Well, the problem with driving the 34K-A at 120ma is that you will kill the LED rather quickly. I asked iamlucky13 to abuse my emitters a few years back, and this post is what he reported:
As you can see, it permanently degraded the 3400k emitter (34K-A) within a span of days when being driven at 125mA. 2300k emitters could handle a bit more, but still...
As a rule of thumb, you should never drive the LED past it's peak output curve (34K-A peaked at 110mA). Otherwise, you will destroy the emitters in a hurry.
To get a reasonable lifespan, you should limit the current to 50-80% of that peak (90mA for standard model [edit: for 34K-A, can't vouch for other models], 120mA for EX version). So, you will realistically get 21lm from the standard model vs 27lm EX models. That's about 30% difference, so take it what you will.
Thanks again rngwn! I suspected that might be the case. It is good to know I can safely drive the 34K-A with 90mA and get about 20lm out of each one. That lower current will equate to a longer run time which is a benefit — so they might actually work better for me then the EX model really. Going with a standard model would also allow be more choice of color temp too. I’ll have to think about it some more…
After looking further at the lumens vs. current vs. voltage graph (in the initial post), I realized that the 34K-A needs a bit more voltage than the 32K-C-EX so I don’t think they would run very bright with just two AA NiMHs. So I think I am going to go with three AA batteries and a DC-DC regulator to control the power. Finding a DC-DC small enough to fit in the head of the flashlight was an initial concern, but I think I can get one in there with my projected setup. Is there a graph like the aforementioned one that also includes rngwn’s other standard LEDS (besides the 34K-A)?
I had no idea that the Nichia GS was rated as high as 70ma. Does it get warm at that level? I’m actually not worried about going that high. I’d just love to have a 5 lumen, 5mm coin light with decent tint and runtime.
This just came out of the blue, but it seems like the company that makes 23k-AB, 34k-A, 58k-A (2300k, 3400k, 5800k) has just gone out of business. The sales rep did not respond to my inquiries, and the company's minisite has seemingly gone missing from the marketplace.
For 23k-AB and 34k-A, I only have a few left, so I'm afraid that this will be your (lucky few's) last chance ever to get your hands on these.
This is sooo sad. If you still have the last packs, I will claim both of them. I have 100 of each in my stock already but … they will eventually run out.
I hope you’ll find alternatives.
I do have backup companies to order from. The biggest problem is that I cannot get them as cheaply as Sophia's. In fact, I'd rather be making 0.5w models which delivers more output and could fit more hosts because the BOM gap between the standard models and those EX models isn't all that big anymore.
I swapped out 6 cold white emitters in a simple flashlight, transforming it from a well-meaning gift I didn’t have a use for into a fantastic night-time companion. ePacket delivery took 21 days to my US address, which I’m happy with given expected holiday shipping delays.
All photos are locked to ISO 55, white balance 4500K on a Pixel 4 XL.
I’m running the LEDs at around 10 mA via (((4.0−2.7)÷20)×1000)÷6. (6 LEDs in parallel, 20 Ohm resistor, roughly 4 volts from lightly used 3× AAA alkaline in series, ignoring internal resistance. I’ll switch to NiMH.)
Click/tap photos for larger view.
Before - 6× stock cold white LEDs:
(The flashlight is already partially disassembled, making the side spill more visible.)
After - 6× RWN05-19K-C:
In case it’s useful for anyone else, here’s a tint comparison against a D4SV2 with OSRAM W2 and a KR4 with Nichia E21A 2700K and non-floody optic.
These 5mm LED’s basically are their own optic and are not typically used with an external optic. I believe both the size of the cavity the LED sits in and the height and curvature of the dome affect the beam profile of a 5mm LED.
Update: The postal service has raised the cost of e-Packet to U.S. once again. From March 1, 2022, the ePacket shipping cost to U.S. will be $11. The shipping cost to other countries remains the same until further notice.
Until then, the ePacket shipping cost to the U.S. remains the same $10.
YES! The 1900K is perfect for night lights and led candles! A soft warm glow. I have been driving my night light projects with a single AA using a QX5252F and around 470-680uH inductor. This draws about 4-5mA, so an Eneloop charge should run around 450 hours! Anything brighter I have found to be too bright and disturbing to sleep. Maybe a bit brighter in the bathroom.
Nice about the 5252F, it will shut off when the battery drops below .9 volts to save from over discharge.
Very nice! Would love to see some pics. Are you mounting components on a board? Maybe a noob question but I’m running all kinds of components wild making tiny 1900k night lights
