings ...
jeff51
jeff51's picture
Last seen: 1 day 20 hours ago
Just got one of these in:
https://www.amazon.com/dp/B08Y8M54M9?psc=1&ref=ppx_yo2_dt_b_product_details
No special deal. But was looking for something nicer than my $10 crappy metal vernier – I can’t read the darn scale – ones. And not as expensive as my Mitutoyo $$$ digital one.
There are jobs I won’t use the good ones for. Too chicken on FUBARing them up.
Not as smooth, but all metal, matches the readings of the big bucks set, Came with 2 extra batteries. Case clasps don’t feel like they will last very long.
$19.98 + tax. If they last, heck of a deal if you are in the market. Way ahead of the plastic jobbies that are just $10-$12 cheaper.
All the Best,
Jeff
Lightbringer
Lightbringer's picture
Last seen: 4 hours 9 min ago
Just don’t try to measure the length of a Li cell… LOL
jeff51
jeff51's picture
Been there – almost done that! Keep tape handy to keep the sparks at bay! Shocked
Richie086
Richie086's picture
Thanks for the heads up. I ordered both, but had to check out each separately for the codes to work.
Richie
xevious
xevious's picture
Interesting. I should qualify things a bit more, to help make the picture perfectly clear.
1. I tested one battery out of the box and it showed 1.27V with my basic digital battery tester. Now, since the cell is marked 1.2V, that should be considered a fully charged cell, right? So I thought maybe I should put it in the charger to see what is shown. Only 1 bar of power level was indicated.
2. I figured OK, I’ll put the whole pack on the charger. I have heard it’s good to “exercise” a NiMH cell at first use. Fully charge, deplete near empty, then charge up again. I didn’t expect that charging would take so long. I mean… cells starting at 1.27v, but the EBL charger showing only 1 bar?
3. It took way too long in my book for the charger to “top off” these cells. But, if there’s one consolation, I had temperature checked the batteries at several points. Never got hot. Barely warm even.
After charging they showed 1.42v. Next day, after “resting,” they’re now showing 1.34v which is in line with what’s considered “normal.” LINK.
AFAIK, there’s no such thing as a 1.5v AA NiMH battery. You have to step up to Lithium Ion to achieve that.
gchart
gchart's picture
Last seen: 7 min 56 sec ago
Been there, actually did that. Thank heavens it was a protected cell and the protection circuitry actually did it’s job. Yes, I’ve now learned to tape one end of the cell.
I got a great deal on mine 3 years ago. Monoprice had the Tacklife DC02 (metal, digital) for $8 and free shipping. They might not be high end, but they’re great. I probably use them at least once a week, especially now that I do quite a bit of 3D modeling for 3D printing.
FlashPilot
FlashPilot's picture
Last seen: 17 min 4 sec ago
Thanks! I ordered the 26,800 mAh version. You’re right… it’s a steal at this price if genuine and the cells still maintain their rated capacity.
shirnask
shirnask's picture
Last seen: 4 hours 7 min ago
Bought a cheap one with plastic jaws just for that. Just don’t forget and use the wrong one
gman9
Forsythe P. Jones
The trouble with those cheap digital calipers is they eat button cells. Parasitic current drain is significant enough that they will use up a cell in a few weeks or months just sitting there. Keep spare cells around. I found this annoying enough that I mostly use a 2 dollar Harbor Freight caliper now, and plan to get a crap-rate dial caliper ($10 at dx engineering) sometime. Meanwhile the HF one is perfectly fine for measuring batteries:
https://www.harborfreight.com/6-in-utility-caliper-63664.html
And since there are non-amazon links here, the 2 dollar 1aaa Halo lights are up again at Meh::Sidedeal:
https://sidedeal.com/deals/3-pack-halo-mini-lite-led-flashlights-15
They are that price til midnight EDT Sunday night, then back to $3. My review is here:
https://budgetlightforum.com/node/78871
I’m tempted to order some now, but I have several other 1aaa lights (Sofirn C01 variants) making their way from ali express. So I’ll resist. But these are decent gift lights since each comes in a little box with some useless accessories, and they are fairly bright by non-flashaholic standards. I am edc’ing one right now.
Lightbringer
Quote:
EBL AA cells, charger, blah blah blah
Finally got around to sticking the first 4 in my Ope, and they’re clocking in at an average 2050mAH each at 500mA, and pretty consistent (2072, 2069, 2035, 2049).
Didn’t try the charger, but in the Ope, they all ran fairly cool, nothing was heating up.
chops728
Last seen: 39 min 1 sec ago
This was a great fan ( The night of Ida) at the $13.99 price — Even better at $7
https://www.myvipon.com/product/8844112
jeff51
jeff51's picture
Good to know, time will tell…
The set I got has an on/off button. It turns on by itself it the jaws are moved.
All the Best,
Jeff
Richie086
Richie086's picture
Just received both of these power banks. Both arrived in brand new unopened boxes and are each about 1/3 charged. I have them on the charger now and I’ll run
them through a charge cycle and let you all know if any issues arise. Thus far, all seems perfect, but I will try to open the larger 30,000mAh version and see what
type of cells are inside it.
Richie
FlashPilot
Thanks Richie. Im looking forward to your discharge results and 30k tear-down. Does the larger one allow for fast charging the pack? And can the pack be charged via USB C?
Richie086
Richie086's picture
I’m charging the 30,000mAh PowerAdd from my large AFTIME power bank that I also recently received from Amazon. The AFTIME is sending the PowerADD 5.02v and 1.92a using
one of my USB-A to USB-C cables.
Richie
ImA4Wheelr
Last seen: 4 months 1 week ago
ImA4Wheelr wrote:
dthrckt wrote:
!{width:80%}https://i.postimg.cc/50ChQBhQ/20210831-200056.jpg! One side already failed. Starting to sense a theme with vipon.
Bummer.  I ordered those too.  Guess I'll check the thermal paste situation before deciding whether or not to return.  Thank you for reporting that dthrckt.
Finally got around to opening one up.  Bad news for anyone wanting to check/redo the thermal pathway.  The mcpcb is glued.  So wrestling the base out is a pita and risky.  Since I really like the light and paid so little, I think I will just keep them as is and hope they are adequately thermal glued.  The one I did open doesn't look promising though.
Oh, for those curious.  The emitters are wired 21S2P.  Unloaded voltage from the driver is about 67 volts.
dthrckt
dthrckt's picture
Last seen: 6 days 58 min ago
All 3 panels dies in mine now. They said they’re sending replacements but I doubt it, just chalking those garage bulbs up as a loss. No big deal.
pennzy
pennzy's picture
Last seen: 55 min 33 sec ago
Which ones are you talking about? I’ve had a pair in my basement for over a year now.
dthrckt
dthrckt's picture
Sorry, the latest deal for those 3 leaf garage bulbs, coupon from vipon. 1 is still working great, other dead. I have 2 others from different listing working for 4 years or so.
I have had zero Phillips led bulb failures out of 100+ in that time, so just warning people. These garage bulbs look less redneck than my 4 to 6 bulbs per socket solution. I would like to find good ones.
Hard to find the post on mobile, this was the item.
https://www.amazon.com/gp/aw/d/B08CVRNDJ3
Richie086
Richie086's picture
I thought that light looked familiar. I purchased two of those from that Amazon deal back on August 13th. I’ll have to use them carefully being plastic housings. Obviously
not great heat dissipation.
Richie
