I too would prefer LIFEPO4 for my power banks, but until a great deal on one comes around, it’ll have to be these using 18650 or 26650 Li-ion for me. But I do feel your pain on previous
power banks I’ve purchased. The one that has been great for me for the last 3 years is my Nextrend 75000mAh / 278Wh Power Bank. It contains (15) 5,000mAh LiitoKala Brand INR 26650’s.
I’ve found many of these type of portable power monsters contain either DP brand cells, or like my Nextrend using LiitoKala Brand INR 26650’s. A photo of the inside of mine is below.
I will say this, if the Chinese want to build something like this with excellent soldering and very neatly laid out, they can if they want to. But where it counts are the batteries have really been excellent.
I received my EBL 8xAA battery set & charger. Batteries did not come charged. They were pretty low. Charging took a very long time. After 5 hours and only half-way through, I let it continue overnight. I assume it may have been about 10 hours total.
Btw, once off the charger, these 1.2v cells were reading at 1.42v. Is that normal? Are they actually capable of this voltage, or were they overcharged?
I removed mine from the EBL charger before they were fully charged. They were so hot, you could barely hold them. So I use my AA/AAA PowerEx charger instead.
They don’t get nearly as hot charging them at 200mAh - 300mAh setting. They typically come off the charger at about 1.42v and the static voltage reduces to about 1.37v.
Edit: Just noticed in the photos it shows 6x cells which makes a 20,000mAh powerbank not 26,800mAh, but in the descriptions it claims it uses 21700? which according to this you might receive the 8x 18650 version or the 6x 21700 version POWERADD EnergyCell Series Power Bank, Power Your Devices – Poweradd
Poweradd is a well known charger & powerbank brand but something must have happened because seems like they’re pulling all of their products off amazon and selling them cheap under energycell store. I do remember they have been offering free stuff for positive reviews in the past, maybe same fate as tacklife?
Anyways $13.59 for a 26,800mAh powerbank with 30W PD charging is a steal, well that IF you get the real poweradd product. There is also a 15,000mAh version for $10.
Just got one of these in: https://www.amazon.com/dp/B08Y8M54M9?psc=1&ref=ppx_yo2_dt_b_product_details
No special deal. But was looking for something nicer than my $10 crappy metal vernier - I can’t read the darn scale - ones. And not as expensive as my Mitutoyo $$$ digital one.
There are jobs I won’t use the good ones for. Too chicken on FUBARing them up.
Not as smooth, but all metal, matches the readings of the big bucks set, Came with 2 extra batteries. Case clasps don’t feel like they will last very long.
$19.98 + tax. If they last, heck of a deal if you are in the market. Way ahead of the plastic jobbies that are just $10-$12 cheaper.
Interesting. I should qualify things a bit more, to help make the picture perfectly clear.
1. I tested one battery out of the box and it showed 1.27V with my basic digital battery tester. Now, since the cell is marked 1.2V, that should be considered a fully charged cell, right? So I thought maybe I should put it in the charger to see what is shown. Only 1 bar of power level was indicated.
2. I figured OK, I’ll put the whole pack on the charger. I have heard it’s good to “exercise” a NiMH cell at first use. Fully charge, deplete near empty, then charge up again. I didn’t expect that charging would take so long. I mean… cells starting at 1.27v, but the EBL charger showing only 1 bar?
3. It took way too long in my book for the charger to “top off” these cells. But, if there’s one consolation, I had temperature checked the batteries at several points. Never got hot. Barely warm even.
After charging they showed 1.42v. Next day, after “resting,” they’re now showing 1.34v which is in line with what’s considered “normal.” LINK.
AFAIK, there’s no such thing as a 1.5v AA NiMH battery. You have to step up to Lithium Ion to achieve that.
Been there, actually did that. Thank heavens it was a protected cell and the protection circuitry actually did it’s job. Yes, I’ve now learned to tape one end of the cell.
I got a great deal on mine 3 years ago. Monoprice had the Tacklife DC02 (metal, digital) for $8 and free shipping. They might not be high end, but they’re great. I probably use them at least once a week, especially now that I do quite a bit of 3D modeling for 3D printing.
