That makes sense, I wish so had one of those things that can test output
I have one of these that seems to be working well - https://www.amazon.co.uk/dp/B006QHOX0Y/ref=cm_sw_r_cp_api_glt_fabc_WWVHS8R4352RRV92TBZH
If you step outside and put the light on something 100 meters away you’ll see the difference very easily between 50 and 100%. Inside the house, it may be harder to tell.
Calculating throw from candela = 2 * square root of candela. Therefore the quadrupling of candela to double throw would make sense.
Does this carry over into overall brightness / Lumens as well? I suspect yes, because the surface area of the inside of a sphere is a square function as well.
I am sure someone smarter than I will be along shortly to answer.
You don’t see lumens, you perceive lux.
Presumably that only measures lux not throw as well?
You can only ever measure lux. You then use a formula, or enter the numbers (Lux and distance from the meter) into a calculator to work out throw. I use this one - Lux to candela (cd) conversion calculator
I just hold the light to my ear on turbo and check my opposite ear with a light meter.
Just joking, but when I check a light for throw, the perceived brightness on the wall and using it a night are the most fun for me. I can see the difference between 4000 and 6000 lumens. It appears the more you use different lights, the easier it is to differentiate lumens.
Well I’ve ordered one of those light meters, what’s the recommended measuring distance to accurately estimate throw?
Depends on the light intensity and the range of your meter, usually 1-10 m. In extreme cases you can add a ND filter and correct the measurements afterwards.
Well I still have a Fenix light with known throw, presumably if I measure that and compare it Fenix’s own measurements then I should be able to figure out the margin of error
Not quite. You need a calibration light (the Fenix in your example) when you come to measure lumens, either through ceiling bounce, sphere or tube. But when it come to candela, it’s purely just numbers. I predominantly use around 6m to measure. So I set my meter up, choose the range (x10, x100 etc), measure the distance with a laser measure, then take a reading. Enter these numbers into the calculator I linked to above and it will give you your candela. Then I square root that number and x2 to get meters of throw.
you may just have a weakish battery
sometimes the bat cannot do what the light could do
and 50% more is not that apparent, either ,as others said
Fair pointed but I was testing with a fully charged battery. I’ll try the same test again outside when it’s dark when I have a chance, see if the drop in throw is noticeable.
The longest distance in my house is 6.46 meters so I use this for throwers.
Reading X 6.46 X 6.46 = Candela/CD.
Throw = Square Root of 4 X CD, all in meters.
Same answers as above.
Presumably you have to do this test in complete darkness?
It’s annoying that there’s no mode in biscotti that contains both 50% and 100%, then it would be easier to tell if there’s a perceivable difference.
Some lights might have regulated high and FET-driven “turbo” where the diff is about 2:1.
Switching back’n’forth gives a little hint of extra brightness, but nowhere near “omgwtf, that’s twice as bright!!!”.
Even with my Q8, I was expecting 5000lm (vs about 1000lm of my other lights) to be like daylight in the backyard, but it wasn’t. Bit of a letdown.
Brighter? Sure, but not “night’n’day bright” as you might expect.
Ok after testing in the woods in the dark, there’s definitely a noticeable difference between 50% and 100% but obviously it’s nowhere near twice as bright.
That’s very good news, but nowhere near being great news.
Over the few or so years, I spoiled myself as to what I subjectively considered to be very bright. As long as I was willing to migrate to larger lights. And that's exactly what I did. The first thing I considered to be very bright was me. Then I was dethroned by the Tru Value Rayz 1000 Lumen 9 x AA. Then that was dethroned by the Four-Sevens MMU-X3, 1,600 lumens. That was no longer very bright when the Niwalker MM15 5,233 lumens lit up my life.
Next, Noctigon Meteor M43vn 12 x XP-L 8,400 lumens.
Next, TN36UTvn 13,400 lumens.
Next, a lot more lux with X65vn with 11,500 well-tempered lumens.
Next, Acebeam X45vn muchly boosted to 25,000 lumens.
Next, Imalent R90TS 36,000 lumens. Next, Imalent MS18 100,000 L-words.
10,000 small white room ceiling bounce lumens is a round number for the cutoff for what looks very bright to my 61 year old, self-spoiled rotten eyes.
Outdoors, more throw with less flood looks brighter per given lumens; to me, anyway.
D4V2 W2, EC03 50.2, X50 and BLF GT94 are on my front four bright burners today. Tomorrow will be FW4a W2, FT02S 50.2, MS06 and HK90 to brighten up my life.
D18, KR1, MT07, MT05, NSX53, FW21pro90, E4K, MS03, TM9K and many others: My life is noticeably brighter with flashlights.
